M2 Technical Topics > Suspension | Brakes | Chassis > REAR track pads / MIXED pad set-ups
      01-08-2020, 06:46 AM   #1
Nathan-M2
Drives: BMW M2 (n55)
Hi guys,
I will be tracking my car this year and wondered if you guys could help with the following?
If running dedicated front track pads (for example; RS29’s) could you still run the rear OEM pads and be OK? (bearing in mind rear braking accounts for approx. 25% of your total braking force).
If not, would running a fast road pad in the rear OK instead? Such as Ferodo 2500 or EBC yellow?
Keen to know what experience people have with mixed pad set ups please.
Thank you 😊
      01-08-2020, 07:33 AM   #2
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
I wouldn't run street pads on the track, even if they are just on the rear. The potential for them to quickly wear down and damage your rotors is still a possibility.
I personally run Ferodo DS1.11's in the front, and DS2500's in the rear on the track. This provides a pretty even brake feel and wear appears to be about the same.
As a bonus, you can run the DS2500's on the street as they aren't very noisy, and they are the same compound as the 1.11's, so theres no need to rebed the pads when you swap them out if you run the DS2500's on the street (all 4 corners).
The DS2500's however likely arent enough brake to run in the front for track day, hence the reason for the 1.11's.
Hope this helps!
PLF693766.00
Kankles1484.50
      01-08-2020, 07:42 AM   #3
Nathan-M2
Thanks for your advice and yes, I've seen a huge number of threads saying DS2500's simply aren't good enough upfront.
I would be swapping out the front track-pads post-session, so would have to put the standard rears back in too.
      01-08-2020, 08:16 AM   #4
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Nathan,
On my F20 m135i I ran mixed oem pads as follows:-
F2x MPBBK pads at the back and F8x M4 sport pads upfront
Above worked a treat for DD and occasional TD's. Fronts would squeal a tad after too much light duty but a swift beasting soon shut them up again.
BP
Current '22 X3M LCI..
      01-08-2020, 08:18 AM   #5
mcvaughan
mcvaughan's Avatar
Drives: F87 Competition
Shouldn't be a problem. I run 1.11 up front and 2500 rear. Fronts do most of the work, provided you're disabling DSC.
Matt
      01-08-2020, 08:57 AM   #6
Nathan-M2
Thank you, this is likely what I'm planning.
      01-08-2020, 09:29 AM   #7
PLF69
PLF69's Avatar
3766
Drives: 2023 M3
+1 I run the same setup
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp
Daily: 2023 X5 45e
Daily/Family: 2021 Atlas Cross Sport 3.6
      01-08-2020, 09:44 AM   #8
mcvaughan
mcvaughan's Avatar
And it's more convenient because you're only swapping on one axle.
Matt
      01-08-2020, 10:28 AM   #9
Nathan-M2
So you guys leave the 2500's in the rear but switch back to OEM pads on the front?
I thought you'd swap front and rear's both back to OEM after track, no?
      01-08-2020, 10:38 AM   #10
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Run 2500's on all 4 corners instead of OEMs for the street. The pad compound is similar enough to the DS1.11's that no bedding is required between track/street.
      01-08-2020, 10:54 AM   #11
Nathan-M2
Ah right, I understand what you're saying.
Thanks.
      01-08-2020, 11:21 PM   #12
Zoomzoommo
Zoomzoommo's Avatar
53
Drives: 2020 M2C
Suggestions for vendors on the Ferrodos? Use Rennstore for Pagids, but no source for Ferrodo.
      01-09-2020, 02:10 PM   #13
mcgarnigle
Drives: M2C
I use carbotech xp20 front and xp12 rear
They're a noisy on the street. But are completely fade proof with rbf600.
      01-09-2020, 04:35 PM   #14
Daytona_550
Daytona_550's Avatar
Drives: '20 M2C / '08 550i / '23 330i
Got my Ferodos from jritt@essex
      01-09-2020, 06:02 PM   #15
Drop the hammer
Drives: '17 F87 M2 AW, Dct
I also run ds2500’s in 4 corners for daily then Put Ds1.11’s up front for track days. For winter right now I’m running the factory pads, but they are very soft in performance versus ds2500, and I don’t like the feel of them anymore compared to ds2500. I was hoping to just use them up (60 percent left) but in winter on the street there’s very little of wear anyways, So I’ll be just putting the ds2500 in and leaving them in full time except for track days. I didn’t realize how much better ds2500 was until I went back to stock pads.
      01-10-2020, 09:09 AM   #16
Nathan-M2
Hi guys,
I went ahead and ordered DS1.11's front and 2500's rear
      01-10-2020, 07:03 PM   #17
Drop the hammer
Just a word of caution on ds1.11, even though they are really good track pads, but if you try and use the ds1.11 on street they will squeal loudly every single time you apply them, even just lightly touching the pedal. Like garbage truck squeal. I even had guys pull up beside me telling me I should change pads as it sounded as they were down to steel on steel.
      01-13-2020, 11:09 AM   #18
dmf
Drives: M2 Competition DCT/BSM
I was departing Bakersfield towards Buttonwillow for a track day with my 1.11s in and came to a 4-way stop with a truck stopping on the other side. Pretty sure the noise from the 1.11s was louder than his brakes which would explain the odd look on his face.
      01-29-2020, 05:19 AM   #19
Nathan-M2
I will only beusing these pads on track. OEM when off track
      01-29-2020, 06:31 AM   #20
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Make sure you clean brake surfaces - to clear baked on brake dust deposits off - with harder race pads before putting yr stock pads back in.
      01-31-2020, 12:46 PM   #21
dcmac
dcmac's Avatar
442
Drives: '18 LCI M2
No problem.
I run PFC08 up front and Hawk HPS 5.0 in rear.
Switch the PFC’s out for the front Hawk’s once track day is done
      02-03-2020, 01:08 PM   #22
vale007
Drives: e82 1 M coupe
endless cc38 me22 front and rear, works good. no noises. all break shields removed
