BMW M2 Forum > BMW M2 Discussions > Sport auto M2 1:12.2 @ Hockenheim
      04-18-2016, 08:02 PM   #89
zenmaster
Drives: '17 M2
Originally Posted by stylinexpat View Post
The new M2 seems good on a smaller track but on a track like the Nurburgring the numbers are not all that great (sort of like the 1/4 mile traps speed numbers).
What would be a satisfactory M2 Nurburgring time for you?
      04-18-2016, 08:05 PM   #90
gthal
gthal's Avatar
1904
Drives: 2018 340i xDrive
Originally Posted by rich8566 View Post
Why am I hearing the squeal of non-OEM track pads? If that's the case this time is not a legitimate time for what is supposedly an OEM car.
M performance pads.
For a car that goes to journalists and is flogged for hours on end, they are somewhat needed. Stock pads would be toast in no time and they would be swapping pads every few hours. Besides, no one in their right mind takes any M car (other than one with ceramics) to the track on street pads. They are street pads for a reason.
It doesn't invalidate anything IMO as it is simply a few hundred dollars for a BMW M performance item... no different than opting for ceramic brakes on an M3/4. If you took the M2 out on street pads for a 15 minute lapping session, the street pads would be fine but they cannot withstand hours of track abuse... no street pad can on any car. It doesn't change the capability of the brakes but simply the heat resistance of the pad.
Bet you EVERY 'Ring time is with some sort of track brake pad if for no other reason than safety of the driver to avoid a very dangerous potential scenario.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery
2016 M2 | Long Beach Blue | 6MT
2015 M4 | Austin Yellow | DCT
2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3
      04-18-2016, 08:07 PM   #91
rich8566
rich8566's Avatar
Drives: M2 + Z-4
2014 BMW M235i  [0.00]
M performance pads.
It doesn't invalidate anything IMO.
I agree, it does not invalidate the time, but the time cannot be compared to an OEM M2.
      04-18-2016, 08:12 PM   #92
gthal
gthal's Avatar
1904
Don't know if I completely agree...
Take an M2 from the showroom out to Hockenheim, run a warm up lap and then a hot lap. An OEM pad would handle that without issue and without meaningful fade. The lap time would likely be similar, if not identical. It is the endurance of the pad over multiple and sustained laps that is the problem. The pad isn't, IMO, defining the ability of the car for a lap but the ability to sustain that over many laps.
Second, no one takes any M car to the track with street pads if they have any level of ability. Therefore, every M car (and every track car) is on a similar footing at the track as they all have track pads once you pass the level of a novice driver.
      04-18-2016, 08:26 PM   #93
zenmaster
Drives: '17 M2
Yep. Now watch what happens when the production version of the Civic Type R actually runs the Nurburgring. The difference won't come down to the brake pads.
      04-18-2016, 08:39 PM   #94
FogCityM3
FogCityM3's Avatar
499
Drives: M3 (E90) & Porsche GT3 RS
Yes, it has been documented that BMW performance pads (available at the time) are used in all of the Nurburgring/Hockenheim/Instrumented testing by SportAuto. It is apples-to-apples, though improvements in brake compounds can occur over the years, but think anything from mid 2000s on is pretty comparable.
M performance pads.
      04-18-2016, 11:00 PM   #95
Robin_NL
S0THPAW
Robin_NL's Avatar
8717
Drives: HS M2 Competition
Those are OEM M Perf track brakepads and as already stated above apples to apples etc etc.
I'm using Pagid Yellow square setup atm and Castrol SRF fluid. If you're only one tiny bit into tracking your car you know that's the first thing to do...
Cheers
Robin
      04-19-2016, 12:15 AM   #96
IrishCoffee
IrishCoffee's Avatar
79
Drives: 2020 M4
Cheers
Robin
Pagid yellows sound like a dump truck braking! Love it.
Nothing like pulling into a gas station with Pagids in and everyone looks at you like your car is about to explode from all the noise. They sure do last and brake hard though. They are the best that I've found.
      04-20-2016, 02:12 PM   #97
bradleyland
TIM YOYO
Drives: 2013 M3
Apart from the budget(In my country an M2 is from € 80k and a Cayman S from € 90k to start with so that shouldn't be the biggest problem) , the M2 is 0.6s faster than a 981 Cayman S @ Hockenheim Short, and because of FR layout and more torque it can and will be more fun for many(like me), but I get what you're saying. I also think an M2 is 100 times more eyecandy than any Cayman except for GT4, sorry....
http://fastestlaps.com/tracks/hockenheim-short
Cheers
Robin
I can't wait to drive an M2, because I'll be evaluating it against the Cayman S. My experience has been that while the baby Porsches aren't the fastest cars around a course, their handling is incredible. The other thing about Porsches is that they stand up to track abuse incredibly well. I know a few of the SoFL guys with McLarens and Ferraris, and they all end up buying a 911 or Cayman for track duty because they're so much cheaper to run. Fewer breakages and lower maintenance costs.
That's where I'm hoping the M2 can slot in. It's quite a bit less expensive than the Cayman S, and (historically) BMW's tend to do pretty well at maintenance costs and low failure rate under track duty, provided you do the prep work. For the price difference between an M2 and a new Cayman S, you could do an entire brake upgrade, heh. The big question in my mind is cooling and turbocharger durability.
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech
Past: 2013 ///M3 - Interlagos Blue Black M-DCT
Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport
      04-24-2016, 03:07 PM   #98
bradleyland
TIM YOYO
Drives: 2013 M3
Dropped "track soft" tires on the 1M in ProjectCARS and pulled off a 1:12.067 Nevermind my little off coming in to T2 lol. I love watching lap videos, then loading up pCARS to give it a try myself. Obviously there's a big difference between a video game and real life, but it's still a lot of fun. You can see how the racing line is similar. You can also see the celebratory burnout at the end is similar
Also, you'll notice that I'm cutting the track after Querspange. That's because this game doesn't have the Sport Auto short layout. It only has the short with chicane, so I just have to cut the track.
https://dl.dropboxusercontent.com/u/...1M-0112067.mp4
      04-24-2016, 03:11 PM   #99
zenmaster
Drives: '17 M2
lap 8 was all over the place.
      04-24-2016, 05:39 PM   #100
bradleyland
TIM YOYO
Drives: 2013 M3
Driver lost his mind
