03-05-2018, 07:03 PM | #23 |
24199
Rep 190,807
OP thank you for the taking the time and sharing your opinion
horsepower_and_hounds1836.00 M2guru383.50 |
03-05-2018, 08:29 PM | #24 | |
Rep 752
You don't hear this while driving, unless for whatever reason you're revving while you drive lol. Thanks for sharing this post. I can confidently say, stock air box is the BEST! Throw a BMC drop in filter and call it a day, maybe even an Eventuri Air Scoop for fun lol. That being said, I love the way the Eventuri sounds, I think I replied to your posts in another thread, I wasn't exactly sure what sound you were referring to but now I do. That whistling sound is negligible under all driving conditions... |
03-06-2018, 03:35 AM | #25 |
Rep 1,348
Efficient FMIC upgrade > than CAI by far! Do that and call it a day. CAI waste of time and money in comparison
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 |
Heronween0.00 |
03-06-2018, 03:36 AM | #26 |
Rep 1,348
03-06-2018, 10:21 AM | #27 | |
Rep 4,551
Drives: 2015 328d xDrive
BMC filter is oil'd. Oil getting into the intake = Dirty MAF sensor and eventual fault codes/CEL. Air scoops can cause air turbulence. While they are good in theory, most don't actually help airflow, they hurt it. What would actually help our cars would be a ram air intake system where the filters are actually directly in the path of oncoming cold air |
NYC Bimmer259.50 |
03-06-2018, 10:38 AM | #28 | |
Rep 752
Maybe it hurts it eventually? Idk. I never had problems. I don’t think the air scoop hurts or helps. If you look at the path with the Eventuri/their shroud that goes under the cone...it’s just “adding” more air. Whether that helps or not, idk. I also don’t think any intake would help lol, especially not MSR type ones. |
03-06-2018, 11:08 AM | #29 |
Rep 4,551
I'm all for leaving it stock, I just think (in theory) a filter positioned behind the grill that's directly in the oncoming path of cold air would actually lower IAT's. Yeah, it's more exposed to debris and water, but at least it's not sucking in hot air like most of the other aftermarket options that don't have sealed boxes.
NYC Bimmer259.50 ///M TOWN16569.50 |
03-06-2018, 11:39 AM | #30 | |
Rep 752
With my set up, IAT’s are usually 8-10 degrees above ambient temperature. That fluctuates with the ambient temp. And after multiple pulls. That being said, I want to say Eventuri is pulling in fresh air when driving. The only time hot air will be sucked in, will be from a stop which will quickly become “cool” air from outside as you drive off. So I don’t think it’d affect one. Wagner IC helps a bunch! |
AndrewC198910931.00 |
03-06-2018, 01:55 PM | #31 |
Rep 2,829
Thanks for all the research that you have put into this but bottom line no power, you're better off with a drop-in filter
BMW I12 i8 Frozen Yellow- H&R springs, 22" Radenergie F10 Monoblock Forged /// F87 M2 Aw -Vorsteiner Aero Kit, VFF-107,Macht Schnell-Springs,VF-Engineering/Hex tuning Stage Two,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe/// Wish list :Mexico delivery 2024 BMW M2 (G87) |
eeyang92318.50 |
03-06-2018, 04:56 PM | #32 |
Rep 190
I have the CTS intake and it is just ok as far as build quality goes. While it mostly sounds great, it has this annoying whistle that either has disappeared over time or I just don't notice it anymore after having the intake for a while.
I actually dremeled the plastic wire cover so that it would fit with the intake and still protect the wires in that box. Figured that buying another cover down the road is a small price to pay. Eventually I would love to get the Eventuri, it is just beautiful. I know the intakes don't really add any power, but like a cat-back exhaust, the sound is worth it IMO.
:::: 2017 AW M2 :::: (SOLD)
03-06-2018, 07:48 PM | #33 | |
Rep 752
But I don’t want to run a JB4 lol I’m flash tuned for a reason... I’m sure my BM3 tune could be made to work with BMS but eh not down. ALSO, where the filter attaches to the rotomolded plastic tube, its not reinforced with metal so under heat it can deform and essentially the filter won’t be sealed or could fall off. I say $1000 is a reasonable price for an intake on a car like this. I wish there was a plastic version of the Eventuri, that’s what I’d get....I don’t care what the engine bay looks like, stock looks sexy enough to me. Also, very curious on the other carbon fiber intakes out there, looking inside the carbon tube is it smooth like the outside? The Eventuri is not smooth at all, I can see how that could potentially affect flow...cause turbulence in certain areas. But in the end, stock intake is superior. Does stock intake suffice with say PURE Stage 2 + auxiliary fueling, like 500 hp area? |
Bazgab132.00 |
03-07-2018, 03:17 PM | #34 |
Rep 1,835
Drives: 2020 X4M CS
Ths may look cheap but it worked...without the sheet metal and DEI Heat barrier intake temps went up drastically in lower gears and mid RPM range...this brought them to stock and let me really hear the turbo and blow off valve...NO CEL In the long run I still switched back to OEM.
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 Last edited by DKX4///M; 03-07-2018 at 03:22 PM.. |
Heronween0.00 |
03-07-2018, 03:53 PM | #35 |
Rep 522
Can vouch for the Injen. Sounds absolutely brutal paired with a straight-through exhaust setup. Some "fluttering" sounds on lift at certain speeds, but doesn't bother me. No CEL.
05-02-2018, 12:31 AM | #36 |
756
Rep 2,149
OP here. I went with the Eventuri and installed it today. It's actually not as loud in cabin as I was expecting. The BSR intake on my Saab 93 Aero is much louder. The intake sound is louder and there is a loud blow-off sound when I let off the gas on the Saab. My Saab is also tuned, so maybe the higher boost is making it louder. More air being sucked in and more being blown out.
As for the Eventuri, mine has the new filter style and it still has the bottle blowing whistling sound. I think it's unique, so I don't mind it as much as I thought I would. And it definitely does make that sound while driving. But it's only when I let off the gas. The most noticeable time this happens is in Sport+ with the DCT auto rev matching when I downshift approaching a stop sign. Which I end up doing quite a bit because I live in a city. After removing my stock airbox, I totally see why stock is probably sufficient. Adding the Eventuri scoop to stock would probably have lower IATs than any of the other intake options. I kinda wish I did try the BMS intake, so I could report on if I got a CEL. But I didn't want the hassle of having to return it and buy the Eventuri if it did happen. I just wanted something I knew worked. |
05-02-2018, 01:33 AM | #37 |
Rep 599
Drives: M2, C63s, 718 Cayman GT4
2018 MG M2 - Ohlins R
05-02-2018, 09:41 AM | #39 | |
Rep 266
06-21-2018, 04:47 PM | #41 | |
Rep 699
Thanks for that. I've been searching for a drop in dry panel filter. I wouldn't put a K&N on my push mower. |
06-22-2018, 09:49 AM | #42 |
Rep 4,254
Say no to intakes. Also say no to oiled filters.BMW MAFs hate them.
Best thing you can do is put a new OEM filter in it. Done. If you have a compulsion to spend more money, drop an AFE ProDry S filter in.
///M Power
Heronween0.00 |
07-10-2018, 10:24 AM | #43 |
Rep 44
For those asking if the BMS intake still generates CELs, I can confirm YES. I just installed mine yesterday and now have a CEL after about 50 miles of driving.
Only mod on a brand new car. Sounds amazing, but if I can’t get rid of the CEL, I’m going to return it and go back to stock. Not getting a JB4 too just to get rid of a CEL. One thing that I’m wondering since I have a DCT. The placement of the MAC and the tube coming from the DCT are reversed. Could this be the cause? Is there some form of pressure coming back through the DCT tube that’s throwing off the MAF reading? Can’t seem to find the answer to fix this problem. |
07-11-2018, 12:22 AM | #44 | |
756
Rep 2,149
BMW_MSquared98.50 |
