02-29-2020, 12:07 PM | #1 |
756
Rep 2,149
Stock Seatbelt Tension Trick
I heard of this trick recently where you move your seat back all the way, then pull on the belt hard to get it to lock, then move your seat up into the normal driving position. Because the belt is locked, you can put extra tension on the seat belt by moving the seat forward, which straps you in tighter.
Has anyone tried this? And downside to doing this or safety concerns? I just did it while parked and it does work to hold me in place tightly. Haven't driven like that yet, because I just remembered to try it as I got home. |
03-02-2020, 03:59 PM | #4 |
Rep 126
You can actually make a second memory setting for the seat (a pre-tension setting), then after the belt locks hit the other memory button and it's the same belt tightness and position every time.
---2017 White M2 - Zero Option- 6-Speed Manual---
Killed by Death12423.50 |
03-03-2020, 07:50 AM | #5 |
Rep 1,917
Submarining is a danger in an impact. Admittedly I've used this at the track in the past. Also the neck could be at risk, unless using a HANS device.
Matt
03-10-2020, 10:34 AM | #6 | |
Dirt Junkie
116
Rep 76
Drives: 2020 BMW M2 Competition
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming 'WOW-What a Ride!'" - Anonymous
03-12-2020, 06:55 PM | #7 | ||
Rep 684
