M2 Technical Topics > Suspension | Brakes | Chassis > AST 5100 coilover for M2C
      05-31-2020, 01:08 PM   #1
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
Anyone in the US running AST 5100 on their M2C? Impression over stock? Also are the top strut mount for the front needed?
      05-31-2020, 05:32 PM   #2
Big Fabri
Big Fabri's Avatar
Italy
95
Drives: Lamborghini Huracan
ast are very good.You also want camber plate to make a correct geometry. I don't know why bmw makes the rear adjustable and the front non adjustable.
      06-02-2020, 02:27 AM   #3
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
I have OGM2 c/w MPerf Coilovers and have driven LCI M2 & M2C with AST's - you won't be disappointed.
IIRC default from AST is OEM compatible springs so you can re-use top mounts.
As Fabri says, if you are wanting more aggressive geo then you'll need adjustable either top mounts or lower arms to add more camber.
Having put longer arms on the front of my M135i (gained camber/caster/track width) and owned cars with camber plates (more NVH), I'd probably opt for adjustable lower arms.
HTH, BP
Current '22 X3M LCI..
m20e30871150.00
      06-02-2020, 03:17 PM   #4
MR.
MR.'s Avatar
Great combination between track use and daily comfort levels. If you don't need the top mounts, then just go for the setup without. Great solution all around and lovely to use.
Both my MINI and BMW are running AST 5100. Great piece of kit.
MR
      06-02-2020, 05:38 PM   #5
3t3p
New Zealand
455
MR
Reliability so far any issues?
      06-02-2020, 06:39 PM   #6
tropicatango
tropicatango's Avatar
437
Drives: Bmw f87 M2c hockenheim silver
Does anyone have the part nuber or site from where to buy ast 5100 for the m2c for the best price
On the ast site there is no application for the m2c....
      06-03-2020, 03:09 AM   #7
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Same kit fits all F87's
      06-05-2020, 02:31 AM   #8
widetyres
279
Drives: M3 E92 DCT, 2012
I have AST5100 on my OG M2 - just fitted a few weeks ago.
Turn is much better, car is flatter into corner - the OEM suspension is too soft on the front and the far-front corner sags on turn-in - this was frustrating and didn't inspire confidence (this was the main reason I upgraded).
The ride is incredibly smooth on the softer settings. I am now running @ 6 clicks (mid setting) all round and the balance between road holding and comfort is excellent. Now it has the geo done, the turn in is great, mid corner balance is incredible, but it's absolutely fine comfort wise, heck even in a straight line it feels really sorted and planted on the road - excellent suspension!
The rear also has significantly more grip around corners and over road imperfections compared to stock (even in an unaligned geo state).
Whether you need adjustable top mounts depends on where you drive it - I have -1.6 front (fixed) and -2.0 rear camber and this feels great on the road - (TBH, I would have liked a bit less rear camber to maximise grip (e.g. -1/-1.5), but this is how they set it up and it's fine - a reasonable balance between road and track duties - my car is lowered and apparently there are limits to how much you get the camber back to). If you are doing a lot of track days though, you should def dial in more camber which will need new top mounts.
m20e30871150.00
      06-05-2020, 02:36 AM   #9
widetyres
279
The AST site is very out of date - it doesn't even hold the references to the OG M2 (on their UK site at any rate).
You need this one:
https://arperformance.co.uk/product/...uspension-kit/
      06-05-2020, 03:32 AM   #10
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
WT - shame you didn't get the rear camber set to -1.5deg, as you say, whilst getting your geo aligned. From 1st hand experience, the added traction is more even noticeable and impact on how the rear behaves on bends (either on bumpy roads or max attack on smoother tracks) with pucker coilovers. BP
      06-05-2020, 04:21 AM   #11
widetyres
279
BP - did you manage to get -1.5 on your MP coilovers? I have set my ride heights up to the same as BMW specify for those (F:595,R:600 from bottom of alloy)
      06-05-2020, 06:03 AM   #12
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Yes - dailing in slightly less -ve rear camber and getting rear toe right was no issue as it's well within the range of oem hardware.
AFAIK setting rear toe up correctly with higher rear camber (ie -2deg++) is when it gets more difficult with the oem eccentric bolts.
      06-05-2020, 08:13 AM   #13
widetyres
279
Cheers - I will make a point of getting this done next time.
      06-05-2020, 10:06 AM   #14
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
For me track days are about 2-3 times a year and some year it's none. Mainly street and canyon drives. I reached out to AST as well, they said 70% buyer use stock mounts. If I was doing 10+ days a year I would definitely go for the mounts.
      06-07-2020, 06:43 AM   #15
MR.
MR.'s Avatar
None! My MINI has had major beating for 3.5 years now on this suspension, and still no issues.
On the BMW nothing as well, one bolt came loose of the control rod but we tight it again. Initial installation it was not put tight enough.
MR
widetyres279.00
      06-07-2020, 04:05 PM   #16
3t3p
New Zealand
455
MR
Cheers. Not much info out there about real world useage. No rebuilds needed then, do they have any dust boots?
      06-07-2020, 04:36 PM   #17
widetyres
279
MR
Dust boots for the rear are included in the kit. You reuse the oem front dust boots if you want them - you have to reuse the top part (spring seat) in any case.
      06-08-2020, 05:34 PM   #18
3t3p
New Zealand
455
That's cool, I recall something saying originally no dust boots which is kinda scary for a daily.
I wonder how AST does in reliability stakes considering M perf coilovers do sometimes fail.
      06-09-2020, 07:15 AM   #19
FreeDarko
Drives: F80
Anyone run these in cold climates/winter yet? Any noises or issues?
