08-04-2016, 09:35 AM | #23 | |
///M Powered for Life
11490
Rep 10,329
I have yet to hear a turbo engine that sounds even acceptable. I have driven the M2 and it sounds better than the M3, but that's not saying much! You mentioned straight line speed of the cars, which is where I find the previous ones got their doors torn off. Around a track, I believe Lightning Lap has shown every generation M3 to be faster than its equivalent Cayman/Boxster S. Maybe that will change now with the turbo Boxster, but if it did it would be the first time in 10 years. I wish they had made a 6 cylinder 2L engine for the new Boxster/Cayman. It wouldn't be as efficient as the 4 cylinder for sure, but it would have retained a lot of the pleasantness of the 6 cylinder with a small penalty and felt more expensive. BMW did this back in the stone age on the Z3 if I remember correctly. A NA 2L 6 cylinder with 150hp. Whenever I get into a 4 cylinder car it reminds me of diesels back in Europe growing up. That is not a pleasant memory as they seem like little tractors. |
08-04-2016, 10:46 AM | #25 | |
202
Rep 621
If you look at the fastest laps I provided, the m3 was easily beaten on track by the 981S on all but 2 tracks of 10, including a 1.2 second delta in the Lightning lap (that's VIR right?). The current car is definitely going to be much faster especially considering how much faster the 991.2s got from some pretty damn incredible numbers already. I would certainly have liked a 2.0-2.5 liter F6 over the 4s...but I think they are making some of the best and most technologically advanced turbo motors and can't find much fault in the 718 except that it doesn't sound AS good as the 6. |
08-04-2016, 12:23 PM | #26 |
TIM YOYO
1504
Rep 3,283
Drives: 2013 M3
Wishing for a 2L F6 turbo is about as reasonable as wishing for the S65 to return. A 2L six-cylinder engine would have a cylinder volume of 333cc, which is far below optimal. Cylinder volume is a balancing act between filling efficiency and heat losses to cylinder surfaces. Modern engineering identifies 500cc as the ideal balance between the two concerns.
It's easier to understand when you compare cylinder volume to cylinder area visually: View post on imgur.com (click for full size) At 333cc cylinder volume, cylinder surface area is around 265cc. At 500cc cylinder volume, cylinder surface area is around 350cc. So you get an additional 167cc of displacement for an increase of 85c^2 in cylinder surface area. You could, of course, keep going with cylinder size, but your intake and exhaust ports are limited by the area of the bore, so things start to get impractical for car engines pretty quickly. It's worth noting that where efficiency is top priority, cylinder volumes tend to be huge. That's why giant ship motors might only have 6 cylinders that displace many cubic meters. The engines run at constant speed for long periods of time, so you can turbocharge them all to hell in order to overcome fill rate issues. And that's your daily digression on engine design compromises
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech Past: 2013 ///M3 - Interlagos Blue Black M-DCT Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport |
M3 Adjuster7905.50 |
08-04-2016, 02:47 PM | #27 | ||
Rep 40
I personally prefer the big turbo punch and the effortless power at any rpm of a turbo car. I'll miss the sound of the 6 cylinder but most of the time even the Cayman S feels slow compared to a 4 cylinder turbo. |
08-04-2016, 04:39 PM | #28 | |
Rep 176
Taxation structure (in most important markets) is also a very important variable, otherwise 550 cm3 would be much more used, for instance. Considerable better in a surface to volume ratio and not to much different in what concerns intake and exhaust ports. |
bradleyland1503.50 |
08-04-2016, 07:14 PM | #29 | |
Rep 1,048
2019 Jeep Wrangler | 2018 BMW 320i | 2016 Porsche Boxster Spyder | 2009 Jeep Wrangler
gone: 2015 M4, 2015 335i, 2012 Turbo S, 2008 M3, 2004 M3, 2003 330xi |
08-05-2016, 05:43 AM | #30 | |||
7906
Rep 11,785
It's amazing how many people don't remember the Porsche 914 and the Porsche 944 (including 944 turbo). Porsche did the same thing at the time, as it was the direct competitor for the e30 m3 |
08-05-2016, 09:42 AM | #31 | |
Rep 769
BMW might be next!
It is the end of an era and we have to hope that down the line they will find a way to engineer that special lost Majid back into future tech. |
