M2 Technical Topics > Track / Autocross / Dragstrip > TC Kline or Ohlins, input appreciated **updated**
      11-09-2019, 04:30 PM   #1
Malakas
Drives: 2020 M2c
Fellow track rats,
Looking into suspension and pretty much had it nailed down to the Ohlins coilovers with TCK camber plates. I like the single dial adjustability. Seems easy for a car that will be 80% street, 20% track.
But I also like the idea of supporting a die hard track enthusiast that has given a lot back to the BMW racing community... I know on the M3/M4 forums a lot of guys have the TCK setup and love it, Im just wondering how easy it is to adjust.
Any feedback would be appreciated... doing a WRL race at COTA in a couple weeks but my first DE in the M2c will be late Feb, so I have a little time to sort this out, but not a ton.
Thanks!
J.
Ride: 2020 F87 M2C, 6MT Drive: Nine-Four Motorsports
Before:
2013 - 3.8L GTR, first DCT
2012 - 5.2L R8 v10, 6MT
2011 - 4.0L E92 M3, 6MT
      11-09-2019, 06:03 PM   #2
Commanderwiggin
Commanderwiggin's Avatar
2050
Drives: M2C - X3M - Turbo E46 M3 - 45E
I have the TCK D/A kit on my E46 and it's been perfect for the past 7 years. I plan to get the same for my M2C within the year. I rode in a car with Ohlins RT and although it wasn't on the track, it felt very similar to OE; just lowered.
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration
1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder
Malakas469.50
      11-10-2019, 10:32 AM   #3
M2C AW
Drives: 2019 M2C Alpine White
Im happy with the Ohlin DFV R&Ts..….for my road and track application. Good everyday ride quality at 10+ clicks. I don't necessarily love the bottom adjustment..but oh well. Sorry..no experience with the TCKs for comparison.
Ill be at the WRL PDS on Friday. Stop by if you'd like to take a look (MGM #7).
      11-10-2019, 01:08 PM   #4
Malakas
Drives: 2020 M2c
Everyone who uses the TCK stuff just loves it. How are they to adjust?
Thanks! I might just do that... I thought we had some test time on Friday as well. Not sure what garage we have but were running a Supra and Lex IS. The Supra is hard to miss. Will definitely try to find you - would like to check out the adjustment knob.
Before:
      11-10-2019, 01:29 PM   #5
Commanderwiggin
2050
Yeah they've been awesome. To adjust rebound you need access to the top of the damper and the compression is at the bottom of the old kits. Pretty easy to adjust. On the F8X kits the compression is still at the bottom and they moved the rebound so you can access from the wheelhouse. See here: http://www.tcklineracing.com/webdocs...etails1204.cfm
One thing...Koni dampers may not look the nicest but they're stupid reliable and perform really well in comparison to MCS/JRZ/Ohlins.
JTO245274.50
      11-10-2019, 04:06 PM   #6
PrimeBMW
PrimeBMW's Avatar
Drives: E46 M3+S62, E92 M3
Fellow track rats,
Thanks!
J.
Personally I wouldn't bother with either you are considering. Skip both and go with MCS singles. They can be pared with spring rates that are comfortable on the street and very effective on the track.
      11-10-2019, 05:13 PM   #7
bentom2
I’m in the same boat as the OP, trying to decide between Ohlins and TCK. I’m curious what benefits you’re getting for a ~50% increase in cost.
Both the Ohlins and Koni dampers have a decent reputation for longevity. Can the MCS stand up to multiple years on a daily in all weather conditions, or do you trade off more frequent service for more sensitive dampers?
      11-10-2019, 08:54 PM   #8
PrimeBMW
PrimeBMW's Avatar
How much are the options you are considering? Most MCS singles are $2450 plus camber plates, springs and then install. That is some top notch performance for the price. I don't know how many street miles you put on but might need to rebuild in a couple years??? (Rebuilds are reasonably priced) MCS has the best customer service in the industry. So you can't go wrong. Plus you'll never risk wishing or needing better performance. Unless you upgrade to double or triples (which is overkill for HPDE)
I guess I would ask this. Are you competitive, interested in improving and going as quick as you possibly can? Buy MCS. If not then I guess it doesn't matter what you buy.
*I often see or hear of someone buying Ohlin R&T or KW Club Sports thinking they are top notch. Then a couple years later understanding that they are not that great. They then go with MCS or JRZ. Now that is a expensive route.
Hopefully this is helpful.
bentom2335.50
      11-10-2019, 09:19 PM   #9
OG Shark
OG Shark's Avatar
4693
Drives: Angry
I have no experience with TCK so cannot compare - but I am very happy with the Ohlins RT on my M2. Very capable on this platform on the track & still with good street manners. I run their suggested spring rates - very good no fuss setup imo.
Sorry - off topic - M2MGM you running over the weekend too at WRL or just there for Friday?
      11-10-2019, 09:37 PM   #10
OG Shark
OG Shark's Avatar
4693
Drives: Angry
Certainly can’t go wrong with MCS but I think you might be pleasantly surprised with the ohlins on this car. It’s actually a very capable package on this platform. Maybe not on other platforms - that I don’t know - but definitely happy with them on my F87.
bentom2335.50
      11-10-2019, 11:04 PM   #11
bentom2
Ohlins R&T and TC Kline Double Adjustable are both right around $3k. Looks like MCS 1w are a bit more for on the F8x platform for whatever reason, around $3,300. Springs and camber plates are another $1,100.
The overkill you bring up for 2w or 3w is exactly what I’m trying to figure out for the $3k options vs the MCS. Support and service are certainly worth something. Sounds like TCK is at least s accessible as MCS, and my preferred local shop is an Ohlins dealer, including in house rebuild/revalve.
FWIW, I’ve absolutely ruled out KW CS. At $5k, I’d absolutely go with your recommendation instead.
This stuff is tough to work through. It’s at least as subjective as tires or brake pads, but at least I can experiment with those and find what works for me. With suspension, you’re stuck with it for a long time, or out a hefty sum to switch.
On the other hand, coming from stock suspension, I’m sure any of these options will be a nice improvement.
CrashFL137.50
JTO245274.50
      11-11-2019, 11:11 AM   #12
OG Shark
OG Shark's Avatar
4693
Drives: Angry
Im signed up for the Friday DE only....but might stick around to spectate Saturday’s race.
Good deal, enjoyed the DE last year but the traffic got a bit frustrating at times. Was a lot of fun with some of the race teams mixed into the groups though. I'll be in an m240iR for the weekend - should be a lot of fun seeing how it compares to our M2's.
Having your preferred shop being that familiar with Ohlins is definitely a plus. But would also think MCS would get you sorted out pretty quickly as well - with a bit of extra time in the mix for shipping. Hopefully the service frequency doesn't end up being that much either way you go so it doesn't end up being an issue.
Do you have wheels & tires figured out yet? With the larger spring perches vs oem you might need to consider this as well. I know with the Ohlins it is very, very tight - but I can run a 9.5" front with 285 Pirelli DH or 275 Hoosier R7 on the track. I back down to a 265 MP4S on the street. Run all these on 18" wheels. Not sure about the size of the MCS - maybe PrimeBMW can give you some feedback here. I want to say that Ohlins is on the larger size so MCS should have better clearance, but I'm definitely not 100%. Just something else to consider if you haven't already - a lot going on with our M2's.
bentom2335.50
      11-11-2019, 12:19 PM   #13
bentom2
Good point about wheel clearance. I do recall now reading something about decreased tire/wheel clearance with the Ohlins.
I’m running APEX FL-5 in 18x9.5 et28 fitted with Hankook RS4 265/35r18. I’ll want to be able to run 275s as well and prefer not to use spacers, though they aren’t completely out of the question.
What offset are your 9.5s? Sounds like you’re shuffling plenty of tire in there despite the tight fit.
      11-11-2019, 12:53 PM   #14
Malakas
Drives: 2020 M2c
Thanks for all of the responses - this is exactly the conversation I was hoping to start...
MCS... oh MCS. Yes these shocks are pure sexiness. I spoke with them a few months ago about running the electronic setup (at 10k but oh so cool) but never really considered the single adjustable. Would probably be around 5k all in (shocks, springs, camber plates and install) but maybe worth trying it out.
I wish I understood more about shock technology... would only rebound adjustment be enough to have a setting for street and one for track?
I asked about the rebuild interval and I cant remember what they said, but it was definitely not bad. And at that point you could upgrade to 2W if you wanted to.
All I have heard is great things.
...I’m sure any of these options will be a nice improvement.
Thats for sure, but it is a tough decision. Right now MCS with camber plates look to be 5k range, Ohlins 3200 + camber plates, and TCK is 2900 WITH the Camber plates. For a car that is only doing to see a DE here and there for fun not sure if there's a huge handling / cost advantage in going MCS... but they sure are trick.
Before:
bentom2335.50
JTO245274.50
      11-11-2019, 04:06 PM   #15
OG Shark
OG Shark's Avatar
4693
Drives: Angry
That is the same size/offset that I have on the front - but I do have to use a 7.5mm spacer Turner 7.5mm Spacer to clear. I'm with you on preferring not to run spacers - unfortunately there was no way around it with this combination on my car.
bentom2335.50
Malakas469.50
      11-11-2019, 05:16 PM   #16
PrimeBMW
PrimeBMW's Avatar
The shop that I go to here in Portland is AR Motorsports. They have likely installed more MCS that anyone. Plus have helped prototype MCS for a number of platforms. They would likely be below $5000 for parts, install, alignment and corner balance. Between AR Motorsports and MCS you would get your track and street settings. The valving would also allow you to change spring rates if you like.
*I also have MCS triples on my race car.
bentom2335.50
Malakas469.50
      11-11-2019, 07:14 PM   #17
bentom2
If I convince myself to spend MCS money, I’d definitely source through AR. Dan is at a number of the DE days I attend providing support for anyone who needs it. Pretty cool that they do this. I’ve never needed his services fortunately, but it’s good knowing he’s there.
I’ll probably reach out to them for a quote when I get closer.
PrimeBMW661.50
      11-11-2019, 07:54 PM   #18
Malakas
Drives: 2020 M2c
The shop that I go to here in Portland is AR Motorsports...
Cool. Thanks for the rec. I sent MCS an email this morning but haven't heard back yet.
Before:
PrimeBMW661.50
      11-12-2019, 02:49 PM   #19
Malakas
Drives: 2020 M2c
If I convince myself to spend MCS money, I’d definitely source through AR. .
Do you have his contact info?
      11-12-2019, 05:28 PM   #20
PrimeBMW
PrimeBMW's Avatar
AR Motorsports 5036973311. You want to talk to their performance/Motorsports division.
      11-12-2019, 06:28 PM   #21
Malakas
Drives: 2020 M2c
Thanks!
PrimeBMW661.50
      11-14-2019, 04:50 PM   #22
Shayan55
Shayan55's Avatar
Drives: F90 M5
2105 BMW M235I  [0.00]
I had TCKline Double adjustable on my M235i and loved them on track and on the street.
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct
Hmu on Ig: @n55_shayan
JTO245274.50
