M2 Technical Topics > Suspension | Brakes | Chassis > BMW M3/M4 F8X Carbon Fiber Strut Mod on the BMW M2
      03-26-2020, 08:21 AM   #199
3t3p
New Zealand
455
Easier to place the car. The deadness centrally in the steering wheel is physically the same, but as the car is keener to turn it has the effect IMO of making it seem like the deadzone is less.
      03-26-2020, 01:30 PM   #200
SIE_M2
8
Drives: Bmw m2
Thanks both for the replies!
      03-28-2020, 08:33 PM   #201
///Monika
Drives: '18 X3 M40i & '18 M2
Hoping you guys can help me here. We installed a new HPFP today and in the process, had to remove the carbon strut. As soon as it was unbolted from the front and back, well - the front piece was just completely de-coupled. it looks like it's merely glued on.
Husband wants to remove the glue on the bracket (picture) but what do we use to re-glue it ? Any ideas ?
      03-28-2020, 08:58 PM   #202
Nezil
Nezil's Avatar
1403
Drives: LCI '18 6MT M2
It is just glued on, yes... maybe beta-link would work?
Yours looks gold, is that just the lighting? I thought it was black normally.
2018 ///M2 LCI, LBB, 6MT...
Current Performance Mods:
      03-28-2020, 10:22 PM   #203
///Monika
Should be gold for what this thing costs right. No, probably has a lot to do with all the led lights in here. I was thinking beta link too (we actually have some but never used it) but wasn't sure .. Shouldn't be a problem removing it off the bracket but any attempt to remove it from the carbon fiber is well - risky at best. This stuff is really on there. Almost like a rubber material. Wonder how well beta link sticks to beta link.
Adding a photo of the carbon... Apologies if the thing is rotated wrong(must be something to do with my phone).
      03-29-2020, 04:07 AM   #204
M Fifty
844
Drives: M2 & 330CI
This was a new part?
From the pictures, while the adhesive is on both parts, it's only around the edges of the bonded area on the CF (and you can see the imprint of the weave in the adhesive that's still attached to the bracket).
That rather suggests the surface coating on the CF failed.
///Monika186.50
      03-29-2020, 09:48 AM   #205
///Monika
Yes, purchased new from Sun Motors (Brian) back in Sept. '19. You are exactly correct, the imprint is actually the coating pulled directly off the CF. The surface on the CF is uniform though.
Worth an attempted repair ? Betalink cured over a couple of days?
      03-29-2020, 10:06 AM   #206
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Parts usually have 24 months warranty- take it back to dealer ?
Current '22 X3M LCI..
PLF693766.00
///Monika186.50
      03-29-2020, 11:00 AM   #207
///Monika
Thank you. I had to check to verify that purchasing the part out-of-state (or different dealership) isn't a problem and according to the BMW web site, as long as we have the invoice (which we do), we can return the part for a replacement.
Here's hoping no one else has a failure outside the warranty.
      03-29-2020, 04:25 PM   #208
drledford93
drledford93's Avatar
34
Drives: Ford Focus RS (RIP), C43 AMG
Has anyone made a video log of this install/upgrade? I'm looking at purchasing an '18 LCI and would like to explore this...(nothing was on youtube that I could find...)
      03-29-2020, 05:00 PM   #209
Nezil
Nezil's Avatar
1403
I considered taking some photos, but decided that there are so many tutorials out there for the more complex parts that it wasn't worth bothering.
Once you have the right parts... which includes all the fastenings in my table a few posts ago...
- Disconnect battery
- Remove the plastic trim either side of the bulkhead
- Remove the steel strut brace
- Replace the shock top hat by either removing the strut and using spring compressors (more complex), or by jacking the lower control arm with the car or jack stands (easier), removing the nut and slowly lowering the jack taking the slack off the spring. The top hat can then be simply un-bolted from the strut tower and the new one bolted in. Re-fitting is the reverse of removal
- Fit the riv-nuts using any approach that works; I recommend using a serrated washer, an oversized nut, a flat washer and a bolt
- Fit the new Aluminium brace, being careful as you slide in under the fenders and up to the mount point under the windshield
- Bolt everything up but do not torque yet, replacing bolts as required
- Lower the car back down to the ground
- Tighten all bolts to the correct torque, details in the table
- Reconnect battery
If you want to replace all the trim pieces, and you should, you'll need to remove the wiper arms to get the plastic under the windshield off. Everything else after that just clips into place.
If you were closer, I'd happily offer to do this for you because it's a quick job. Louisville is a little far for me.
dtmurf481.50
      03-29-2020, 05:01 PM   #210
Nezil
Nezil's Avatar
1403
Sorry, I should have said that removing suspension on an F series BMW is all over YouTube, and so are the details on how to attach a riv-nut.
      03-30-2020, 02:22 AM   #211
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
This step by step is fairly comprehensive, although its for F2x cars (hence the need to change out front cross slam panel - not necessary on an M2 as it shares same front cross slam panel with M3/M4).
https://www.babybmw.net/viewtopic.ph...19998#p1119998
The most involved part is installing the alloy brace - essential as this supports/secures both 'legs' of the CFRP part.
Looking at Nezil's photos, my only additional tip would be sleeve/wrap the alloy brace in insulating tape, where its closest to the 12V +ve terminal to ensure no chance of a short.
HTH,
BP
      03-30-2020, 11:32 AM   #212
drledford93
34
Thanks for the help!
What is the increased rigidity/turn in feel if *just* the aluminum brace is installed? Anyone do only that and leave off the CF one?
      03-30-2020, 11:40 AM   #213
Nezil
Nezil's Avatar
1403
That's all I've done so far... the CFRP I've ordered, but I bought it from an eBay seller in the UK and I've no idea when it's going to arrive.
I really want to complete the project, but I'm sure the Aluminium brace makes the biggest difference. It's not that expensive a project, so well worth doing.
      03-30-2020, 12:31 PM   #214
drledford93
34
Thanks for the offer to help, only a small commute. I just found it a bit confusing, perusing the thread and trying to figure out the purchase list. But, then again, I was trying to parent two redheaded boys that are slightly raucous.
I posted above but thought you might see it now, any idea if just the aluminum brace would help over the steel one and without the CF part? That CF part is steep...
Daniel
- Reconnect battery
      03-30-2020, 01:12 PM   #215
Nezil
Nezil's Avatar
1403
The parts list table that I made should be fairly clear, but let me explain it again for more clarity...
I divided it in to sections sort of based on what had been written elsewhere about stages for this retrofit:
  • Stage 1: Strut reinforcement rings
  • Stage 2: Aluminium Brace
  • Stage 2a: Plastic trim
  • Stage 3: CFRP Brace
You could eliminate stage 1 and save yourself some money. The M2C doesn't have these rings, but the M3 and M4 do; your call. If you do skip Stage 1, you'll still need 10 of the stock bolts that hold that strut top hats on because they're single use (torque + angle). These are listed in the 'return to stock' section; the part number is 31306869931.
Absolutely everything you need to fit the Aluminium brace only is listed in Stage 2 (except the bolts I mentioned above if you're not doing the reinforcement rings); you won't need anything else.
Stage 2a is somewhat optional. You can trim the stock plastic pieces if you prefer, and that should be fine. If, like me, you want to make it look as OEM as possible, you'll need everything in this section. I would recommend getting the strut top rubber covers, because of the reasons I mention a couple of posts down - they insulate the 12v terminal.
I have the same problem... not redheaded, but believe me, they're still raucous!
I posted above you about this. Aluminium alone is well worth doing, and it's all I have currently myself. I am going to do the CFRP part, but it hasn't arrived yet so I cannot comment on the difference it makes yet.
      03-30-2020, 01:18 PM   #216
Nezil
Nezil's Avatar
1403
I'll try and get another photo of this today. That's good advice if you don't go with the correct strut tower rubber covers. The correct part has a big bit of rubber going around the aluminium section at that point, so are insulated if you fit these.
One thing I noticed is that the M2C / M3 / M4 aluminium part does have what looks like a 3D printed black plastic part just behind the 12v terminal. You can see it in my photos. This sort of creates a slightly more radiused rather than short edge where all of the other power wires are coming up from the distribution box. I think this is quite important, and without this, I'd put a lot of insulating tape. RealOEM doesn't list this separately, and I've seen some retrofit photos with it, and some without. When I sourced my aluminium section (used), I made sure it had this before I ordered it.
      03-30-2020, 03:09 PM   #217
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Nezil
I assume you mean the plastic part in the first photo (my alloy brace before fitting) and the brace during my install - showing area just fwd that I've wrapped in proximity to 12v +ve terminal.
BP
      03-30-2020, 03:40 PM   #218
drledford93
34
Nezil--You. Are. Fabulous.
      03-30-2020, 11:26 PM   #219
Nezil
Nezil's Avatar
1403
Yes, though it seems to be slightly larger on my car; see photos below.
You can also see the insulation offered by the strut top cover in these photos, which goes around both sides of the aluminium around the 12v area. With the plastic part as well, this almost covers the aluminium in that region.
Below is a photo with the 12v terminal hatch open. You can see from here that it would be pretty unlucky to get a short when connecting here because there is rubber & plastic all around the region exposed when you open the hatch.
I still don’t have the CFRP brace installed, so the final position of the rubber insulation may not be exactly like these photos.
Bee Pee1779.00
      03-31-2020, 01:57 AM   #220
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Nezil
My alloy brace didn't have that extra plastic part in yr 1st photo - might see if that's available seperately for RHD cars and retrofit it.
Thanks
BP
Tags
bmw m3, bmw m4, carbon fiber strut conversion
