05-28-2020, 08:15 PM | #1 |
Rep 835
M-performer coilovers pre-adjustment????
Hello-
My M2 competition is currently at my performance shop having the coilover installed. I don't remember seeing the instruction manual inside the box sealed directly from BMW. Production date was this year for build. I understand that the recommended height setting is 20m all the way around. does anyone know if they come preset at 20m from BMW directly?? |
05-28-2020, 10:37 PM | #2 |
Rep 4,976
Really quick search would have led you to this thread:
https://f87.bimmerpost.com/forums/sh....php?t=1391804 That had this: https://www.shopbmwusa.com/PDF/BMW_M...ion_Manual.pdf Does that help solve your question? If not, I can try to track down the larger one. EDIT: Larger one if you can read German: https://f87.bimmerpost.com/forums/at...8;d=1459903458 Also some good feedback in the threads here: https://www.google.com/search?q=f87+...=719&dpr=3
Current Car: 2018 F80 M3CS, SMB, DCT, ZEC, MPE Recently Departed: 2020 F87 M2C, LBB, ZEC, 6MT (Euro Delivery Aug. 29, 2019, totaled by an idiot in a Camry who then ran from the scene) Wife's Prior Car: 2018 F80 M3, Yas Marina Blue, DCT, Black 19s, Carbon Structure Anthracite Cloth/Leather Combination, Driving Assistance Package (Euro Delivery Oct. 9, 2017) |
05-29-2020, 07:47 AM | #3 | |
Rep 835
Thescout134944.00 |
05-29-2020, 10:12 AM | #4 | ||
Rep 4,976
05-29-2020, 12:41 PM | #6 | ||||
Rep 835
05-29-2020, 02:34 PM | #7 |
844
Rep 1,962
If it's the installation instructions, it says 600mm rear, 595mm front, as measured from the lowest point on the rim to the highest point on the underside of the wheel arch. This is on the bottom of page 6 for the front axle, and the top of page 7 for the rear axle.
05-29-2020, 02:48 PM | #8 |
Rep 135
Above the factory settings of the M performance suspension on my 2020M2C. It's a tad lower than standard, for me the perfect fit. In combination with the M performance forged wheels the stance is beautiful. When the set was mounted (at new delivery with the dealer) it was ca 5mm higher, so it settles +5mm. I would not like the car to be lower. Handling wise, icw the wheels and the cup tires, this is another game than lowering springs and the std tyres. This is pure mechanical grip. Dampener settings are also as prescribed. The car is more comfortable than std. In the end it is the quality of suspension that counts I guess. |
05-29-2020, 02:56 PM | #9 | |||||
Rep 835
So your sitting at 20mm? Or 25mm? |
05-29-2020, 08:14 PM | #12 |
Rep 4,976
The German one that I posted above I believe. Look at page 7.
05-30-2020, 12:55 AM | #13 |
Rep 69
Attached install manual in English. Reference page 6 and page 7 for instructions on ride height adjustment. The ride height is set after the suspension is installed with 75 kg weight on driver and passenger seat. It is measured from the bottom of the wheel to the fender. It is not set prior to install because the ride height depends on the car's weight distribution. If it is set prior to install it is unlikely each corner will be at the correct height. Hope this clears it up. |
M Fifty844.00 |
05-30-2020, 12:03 PM | #14 | |
Rep 835
Also I was a little confused that on some of the websites for ordering this kit I saw that there's an extra hardware kit for $87 I ordered my MP kit from IND and they did not say anything about an additional hardware kit for install. |
05-30-2020, 02:57 PM | #16 |
Rep 835
05-30-2020, 03:59 PM | #17 |
Rep 135
Tbh I have no idea. It sits at the recommended settings for 19" wheels, which is the earlier mentioned 595/600 dimension.
I posted the picture as reference what that means. It's pretty low without being too Barry Boy, if you know what I mean. They did the 75kg as well and while doing so cornerweighed and adjusted the car. 1627kg with 75kg on the driver seat and a full tank. That's a fat lady ;-) |
05-31-2020, 03:22 AM | #18 |
844
Rep 1,962
05-31-2020, 06:19 AM | #19 | |
Rep 4,496
If your installer has priced to include then you are ok if not then they re-use the existing fittings.
Fettled M135i EB AT - gone but not forgotten:
AW M2 DCT |
05-31-2020, 07:33 AM | #20 |
6626
Rep 4,145
Drives: '18 M2 6MT
Refer to this, refer to that, do a search. This forum is full of assholes just like any Civic forum. Sad
05-31-2020, 08:55 AM | #21 |
Rep 278
Understanding what BMW recommends as the proper height, here's what we did as a starting point and we didn't change it once the springs settled. The fronts were set to 12.5mm (using a digital caliper) measured from the remaining top thread (below the to the base of the locking ring) to the base (below last available thread). The rears were dialed till they bottomed out based on other members indicating to set them to their lowest setting. Today, we sit at 23 1/2" or 596.9 in the front and 23 5/8" or 600mm in the rear. These were installed on December 5th 2019.
Husband setup everything off the car with all the necessary parts so all he had to do was remove the entire assembly and swap in the new assembly (fronts). Hope that helps, M |
05-31-2020, 09:55 AM | #22 |
844
Rep 1,962
