M2 Technical Topics > Track / Autocross / Dragstrip > Track Wheels and TPMS
      01-30-2020, 03:40 PM   #1
Zoomzoommo
Zoomzoommo's Avatar
53
Drives: 2020 M2C
Have a set of Apex wheels on order, to be used during track weekends. Wasn’t planning to use TPMS sensors, as I keep a close eye on pressures manually. Plus, a few threads mentioned the M2C restricts performance at lower tire pressures, unless a TPMS reset is performed.
Does anyone have first hand experience running track wheels w/o TPMS sensors? Want to insure performance isn’t restricted by going this route.
      01-31-2020, 11:23 AM   #2
M2joey
M2joey's Avatar
300
Drives: M2, 335is, X5 M50i
Yes, if you get a low pressure warning you cannot disable DSC. Or if you are on the track with DSC off and the pressure is "found" to be too low, you will be kicked into Comfort mode. I cannot say for sure although suspect you will need the TPMS for this reason.
Former BMW CCA National Capital Chapter HPDE program Chairman 2021-2022
      01-31-2020, 12:06 PM   #3
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro SS 1LE
Agreed. Without TPMS the system will assume you are low and force you into comfort with all nannies on.
Just get extra sensors and rest your TPMS with lower pressures.
      01-31-2020, 01:41 PM   #4
Insane_Dawe
Drives: 18 White ZCP M3
Doesn't iDrive will give you a warning that TPMS is not detected and by clicking okay, you are accepting any and all risk?
I thought I read that.
      01-31-2020, 04:00 PM   #5
Zoomzoommo
Zoomzoommo's Avatar
53
Drives: 2020 M2C
This seems like the safest route. Now to find reasonably priced sensors...
      02-01-2020, 09:40 AM   #6
monochrom3
Former P-Car Owner
Drives: 2018 M2 (TBD)
I've been please with sensors from tpms dot com
2018 BMW M2, Orange wrapped!, Journal
1999 BMW M3, Cosmos Black, S54 swapped
5.M0NSTER3353.50
      02-01-2020, 11:56 AM   #7
5.M0NSTER
5.M0NSTER's Avatar
The other advantage of doing this is being able to monitor tire temperatures in real life. I know this is just tire air temp and not thread temp, but it's still enough to warn you when the tires overheat and your grip is about to go.
2017 BMW M2 German Spec
6MT, Driver's Package
--> SOLD
2018 Camaro SS 1LE. Because race car!
"Redline a day keeps the mechanics away"
mcvaughan702.00
      02-07-2020, 12:12 PM   #8
Noel911
Drives: 2017 M2 & 2019 Golf R (Daily)
I do not use tire sensors on my track wheels. While the tire light is on in the dash board, this creates zero issues with the car and selecting modes or completely turning off traction control. This is helpful since I like 28psi hot pressures which sometimes means I start in the low 20s. I just use an old school gauge to measure temps.
Hope that helps.
---2017 White M2 - Zero Option- 6-Speed Manual---
Appreciate 4
      02-07-2020, 03:35 PM   #9
Malakas
Drives: 2020 M2c
The TPMS gave me issues.... Even "resetting it" with low pressures it didn't like it. I was starting with 27psi or so cold... Will be pulling the sensors off the wheels
      02-07-2020, 07:52 PM   #10
mcvaughan
mcvaughan's Avatar
Drives: F87 Competition
Interestingly, my TMPS was giving me no readings yesterday at the track.
Matt
      02-07-2020, 08:30 PM   #11
ZM2
Drives: 2017 LBB M2
Did you change wheel sets at the track and both your street and track sets have sensors?
      02-07-2020, 11:43 PM   #12
Malakas
Drives: 2020 M2c
Where did you get out to yesterday?? MSR?
      02-08-2020, 08:05 AM   #13
mcvaughan
mcvaughan's Avatar
MSRH. S550 Mustang club track day.
Matt
      02-08-2020, 08:08 AM   #14
mcvaughan
mcvaughan's Avatar
Drove down on my track set. And yes, they both have TPMS. Calibrated when I left, but no readings ever showed.
Matt
      02-08-2020, 08:18 AM   #15
mcvaughan
mcvaughan's Avatar
Hope that helps.
28 hot? Seems very low. What tire?
Matt
      02-08-2020, 08:22 AM   #16
ZM2
Drives: 2017 LBB M2
This has happened to me once before of the 50 or so times I’ve done similar. It cleared up after I switched back to my street set and then back to my track set.
I don’t really know the reason or have a fix, but I make sure the wheel set I’m taking off is a decent distance from the car before I put the other on and then drive away a little bit to do the reset.
This may or may not have something to do with it, but I haven’t had the issue since with all the same wheels and sensors involved.
mcvaughan702.00
      02-08-2020, 09:00 AM   #17
Noel911
I'm using Bridgestone RE71s. I find they wear more evenly across the tread at those lower pressures. With these heavy cars you need to manage tires more with driving style though.
BTW, I'm running 265 square so I rotate front to back and left to right too.
      02-10-2020, 09:30 AM   #18
M2joey
M2joey's Avatar
300
Hope that helps.
I think you are the first person in history to be able to completely turn off DSC with an active low temp warning light. Many many M2 owners have been looking for a way to "code out", etc. the low tire temp warning. First time I have read of someone being able to achieve this by removing the TPMS, hmm.
CrashFL136.50
      02-10-2020, 11:14 PM   #19
Anthony1s
756
Drives: 2018 Mineral Grey M2
https://machtschnell.com/tpmsrdc-emulation-module.html
For those that have multiple tire sets for the track, this is simply not practical. Our TPMS/RDC Emulation Module installs in less than 15 minutes and will fully emulate a full-pressure TPMS signal when activated. Module can be activated/deactivated by lifting up on the driver’s side window switch for +5 seconds with the key off.
Wonder if anyone has seen/tried this before? I'm finding a ton of cool stuff I never knew existed on their site.
EDIT: nvm. just seen M2 is not supported. Even thought it's listed in their M2 section.
      02-11-2020, 08:45 AM   #20
Twt
Twt's Avatar
633
Drives: 2017 M2
I think this has been covered in other threads, but I had 4 sets of wheels and various tires. Sometimes I had to start at 22 pounds and the system would go limp. I tried all the “tricks” to reset on track but a real PITA. Early in my ownership I pulled the sensors and did not install TPMS on any of my track wheels. I now swap wheels, set pressures and run with DSC off with no issues. Sometimes the system will still recognize low air pressure, probably the euro default if one tire differs from the others, I guess. I did have some coding done as well.
      02-11-2020, 11:00 AM   #21
SEAT TIME RULES
SEAT TIME RULES's Avatar
1095
2020 BMW M2C  [5.00]
I have a EM into them asking this question and they confirmed that the F87 is not supported by it yet..
2004 Mazda Rev It Up Finalist
2002-Present HPDE Instructor
      02-11-2020, 06:49 PM   #22
Zoomzoommo
Zoomzoommo's Avatar
53
Drives: 2020 M2C
Thanks, all, for the responses. I ordered the sensors from tpmsdotcom (as suggested), but am torn on whether to have them mounted on the EC-7’s. From what I can surmise on this (and other) threads:
1. Not using TPMS sensors on an M2C will allow the use of MDM and DSC off, but the car defaults to comfort mode...which means less steering effort (vs sport or +) and a less touchy throttle. Correct?
2. Using TPMS means I have to worry about starting pressures below 28. Attention to tpms resets. Possibly pitting after a lap to reset. The possibility of limp mode while on track. Correct? On my previous cars used at the track (911’s, GT4, Boxster GTS), 28 cold was always my sweet starting point. But this car is heavier. And the engine is in front!
Given the above, I think I’m gonna hold off on the sensors.
