M2 Technical Topics > Suspension | Brakes | Chassis > AST 5100 fitment issue with TE37 (18x9.5)
      03-22-2020, 03:19 PM   #1
pooyab
pooyab's Avatar
330
Drives: 2011 BMW M3 2020 BMW M5C
2011 BMW M3  [0.00]
Just installed AST 5100 on my friends car and he's having clearance problems. He has 18x9.5 +38 TE37 with a 12.5mm spacer and 265/35 square. According to APEX wheel fitment guide an 18x9.5 +28 setup should work so I'm wondering why this isn't.
I've told him to swap to 255 tires up front and if it's still close, move up to a 15mm spacer. But I'm just wonder why it's not working when according to apex's site, it should.
Interlagos Blue/Speed Cloth | BayOptiks DTM Headlights | Alpine Stage 2 | KW Clubsport | Resonated X-Pipe | Eisenmann Race | StopTech BBK | TE37SL | YFCM CF Driveshaft | Hotchkis F/R Sways | F/R Endlinks | Turner Control Arms and Front Tension Bushings | Powerflex Diff Bushings | Turner Solid Subframe Bushings | MS Underdrive Pulley and Intake | Alpine DCT Tune | Karbonius Intake | Carbon Roof (TBD)
      03-25-2020, 03:57 AM   #2
Megator
Megator's Avatar
518
Drives: M2 Competition
I think what you are missing from the Apex guide is this sentence "5mm front spacers or larger may be required with certain aftermarket suspensions, see below."
38-12.5= ET 25.5 which is still off of ET23 (28-5) they recommend for aftermarket suspensions with 255 tires. Add the 5mm of extra tire of a 265 and your friend would need a minimum of 7.5mm extra worth of spacer for a 20mm total spacer.
Not sure why but many coilovers have the perch right where the tire goes (instead of above as OEM) which limits wheel/tire width inwards.
Another thing to try are narrower tires. OEM 265s are actually 245mm at the tread.
BTW I have 265s up front on OEM susp. and on 18*9 M513 wheels.
Originally Posted by M2 GT View Post
how much camber?
Camber wont help with strut clearance. The geometry of the strut to the wheel does not change with camber. Camber will only help with outer fender clearance.
MR RIZK757.50
pooyab330.00
      03-25-2020, 09:21 AM   #3
M2C AW
Drives: 2019 M2C Alpine White
Try a shorter coil and ditch the helper spring ?
      03-28-2020, 05:05 AM   #4
pooyab
pooyab's Avatar
330
2011 BMW M3  [0.00]
how much camber?
You are right. Reading it again today I missed the 5mm "or greater" part. I had him move to an 18mm spacer clearance is close but it's not hitting anymore I think (3-5mm range), considering moving to a 20 and calling it a day.
I've thought about removing the helper spring. Might just do it next time I have the car apart.
      03-30-2020, 04:32 AM   #5
Megator
Megator's Avatar
518
If its to the wheel then I think 3-5mm should suffice. The wheel should not flex that much.
Removing the helper spring will impact the space available for the tire which can flex and contact.
The only solution is spacers or diff wheels.
