05-30-2020, 01:10 PM | #177 |
Rep 439
Yes. There's a member on here who has 255/275/35 on MP coils, no issues. That's the tire size I'll be moving to after.
07-22-2020, 08:50 AM | #178 |
Rep 658
I have 763 rims and big OEM brakes (2NH - the ones with silver calipers) on my M2C.
The car is primarily used fir long journeys and spirited driving. Would adding M performance coilovers improve handling without sacrificing comfort? The ability of the suspension to tolerate poor roads is very important, as the roads where I live, are far from being perfect. |
07-23-2020, 02:29 AM | #181 |
Rep 658
07-23-2020, 02:34 AM | #182 |
Rep 4,515
Agree 100% (plus having 18" wheels & tyres with more sidewall helps too) ;-)
Current '22 X3M LCI.. |
07-26-2020, 01:18 AM | #184 | |
Rep 4,515
https://www.shopbmwusa.com/PDF/BMW_M...ion_Manual.pdf
325smg11.00 |
07-26-2020, 06:04 AM | #185 | ||
Rep 21
Colman
08-01-2020, 07:04 AM | #186 | |
Rep 19
I bought the M Performance suspension, and I felt the difference IMMEDIATELY as I was leaving the dealership. The dampening improvement is incredible. It is slightly stiffer feeling, but the dampening more than makes up for it. In my opinion, totally worth buying. You can stiffen up the dampening with a knob before hitting the track. Two thumbs up from me! |
08-01-2020, 09:21 AM | #187 |
Rep 1,389
explain this to me, when a car is stiffer but has better damping, how does that translate in the real world?
Damping I thought is returning the wheel back down after an upward force which the springs absorb. And damping is what reduced ocillation if you go over a bump. I'm trying to picture the M perf coilovers, where it is stiffer but better damped? |
08-01-2020, 12:40 PM | #188 |
844
Rep 1,962
Springs "return the wheel back down after an upward force", the dampers are there to slow that down (both in bump and rebound) and stop it oscillating. HTH
08-01-2020, 01:35 PM | #189 | |
Rep 658
So would you buy it if the roads were significantly worse than those in Germany? Ability to drive on poor roads is very important in my case |
08-01-2020, 01:37 PM | #190 |
Rep 1,054
I have MP coilovers that were installed by the dealer.
From wheel bottom to fender, I'm about 595 mm front, and 610 mm rear. (without any load) Tech said he couldn't go any lower on the rears (although 600 mm is the BMW recommended height). It doesn't really bother me much, and it gives somewhat of a positive rake which is fine. However, anything that might have stopped him from going lower in the rear? |
08-01-2020, 04:45 PM | #192 | |
Rep 3,005
https://f87.bimmerpost.com/forums/sh...2#post24922742 Though if this were the problem, I think it would be a lot higher. |
csbear1118.00 |
08-01-2020, 09:05 PM | #193 | |
Rep 1,054
I'll see where the rear spring adjuster is when I get a chance. I believe you both are correct. If the rear spring cup was still in there, I think my rear would be a lot higher as the cup seems to be more than 10mm thick. And I would probably get some funny noises. And from what the tech said, it was tricky to get those last few mm for the rears. That seems to be the common thought regarding the M Performance coils vs the KWv3... the rears are not as adjustable on the MP coils. Which is ok by me. Omasou - I've seen your post before, but I will just say: the 763m look amazing, especially with the drop... I am seriously considering a set. Are those 19x9 ET29 19x10 ET40 ? Last edited by csbear; 08-01-2020 at 09:31 PM.. |
08-02-2020, 12:20 AM | #194 | ||
Rep 3,005
This guy is running the M3/M4 CS orbit gray sizes on his M2, so they do work. https://www.bimmerpost.com/forums/sh...php?p=26447680 Last edited by omasou; 08-02-2020 at 10:40 AM.. |
csbear1118.00 |
08-02-2020, 05:20 PM | #195 |
Rep 1,054
Here are my rears (sorry for the large pic).
Seems to have a little space between the adjuster and body. Tech probably had some difficulty with getting those last few mm. I don't see the rear spring cup, so that's good. |
08-02-2020, 05:34 PM | #196 |
844
Rep 1,962
Well, subject to each end of the coil being properly seated, it looks like you've got more than 5mm of adjustment to go on the adjuster, and hence this ia where your 10mm of ride height adjustment is hiding.
Noting that KW suggest dropping the rear suspension to set the adjuster on the V3 (although that sits the other end of the main spring), and the lack of space to get the c-spanner in there, it might be easiest to relieve the pressure on the spring by supporting the rear hub, undoing the damper top mounts and then carefully lowering the suspension before making adjustments. HTH |
csbear1118.00 |
08-02-2020, 05:49 PM | #197 | |
Rep 1,054
Edit: Also, I assume the KWv3 set does not have the black rubber piece, just underneath the adjuster, correct? Last edited by csbear; 08-02-2020 at 08:12 PM.. |
08-03-2020, 03:12 AM | #198 | |
844
Rep 1,962
