M2 Technical Topics > Suspension | Brakes | Chassis > Changing brake pads for M2 Comp (2NH)
      01-19-2019, 10:47 AM   #1
RocketBoots
RocketBoots's Avatar
Drives: Horse Drawn Carriage
Can someone point to a DIY for changing out brake pads on this BBK?
Is it the same as the OG M2? (Ridiculously easy) If so, no guide needed.
      01-19-2019, 02:26 PM   #2
Tano
Tano's Avatar
Hungary
375
You can find it in the TIS. The procedure is a bit different because you have to loosen the caliper.
      02-09-2019, 01:47 PM   #3
mlx.milano
Drives: BMW M2C
Hi,
Do I need only to lose them or completely take them off? And what is the torque value to be used when re-tighting them: 110Nm?
      02-09-2019, 02:45 PM   #4
Tano
Tano's Avatar
Hungary
375
Originally Posted by mlx.milano View Post
Hi,
As you can see you have to unscrew the 2 caliper screw, then move away it as the brake hose let it so you are able to remove the pads toward the center.
Yes the torque is 110 Nm.
      10-29-2019, 09:11 PM   #5
Daytona_550
Daytona_550's Avatar
Drives: '20 M2C / '08 550i / '23 330i
The TIS that provides the torque specs for the two caliper screws state "Renew screws". Does "renew" mean replace them?
https://www.newtis.info/tisv2/a/en/f...kes/1VnXvBISnQ
      10-30-2019, 07:58 PM   #6
2020M2Competition
2020M2Competition's Avatar
429
Drives: Yes
Yes
      10-30-2019, 08:06 PM   #7
Commanderwiggin
Commanderwiggin's Avatar
2050
Drives: M2C - X3M - Turbo E46 M3 - 45E
Originally Posted by VTBoss302 View Post
Yes
Replace means to replace. Renew only means replace if they are worn out.
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration
1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder
      10-30-2019, 08:15 PM   #8
Daytona_550
Thanks for the replies. Another question... I've done some searching here and can't find definitive answer on wheter to apply brake paste to track pads. My car is a 2020 M2C US market. I found the F80 TIS (recommends against paste) but it looks to be related to ceramic brakes. The TIS for the F87 says to apply paste to the back of the pads, the pins and the beveled edges(?).
What is the procedure for track pads (Ferodo DS1.11) with steel rotors?
      10-30-2019, 08:32 PM   #9
Commanderwiggin
2050
Use paste, track pads likely the same but probably isn't a big deal since the paste is mainly to reduce noise.
https://www.newtis.info/tisv2/a/en/f...kes/1VnXy4bj7K
      10-30-2019, 10:14 PM   #10
2020M2Competition
429
Drives: Yes
You're probably right, but now I'm even more confused as the two words can either be interchanged or mean something different depending on the definition
Some definitions from Webster
Replace
1) to restore to a former place or position
2) to take the place of as a substitute or successor
3) to put something new in place of
Renew
1) to make like new
2) to rebuild
3) to replace
Anyhow, back to the topic at hand
If you reuse the caliper screws make sure they really are in like new condition (the threads are not damaged, clean of debris, etc.)
This is especially important as the screws are steel and are placed into aluminum spindles
      10-30-2019, 10:25 PM   #11
2020M2Competition
429
Drives: Yes
+1
Also, there are some ceramic and synthetic pastes out there that are able to withstand higher temperatures than some of the metal based varieties (which can also sometimes introduce galvanic corrosion) such as this
https://www.permatex.com/products/lu...rts-lubricant/
      10-31-2019, 01:32 PM   #12
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro SS 1LE
Every paste I used evaporated after 1 track day. So I no longer use paste. Only difference is slightly more noise before 1st track day.
Kankles1484.50
      11-01-2019, 05:07 PM   #13
Daytona_550
Found this Ferodo document talking about brake paste, and reasons for its use. Found it helpful but, for track duty, I will be using a higher temp paste like the Permatex suggested above.
      12-03-2019, 11:46 AM   #14
Daytona_550
Help with brake pad sensor cable please!
I'm doing a brake pad change on US market M2C (gray BBK) right now and ran into a question. How do I disconnect the brake pad sensor? The TIS does not seem to match my setup. Is it done by removing the torx screw show in these pics?
      12-03-2019, 12:46 PM   #15
tux2005
234
Drives: 2017 M2
That is probably not the brake pad wear sensor, that looks more like an ABS wheel speed sensor.
The brake pad wear sensor should clip into the brake pad, this is what I've always seen on floating brake caliper set ups on (on E36, E39 and F22 BMWs) and my M2's fixed caliper setup (but the Blue Brembo setup).
Note: there is usually only a brake pad wear sensor on front-left and rear-right wheels, they aren't on all 4 corners.
See RealOEM:
https://www.realoem.com/bmw/enUS/sho...diagId=34_2199
#2 is the brake pad wear sensor, it looks like it should be the same as on M2 non-competition.
Your photo is of the DSC pulse generator, #8 in:
https://www.realoem.com/bmw/enUS/sho...diagId=31_1121
      12-03-2019, 03:36 PM   #16
Daytona_550
Figured it out. The brake pad sensor is only on the front left and on the rear right. I missed that on all my research. Thanks for the reply.
      12-03-2019, 03:52 PM   #17
5.M0NSTER
5.M0NSTER's Avatar
Yeah, good thing you didn't disconnect that. It would lead to loss of traction control, stability control and ABS. And lots of lights on your dash.
2017 BMW M2 German Spec
6MT, Driver's Package
--> SOLD
2018 Camaro SS 1LE. Because race car!
"Redline a day keeps the mechanics away"
      02-16-2020, 01:26 PM   #18
fastlanesimmons
Drives: 2020 BMW M2C
Hello,
Anyone know what size socket is needed to remove the front caliper bolts? Apartment living and my tool selection is limited.
Thank you in advance!!
      02-16-2020, 04:16 PM   #19
Daytona_550
Originally Posted by fastlanesimmons View Post
Hello,
Caliper bolt: 18mm
Caliper bolt torque: 110Nm
      02-17-2020, 07:41 PM   #20
fastlanesimmons
Caliper bolt: 18mm
Thank you!!
      03-07-2020, 09:43 AM   #21
Kingkow
Drives: BMW M2 Competition
Caliper bolt: 18mm
Ok, Thanks for the info. I just realised I was looking at the wrong bolt to release the caliper. Good thing this info was posted here.
Last edited by Kingkow; 03-07-2020 at 09:55 AM.. Reason: Was referring to the wrong bolt
      03-16-2020, 08:29 PM   #22
Quicksilver_M2C
Go for it now. The future is promised to no one
Quicksilver_M2C's Avatar
Drives: 2020 M2C
I'm about to change out the pads on my M2C for ceramic pads. Came across this service manual for the M2C online. Thought I would be helpful...
