10-21-2016, 12:24 AM | #25 | |
3776
Rep 54,154
Drives: F80 M3
Rear diff R&R doesn't affect alignment though unless the subframe had to be moved around. |
10-21-2016, 10:24 PM | #27 |
Rep 245
Drives: M2 DCT MPerformance coilovers
Toe misalignment you will get some feathering on the tread either inside or outside depending on out or in.
Camber you will be dependent on how much g you load the suspension with on average. So a good track alignment (more negative camber) might wear the inside if driven on road for many miles. (or wet track). I just came back from a tarmac rally and found perfect wear for the set up I had in the dry but in the wet I was scrubbing the inside fronts. Less grip. |
10-24-2016, 11:10 AM | #28 |
Rep 17
Here's what they stated on their report.
10-24-2016, 11:15 AM | #29 | |
3776
Rep 54,154
Drives: F80 M3
11-19-2016, 07:23 AM | #30 | |
Rep 310
Drives: 04A6 2.7T(DD), 16M2 BSM MT EP
Wheel alignment done. Rear toe was slightly off: left -0.03' right +0.01'. target is +0.08' range is +0.2' to +0.12' Rear toe reset to 0.08" right and left Last edited by reppucci; 11-19-2016 at 07:30 AM.. |
03-15-2020, 11:38 PM | #32 |
Rep 1,092
It looks ok except your steering wheel likely not centered, the total toe in the front is ok.
Comfort mode makes no difference, our cars don't have active suspension. Maybe you previously had more toe in front so now it feels more floaty. You'll get used to it, don't run more toe. |
