05-06-2019, 02:12 PM | #89 |
Rep 24
A driving test where the drivers are blinded to the model type would be the best way to find out if there were differences or not.
Sedan_Clan25022.00 Prazision55.50 |
05-06-2019, 02:17 PM | #90 |
“One finds limits by pushing them”
123
Rep 529
I’ve own the OG M2 for 2 years and M2C for 6 months.
Everything people are saying about the differences are true. These differences are there even though part numbers are the same, suspension/steering wheel for example. My friend who still has the OG M2 confirms the changes as well, back to back driven.... The struggle is real. |
4
05-06-2019, 02:26 PM | #93 |
4143
Rep 6,926
My local dealer still has two 2018's. The main difference you can feel between the two chassis wise, is the front end. The Competition feels stiffer up front, turn in is more direct and immediate. That is from the combo of the carbon strut brace and bulkhead bracing, along with the retuning of the electric steering. I guess there is a reason BMW fitted the M235iRacing with extra bracing up front.
Project_F871231.00 |
05-06-2019, 02:27 PM | #94 |
4143
Rep 6,926
Germanauto9701.00 |
05-06-2019, 02:42 PM | #95 | |
4143
Rep 6,926
Carbon brace and aluminum bulkhead bracing in the M235iRacing. Strutbrace/bracing out of the car. |
ChrisK4449.00 |
05-06-2019, 02:50 PM | #96 | |
Everyday I'm shuffling
449
Rep 1,098
Say you go to the BMW dealer parts counter and order an OEM replacement part for your M2's suspension, how will they know to give you the "old" or "new" suspension part if they have the same part #? Last edited by MPBK; 05-06-2019 at 07:33 PM.. |
chris7197334.00 |
05-06-2019, 03:21 PM | #97 |
Rep 27
New always better?
I had a m2 2015 ( had an accident and sold) got a new one by 2016 , decat and stage 2 .
I got this new m2c i can say is different in every way. Its feel not upgraded but new. And what i like the most is it feels dangerous . Stage 1 will deliver 500 hp which i expect give me more adrenalin . The M2c is what m2 should be at 2015 . Obviously bmw will killed the gigant flat shoe horrible m4 but why not. Large coupes are killing the feeling. . Even Porsche has killed the cayman and the 911 is getting bigger . I keep my 437m ferric greys from my old m2 .
Dante Felipe Bracale
clee1982797.50 |
05-06-2019, 03:24 PM | #98 | |
Rep 1,459
cptobvious2531.50 natmad667.00 |
05-06-2019, 03:28 PM | #99 |
Rep 1,058
For what it is worth, I've driven both at the at the PDC and felt that the M2C (at different driving schools) was significantly improved in engine and handling performance. The M2C also looks better to me inside and out to me. During the last M school, I heard two different instructors talk about how much improved the M2C was over the original. I think it is very noticeable. I really wasn't a fan of the original M2 engine, but the S55 is great. I will say that both are much more tail happy than an M3/4. Whether that is good or bad is in the mind of the driver. It is very playful and seemingly controllable, but I'm not an expert. I don't think you have to be an expert though to feel the differences. The M2C is the real deal.
05-06-2019, 05:14 PM | #101 |
Rep 308
I can't believe I'm going to wade into this...
Up front, I don't work for BMW so no inside info here. I have been an engineer for more decades than I care to admit though, and "part improvement" roll-ins on the same part number happen All. The. Time. Now I'll admit, if, theoretically, they intended that all M2Cs got the up-rev'd parts (whatever they may be), keeping the same part number wouldn't be the preferred method since they'd want to make sure old stock was depleted in the factory prior to starting build of the 2019. But, I see ECNs all the time that substitute compatible parts with new and improved specs under the same number Quietly closing the door and running away |
05-06-2019, 05:44 PM | #102 |
Rep 137
I can confirm @BlkSVT statement through my own experience. Most "manufacturers" we know are actually just assemblers. They don't manufacture all the components but rather purchase lot(s) of them in bulk from the component's manufacturer. Other manufactures can bid to offer the same spec'd part at a lower cost or failure rate and bam your AC Delco shocks are now made by Mitsubishi.
In some cases the aftermarket parts you'd buy at a premium are made by the very same manufacturer that sells parts in bulk to the assembly plant just with better aesthetics and retail packaging. |
05-06-2019, 06:01 PM | #103 |
581
Rep 1,170
Drives: M2 Competition, E30 M3 DTM
I have owned 2016 m2 and have now M2C
I some area s like mentioned above the m2c is better. But the weight is more also and i can feel it on track. I rather have the m2 with less weight. M2c is about 1635 kg with a full tank. My x1 2.5i xdrive family car is lighter! That is insane! If i knew the m2c was that heavy i would had bought one. |
Ian ///M491.00 |
05-06-2019, 06:37 PM | #104 | |
16300
Rep 8,394
That's the first thing that came to mind regarding the difference people are feeling.
05-06-2019, 07:21 PM | #107 |
16300
Rep 8,394
Interesting.
And the size remained the same.
05-06-2019, 07:30 PM | #108 | |
449
Rep 1,098
I don't see why so much discussion about this topic. |
05-06-2019, 07:31 PM | #109 |
BMW Driver
57
Rep 66
The tires on both the 2017 and 2019 were Michelin PSS. I ran 32psi front and 30psi rear (when hot) at Laguna Seca on both cars. The M2C had much better times through out each session (5-6 laps).
05-06-2019, 07:36 PM | #110 |
16300
Rep 8,394
The one component the M2C has vs the OGM2 is the front Carbon Strut brace.
Maybe it effectively keeps the car more planted.
