05-31-2020, 01:14 PM | #23 |
6634
Rep 4,145
Drives: '18 M2 6MT
05-31-2020, 02:02 PM | #25 |
Rep 839
Thanks All-
My shop is starting the install tomorrow- No one ever mentioned the existing hardware kit so I will bring this up to the shop tomorrow. I emailed the shop foreman the BMW installation guide that the dealership uses to properly install the kit. If they are not comfortable installing the per BMW NA- I'm going to take it to my BMW dealer and have them do the install- |
05-31-2020, 05:29 PM | #26 |
Rep 251
to do the proper set up you need scales to conrner balance the car ,fuck what bmw says.If you are always alone in the car when you have fun setting with 2 75kg in the front is bullshit. You have to set it with the sway bar disconnected to avoid false reading. 49.5% cross weight is fine for road. Be sure to use adjustable endlinks or you will induce load to the swaybar and this is womthing you don't want.
instagram: https://www.instagram.com/big_fabri/?hl=it
06-01-2020, 02:04 AM | #27 |
Rep 69
I had my suspension installed at BMW, and they did have to order all of the hardware. I believe it cost me around $80.
06-01-2020, 02:19 AM | #28 | |
Rep 4,516
Once done, CG reconnected the oem drop links with zero force so adjustable ones aren't a pre-requisite for MPerf coilovers if staying close to oem ride height settings. CG set corner balance with solo driver (weighted drivers side only)
Current '22 X3M LCI.. |
06-01-2020, 02:24 AM | #29 | ||||
Rep 251
I dropped the car to around 15mm so I needed different endlinks This is the rear endlinks lenght difference. Of course you adjust properly only one wheel
06-01-2020, 02:29 AM | #30 | |
Rep 4,516
It has settled since and I don't want it any lower TBH as the car has double duty DD & TDs.
06-01-2020, 02:32 AM | #31 | ||||||||
Rep 251
06-01-2020, 02:44 AM | #32 | |||||||||
Rep 4,516
They're chassis dynamic nous is 2nd to none. 😉
06-01-2020, 02:47 AM | #33 | ||||||||||||
Rep 251
06-01-2020, 02:55 AM | #34 | |
Rep 4,516
I'm pointing out that adjustable drop links aren't essential.
06-01-2020, 02:13 PM | #35 |
Rep 251
in my opinion they are. try to remove them and see if there is or there isn't any load. i bet you can't. i did many of these . one right last saturday. you can also move the position of the swaybar but you are changing the leverage of the suspension
06-04-2020, 11:27 AM | #37 | |
Rep 4,516
https://rparts-sites.s3.amazonaws.co...ll%20instr.pdf Searched on here for the same and this came up... https://f87.bimmerpost.com/forums/at...9&d=1558634564
