M2 Technical Topics > Track / Autocross / Dragstrip > Laguna Seca
      02-28-2020, 03:21 PM   #1
Bill in Marin
Drives: 2020 M2 Comp, 1974 Alfa GTV
Laguna Seca
I’m out here at Laguna for the HOD event. It’s my first track outing at LS and my first track outing in the M2C. I’ve had 3 sessions so far, plan to hit a 4th and bail. The brakes get squishy fast. Now I get all the negative reviews. Pads or fluid, the M2C needs em! They worked fine but feel is terrible if you’re pushing the pace. With the Carbahn tune, I can chase a new GT3 down in the straights, which is wild. I filled a whole tank with 101, so it may be running especially strong. The Cup 2’s are awesome, although I overheated them a bit in the second session and they started to get sloppy. Lastly, I’ve still got it. I’ve just recently gotten back into track driving after racing and tracking a ton over 15 years ago. The feel is coming back, and I’m running near the front. Feels great.
The M2C is a great track car. It’s also the most popular option out here after GT3’s. I’ve counted 5 M2’s and 3 M2C’s.
Appreciate 5
lax01792.50
M2guru383.50
mcvaughan704.00
bentom2335.50
atc556.50
      02-28-2020, 03:50 PM   #2
O Haiii
Drives: Toyota Tercel
Nice pic! Did you have your crank hub replaced? Do you plan on in the future especially with a tune?
      02-29-2020, 12:45 AM   #3
4thM3
4thM3's Avatar
Drives: 2020 M2 Comp. Alp. White
Curious about what tire pressures you ran on your Cup 2s. Just got a set but haven’t mounted them yet.
Thx.
      02-29-2020, 09:35 AM   #4
pal
pal's Avatar
433
Drives: Z4 M Coupe
Were you running any data / telemetry? Curious what times you're running and your speed on the front straight and at the top of the hill before braking for the 'screw.
As for squishy brakes, I'd say you cooked the fluid. Castrol SRF is pretty solid and I'd do a full flush with that for the next track outing. Also, sounds like you are a quick driver so brake pads may also be in order. Pagid Yellow (RS29) is a popular track pad that works well on the street as well (except for the noise).
      02-29-2020, 09:59 AM   #5
Bill in Marin
I only ran Track Addict on my last of 4 sessions with a passenger. Best was a 1:47. 1:46 if I piece together the best section times. Not quite as fast as I thought I was, but I’m happy with it for first time back. Top speed on the front straight was 112, but the front straight sequence was one area that I was definitely giving up some time, easing off the throttle over the crest. I need a few more sessions to fully commit over the crest. Best speed up the corkscrew after turn 6 was 108 mph. What’s good for an experienced driver? I see that 1:40’s-1:42’s on the lap time post. I definitely have a few sections that I was scrubbing seconds. The corkscrew is another that I need more experience with. I will say that the inconsistency in brake feel had me braking softer and earlier on the big braking zones.
I started with 28 psi and they were at 35-37 psi after the first session.
Pads + Fluid are top of the list for the next outing. I also totally blasted the rocker panels. I need to respray and PPF the rear edge of the rockers. I’m sooo happy I wrapped the front of the car.
      02-29-2020, 11:01 AM   #6
kpaso
Drives: BMW
Pads + Fluid are top of the list for the next outing. I also totally blasted the rocker panels. I need to respect and PPF the rear edge of the rockers. I’m sooo happy I wrapped the front of the car.
1:46/7 isn't bad at all for your first time back in that long. Especially with you lifting so much on the front straight. Inconsistent brakes definitely do mess with your head and times.
I would say an experienced driver at your power level might be closer to 1:42 for sure if everything else is stock. The stock brakes won't last more than 1-2 laps at that pace though.
      03-01-2020, 11:42 AM   #7
2020M2Competition
2020M2Competition's Avatar
429
Drives: Yes
As noted, pads and fluid will make a huge difference
How do you like the Carbahn tune?
I'm starting to get tired of higher HP cars that slow me down in the corners and then won't let me pass on the straights
      03-01-2020, 11:46 AM   #8
Bill in Marin
I just watched a 1:37 M2 lap video, and the driver topped out at 128 on the front straight, so I’ve definitely got serious seconds I gave up there. I was in a point-by group, and the front straight was usually pretty busy. His back straight speeds were much closer, but I see where I can trim 4-5 seconds. Then it gets tough.
      03-01-2020, 12:36 PM   #9
4thM3
4thM3's Avatar
Bill in Marin.
I was supposed to be at Laguna instructing but unfortunately a pinched nerve in my back has rendered my right leg painfully useless so had to bail. Would have enjoyed meeting you and getting the cars on track and comparing notes.
Maybe we can connect at one of the north bay cars and coffee.
Have a great event
      03-01-2020, 08:40 PM   #10
Bill in Marin
I love the tune. It does feel under-tired now. I got squirrelly just today merging onto the highway, burying the throttle at ~45-50. It did feel good at the track to just tear away from 997's out of the corners.
      03-01-2020, 09:51 PM   #11
kpaso
Drives: BMW
What other mods do you have?
If you have a video of your lap, feel free to post it as well. That 1:37 video of Alex is quick but he was also on slicks if I remember correctly.
      03-04-2020, 11:59 PM   #12
Bill in Marin
I haven't yet had time to even watch the video, much less parse it out. I'll see if I can edit it down this weekend.
I just started another thread, I am ordering track wheels + tires, as well as track pads + fluid. I'm considering slicks.
My next trackday is looking like Sonoma on 4/13.
      04-22-2020, 09:52 AM   #13
Saanen
Saanen's Avatar
Drives: M2 BSM 6SPD, VW e Golf (DD)
Aleks's shop installed my Ohlins, SS brake lines and corner balanced my car. At that time he was running AP racing brakes and a well tuned three-way adjustable suspension....and I believe RE71 tires...stock N55 engine. At the time he was all about the braking being more important than increased power for our car's track performance.
2007 BMW 335i (sold); 1997 BMW E36 M3 (sold);
1988 BMW 535is (sold); 1984 BMW 323i Alpina (can't believe I sold),1969 BMW 2002 Ti (spec'd as Ti; and yes I sold this too...).
