05-31-2020, 02:59 PM | #1 |
Rep 438
Ohlins advanced track day Coilovers
These look nice , wonder what pricing may be ...
05-31-2020, 04:07 PM | #2 |
Rep 1,664
Ohlins TTX are usually around $10k, I have spoken to a few people in the know about Ohlins recently as I am putting a set of R&T on my car. I think these will be at least $7K+ but I could be wrong! There is a huge hole in the Ohlins lineup between R&T and TTX. If they did something similar to Clubsports (KW/Bilstein) at around $4K I would of bought them.
06-04-2020, 12:55 AM | #6 | |
Rep 1,336
If you were dropping that much coin then MCS and comparable setups look attractive price wise. Would be interesting to see the price point. Appears they gone with a stiffer rear bias where most other setups run a stiffer front. Nice to see they have included the drop links as standard.
Montaver2180.50 |
06-04-2020, 09:58 AM | #7 | |
Rep 1,664
If they did a double adjustable R&T kit with integrated camber plates that would be the sweet spot IMO. I would love this kit of course, and as much as I love winning HPDE trophies it's hard to justify for 10-15 track days per year. |
06-04-2020, 04:32 PM | #8 |
Rep 1,336
Totally agree a Ohlins DA setup would be a nice option. I had R&T in my 350z and loved them. They were an awesome B Road setup however the thread on Bimmerpost about owners complaining about the slow speed knock turned me away and bought a set of MCS 2WNR instead.
But you never know Ohlins may be aggressive on the pricing to hit that justifiable price point or be like the Honda NSX and price themselves out of the market again. Here is the link to the TTX setup. Looks like the 10k for custom was with external canisters. https://f80.bimmerpost.com/forums/sh....php?t=1129675 On a side note if I'm correct the TTX in the rear provided enough clearance to the sway bar so there is not contact while allowing the damper to be aligned square to the chassis. MCS, AST, Moton etc use an offset lower spacer on the control arm to gain the clearance which means the damper is not square to the chassis and introduces a slight ratio.
06-04-2020, 07:46 PM | #9 |
Rep 438
“On a side note if I'm correct the TTX in the rear provided enough clearance to the sway bar so there is not contact while allowing the damper to be aligned square to the chassis. MCS, AST Moton etc use an offset lower spacer on the control arm to gain the clearance which means the damper is not square to the chassis and introduces a slight ratio.”
@MR RIZK ^^^ reason enough for me to go with these if it’s true . I hope they incorporate this in these new ones . Last edited by ROBM2C; 06-04-2020 at 08:16 PM.. |
06-04-2020, 09:06 PM | #10 |
Rep 1,336
I know this is an Ohlins thread but if you were inclined towards MCS or similar, bimmerworld apparently is coming out with something (I think a new sway bar as per another thread) that provides the necessary clearance. So if u were going to change the sway and "potentially" want a cheaper price point this is also an option. The TTX looks like a sweet setup.
06-06-2020, 06:41 PM | #11 | |
Rep 78
Drives: 2020 BSM M2C
06-07-2020, 09:52 AM | #13 |
Rep 309
Drives: 2018 M2 LBB - 6MT
Pardon my ignorance, thought the TTX has been out for the F8x chassis for some time. Is that different from this?
https://store.worksmotorsports.com/O...hl.bmrgr00.htm |
06-07-2020, 12:54 PM | #14 |
Rep 438
The difference is the ttx have an external reservoir .
These I presume will be one step lower. The advance track day have not been released yet . |
06-07-2020, 03:44 PM | #15 |
Rep 309
Ah sorry. I saw the TTX logo on the image and thought they were the TTXs, but I guess they have "TTX technology". Seems like the advance track day option would've been a great solution, albeit arguably a bit expensive. I do enjoy the R&T as it's a daily with some occasional track days, though.
06-11-2020, 10:06 PM | #16 |
Rep 438
06-15-2020, 04:41 AM | #17 |
Rep 1,336
06-30-2020, 08:44 PM | #18 | |
3843
Rep 54,376
Drives: F80 M3
06-30-2020, 08:53 PM | #19 | |
3843
Rep 54,376
Drives: F80 M3
E46, E9x, and F8x M kits will be released. This TTX 2 Way kit for the F8x M will be very similar to the factory M4 GTS setup. Price will be very competitive to many 2 way kits(assuming 2 way with reservoir) currently available. We are guess right around the $7k range. |
PLF693766.00 |
07-07-2020, 05:01 PM | #20 | |
Rep 923
07-07-2020, 06:08 PM | #21 | ||
Rep 1,336
This "apparently" has been fixed but you don't know if u get a set that has been updated or not. https://f87.bimmerpost.com/forums/sh....php?t=1425894
07-12-2020, 08:26 PM | #22 |
Rep 438
[QUOTE=HP Autosport;26381118]We learned about these kits earlier this month. Release date is set to be this summer.
Nice , let us know what day there availible. |
