M2 Technical Topics > Track / Autocross / Dragstrip > Fluid overfill for DCT ?
      03-21-2020, 02:10 PM   #1
M2C AW
Drives: 2019 M2C Alpine White
Any guidance out there for fluid levels for a DCT ?
I’ve confirmed my fluid level up to the side fill port on the transmission, but curious if anyone overfills. Anyone ?
      03-25-2020, 04:44 AM   #2
Megator
Megator's Avatar
518
Drives: M2 Competition
Originally Posted by M2MGM View Post
Any guidance out there for fluid levels for a DCT seeing track duty ?
I’ve confirmed my fluid level up to the side fill port on the transmission, but curious if anyone overfills for heavy track use ? Anyone ?
Euhm why did you even check? The oldest M2 is like 3-4 years old and should not be leaking from the trans.
Also you may have done it wrong as checking the fill level on the DCT is not done as on a manual transmission. The trans has to be operated to move oil to certain spots it drains out of when the car is not running.
More details here:https://www.newtis.info/tisv2/a/en/f...nce/1VnXljlF6b
Do not overfill, you will damage the trans. The DCT has a huge oil cooler and BMW runs it stock in race cars so I think your good with the stock setup.
