05-18-2019, 12:09 PM | #23 |
Luxury at the redline :)
9105
Rep 7,563
Why is everyone downplaying the BBK; wouldn't bigger brake calipers equal better performance, which is more resilient than the blue brakes, which from what I understand; changes color after heavy usage..
This seem like an fix/improvement even if it means compromising to '19s only.. I love the silver BBK, it reminds me of 135i's silver Brembo calipers, which was a first for BMW and outshined the higher tier 335i at the time, on repeated usage. Every vehicle has some sort of compromise but I could live with the BBKs shortcomings if it means an improvement over the prior offering. 'Small car, larger brakes' is an awesome package and it makes those caliper look so dominant |
05-19-2019, 03:09 AM | #25 | |
Rep 7,295
05-19-2019, 12:34 PM | #26 |
Rear Admiral
1485
Rep 1,706
Drives: Bavarian Milk Wagon
OP is outside US where, in some place like EU, the larger brakes aren't standard and cost extra. Standard here are the brakes from OG M2. But yes, the larger brakes look great and I "checked that box".
Found out after order submitted that the 18" 513 wheels I kept from the F80 won't work as winter wheels on the new brakes..first world problem. |
05-19-2019, 03:28 PM | #27 |
Rep 13,093
M2 CS: M Sport Brake standard (2NH) standard, M Carbon Ceramic Brakes optional.
///M is art ↔ Artemis
05-20-2019, 02:18 AM | #28 |
Rep 3,069
I got the blue brakes. They are more than you will ever need on any public road and as a bonus the blue looks much nicer with HS, BSM or AW. Not so much with LBB or SO.
For occasional supersprints upgrading pads and fluid will be more than enough with the standard wheels & tyres. If your track days involve a change of wheels & serious tyres then get a real set of brakes like AP, Harrop etc, there's no comparison. |
Robin_NL8717.00 |
05-20-2019, 05:28 AM | #29 |
Rep 744
So much speculation from ppl who dont track...
1) Braking performance is limited by your tires and brakes have very little influence on the achieved stoping distance. 2) In theory the silver brakes "should" work better on track as they have more thermal mass than the blue brakes, however this only works to a point. Once they are "heat saturated" how well the heat is carried away becomes more important than their size. I can imagine this is harder with the silver brakes since there is less space around them allowing air to flow between the wheel and brake. I think this is why guys that track their M2C and have tracked an M2 say the 2NH option is not worth it. 3) Both the blue and silver brakes are street designs with dust seals that will burn up under repeated heavy use. 4) The M4 CS which is heavier and more powerful comes with the same blue brakes so its not like they are crap. In conclusion if you dont track or ride the brakes down a mountain the blue brakes will be more than enough for you. If you track a little then both are about equivalent with parts for the blue brakes being cheaper as well as pad changes being faster and having the ability to fit cheaper 18" wheels. So really it boils down to budget and looks. |
05-20-2019, 06:12 AM | #30 |
Rep 1,477
Is there anyone in the world who likes blue calipers? Really? On a BMW I mean, not on a Focus RS or a Honda Civic or a Subaru I think blue calipers don't match with any color.
05-20-2019, 11:05 AM | #31 | |
Rep 335
“The CS comes as standard with cast discs with four-piston calipers at the front, two at the rear and put simply they are not a match for the car’s performance. The biggest criticism is it takes very few committed stops for the pedal travel to lengthen, and while retardation doesn’t suffer at a similar rate, it removes the precision required to get the CS slowed and turned in. The optional ceramic brakes solve all of these problems.” Perhaps the 6 and 4 piston Silver brakes with more thermal mass, would have been a match for the car’s performance in the review. Maybe this is why the M2 Competition comes with the Silver brakes, as an option, or standard in the States. |
05-22-2019, 02:50 AM | #32 | |
Rep 744
PPL were saying the same thing about the silver brakes at the intro in Ascari.... |
05-23-2019, 08:40 AM | #33 |
Rep 538
If you dont have to pay for truck brakes why would you? Get some AP's or Stoptech... You can fit 18's and the car will have much better corner weight.
I almost sold my truck brakes but decided to keep them to push them hard and see what they can do. Yes the paint at the bottom is completely destroyed from rocks and my 788's have giant gouges in them from the rocks as well. The Apex EC7's should eliminate that issue and allow proper tire size. In other words I'm making due as a victim of circumstance, You shouldn't if you have other options from the start.. Last edited by Proctor750; 05-23-2019 at 12:13 PM.. |
05-23-2019, 10:36 AM | #34 |
Rep 2,956
I much prefer the blue to the generic red you see on most cars sporting brembos or upgraded brakes. Subaru has typically used gold or black (they do offer a hideous yellow on late models) on the STI, EVO's were always red, CTR uses red, and the Focus RS is the only car I can think of using blue off the top of my head so I really don't associate the blue brakes with anything other than BMW.
05-28-2019, 05:09 PM | #35 | |
Rep 660
All I can say is that upgrading to race fluid and track pads made a huge different with the blue brakes. Very little fade all the way to the last session of the day. |
05-28-2019, 05:56 PM | #36 |
Rep 650
+1 for regular brakes. With the correct pads and fluids they will satisfy 95% of the people based on performance....how they look is a separate issue.
