06-21-2019, 08:18 AM | #1 |
Rep 379
Remove front dust brake shields?
Was suggested by someone that removing the "dust brake shields" would be better for brake cooling. After a bit more investigation it seems the shield might also protect components from heat. I am only concerned about getting additional cooling if removing the shield achieves this. Cannot imagine the wheels being any less dusty and dirty with the shield on or off after an HPDE weekend. I can certainly understand how the shield could be beneficial at deflecting some heat away from suspension components, etc.
Former BMW CCA National Capital Chapter HPDE program Chairman 2021-2022 |
06-23-2019, 03:33 PM | #2 |
Rep 566
Not all advice is good advice. I wonder if this may be the case. Cooling: the dust shields actually direct air flow to better cool the brake components. That's beside protecting stuff.
06-23-2019, 03:38 PM | #3 |
844
Rep 1,962
Noting that the racing variants appear to use a shield - albeit with mouldings to attach cooling ducts - it appears that the thermal shielding idea may have some merit.
06-23-2019, 05:18 PM | #4 |
Rep 1,823
The largest appeal of the shield is to deflect heat from the ball joints at the bottom of the rotors. Outside of that it just prevents dirt from getting between the caliper and the rotor. On my Mustang I had a Ford Racing cooling shield which basically just covered the ball joint and the small area in front of the caliper. The rest of the rotor was exposed for extra air.
2017 BMW M2 German Spec
ZM22810.50 |
06-24-2019, 04:46 AM | #5 | |
Rep 744
Yes it helps with brake cooling! as others have said ball joints may get hotter and require service. I would shield them with at least some of that gold heat reflective tape. Also the shields help keep the discs dry. Keep this in mind if you drive in the rain (longer braking distances). BP engineering makes cool under body panel with brake cooling ducts http://www.bp-motorsport.com/?page_id=9952 |
06-24-2019, 05:33 AM | #6 | |
Rep 4,510
Current '22 X3M LCI.. |
06-24-2019, 09:21 AM | #7 | |
Rep 379
In short, -44C in the front and -33C in the rear with the shields removed.
06-26-2019, 07:48 PM | #8 | |
Rep 660
06-27-2019, 05:34 AM | #9 |
Rep 684
Here is an English translation.
https://translate.googleusercontent....I1HFzrE5NZ3D6A It also appears removing the front lip has a positive effect as well, though it is hard to tell to what degree. I would also note that the shield doesn't appear to provide that much of a heat protection to the ball joint, judging from the distance of the shield to the ball joint itself. Are there discussion threads that would indicate otherwise? |
01-31-2020, 07:33 PM | #10 |
Rep 433
Bumping an older thread
Anyone tried and/or have additional thoughts on this? Instead of removing the shields completely, I'm also considering cutting away the upper portion of the stock shields to potentially aid in brake cooling while retaining the lower portion to protect the ball joints from heat |
02-10-2020, 10:00 AM | #12 |
Rep 379
Yes, a lot of people have done this. In addition to cutting a section away they have also added a modified 911 "brake air deflector" to the lower arm to direct air into the cut out area. There are a couple posts around about how to do so.
2020M2Competition429.00 |
02-12-2020, 03:31 PM | #13 |
1023
Rep 839
For a track-driven car, our advice is to always remove the splash shields. They trap far more heat than they do protecting anything from heat.
A much better solution for ball joints would be to install a thermal barrier over them. We offer a product called Teknofibra that is an incredible thermal barrier. You can hold it in your hand and put a blow torch to the front side without feeling the heat. This is not your grandmother's gold foil heat shield! We provide a lot of this material to professional racing teams for various areas of the chassis. They stick it everywhere. It comes in a couple different thicknesses of 'felt' backing. It It's not cheap, but there's nothing else out there quite like it. You can see Teknofibra on our website here. |
2020M2Competition429.00 M2joey299.50 |
02-20-2020, 12:40 AM | #14 |
Rep 433
Removing the front shields appears to be very simple
Remove wheel Remove caliper Remove front rotor Remove dust shield Removing the rear shields appears to require a lot more work Remove wheel Remove caliper Remove rotor Remove parking brake shoes and expander Remove wheel hub Remove retaining ring Remove dust shield |
03-03-2020, 12:01 AM | #15 | |
Rep 72
https://www.revozport.com/product/m2...-cooling-duct/ Has anyone heard of them or tried it? They seem to have both M2 and M2C options. |
03-04-2020, 12:54 PM | #16 | |
Rep 660
03-14-2020, 01:48 PM | #17 | |
The G8X is a disaster. 🤮
930
Rep 988
