M2 Technical Topics > Suspension | Brakes | Chassis > Check your factory alignment
      10-16-2016, 08:05 AM   #1
Twt
Twt's Avatar
634
Drives: 2017 M2
I put about 250 miles on the car and wanted to check the factory alignment to establish a base for future tracking, the car also felt a little odd in the seat/rear. I took it to GTE in Atlanta, they do a ton of track cars, and it showed that both rear toe numbers were off (toe out) and the RR camber as well. After resetting the car feels better. If you went to the dealer with these settings they would tell you that you needed a $200 alignment! GTE said this is not unusual in that most new Porsches come in with off factory numbers.
BAN_M2C4180.00
      10-17-2016, 02:32 AM   #2
Yellowflash21
Slovenia
370
Hey mate, can you please post all of your alignment settings.
      10-17-2016, 07:28 AM   #3
Twt
Twt's Avatar
634
Drives: 2017 M2
Attachment 1509921
      10-17-2016, 09:00 AM   #4
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
I think they would say that's within factory tolerance or something. Also at 250 miles you can probably get a free courtesy re-alignment.
      10-17-2016, 10:44 AM   #5
Yellowflash21
Slovenia
370
Thank you sir!
      10-17-2016, 12:23 PM   #6
PrematureApex
Drives: N55 X1, N54 135, s54 m3
Are you looking at some other numbers?
The right rear is clearly out of "factory tolerance" in both camber (no big deal) and toe. The factory-acceptable ranges are pre-loaded into the alignment machine, green means within factory spec, red means out.
You would never want to run toe out in the rear of this car (sans perhaps a drifter).
OP: Did you have a dead body in the trunk, by chance?
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      10-17-2016, 12:31 PM   #7
Spinnetti
Drives: Various
Something about a several thousand mile trip including over a rough ocean with the car winched down hard to the deck might do that Since you are having it done anyway, should do it with you in the car to make it even more accurate
      10-17-2016, 01:34 PM   #8
reppucci
Drives: 04A6 2.7T(DD), 16M2 BSM MT EP
2016 M2  [0.00]
1995 M3  [0.00]
2006 Mini Cooper S ...  [0.00]
2004 A6 2.7T  [0.00]
1994 325is  [0.00]
Attachment 1509921
Good to know.
When they swap the rear diff, something many 16-17MY m2's are in line for, the wheel alignment I believe is redone.
I will ask for specs and printout. My rear diff is scheduled to be swapped out soon.
      10-17-2016, 01:46 PM   #9
PrematureApex
I'll admit I haven't been under one, but are you sure?
They should be able to drop the diff right out without removing the subframe (or any of the control arms attached thereto).
      10-17-2016, 03:28 PM   #10
Yellowflash21
Slovenia
370
Twt last thing mate, what was the after value for rear?
      10-17-2016, 05:20 PM   #11
Twt
Twt's Avatar
634
Drives: 2017 M2
Did not take a pic....but all green, I believe they went zero toe in the rear.
By the way, we did this with me in the car and without, no toe change.
      10-17-2016, 05:26 PM   #12
Twt
Twt's Avatar
634
Drives: 2017 M2
We did it both ways....toe was the still whack. Surprisingly, my extra 190lbs barely moved the needle....I think it was 1/10 on right camber only...very stiff suspension.
      10-17-2016, 05:28 PM   #13
Twt
Twt's Avatar
634
Drives: 2017 M2
I did....but the dead body only changes camber
      10-17-2016, 06:39 PM   #14
Spoonman929RR
Drives: 2017 F80 M3
Attachment 1509921
How long have you had it for? For the future, BMW will redo your alignment if it's within 3 months. Not sure about mileage though.
      10-17-2016, 08:04 PM   #15
reppucci
2016 M2  [0.00]
1995 M3  [0.00]
2004 A6 2.7T  [0.00]
1994 325is  [0.00]
IIRC in one of the many posts, I can't seem to locate it, I saw the BMW tech report ..... when the diff is swapped out, in addition to the new bolts, etc... the BMW procedure calls for an alignment check and road test to make sure everything remains to spec.
When I find it I will post the link.
      10-18-2016, 01:11 PM   #16
ChrisK
ChrisK's Avatar
Drives: '19 M2C
Attachment 1509921
I feel for you. I had a M Roadster back in the day, and it didn't drive right the first week I had it. Took it back to the dealer and the aligned it - it was way off (front and rear).
www.ReTuneTheDeTune.com
      10-18-2016, 02:07 PM   #17
HP Autosport
Drives: F80 M3
The factory just get it close, it is never very precise.
      10-18-2016, 08:13 PM   #18
Twt
Twt's Avatar
634
Drives: 2017 M2
That's a sad commentary that the port or the dealer would not check an M car before delivery...
      10-19-2016, 02:47 PM   #19
HP Autosport
Drives: F80 M3
Unfortunately that is not one of the checks they do at the port, but at the dealership level that should have been caught on a road test. Does the car pull to one side or the other?
      10-19-2016, 04:13 PM   #20
M+M
M+M's Avatar
New Zealand
227
Drives: M2 DCT MPerformance coilovers
this is my printout from dealer alignment with installation of lowered MP suspension
BAN_M2C4180.00
      10-19-2016, 06:19 PM   #21
Twt
Twt's Avatar
634
Drives: 2017 M2
Did not pull....but felt rough in the seat....scrubbing
      10-19-2016, 06:20 PM   #22
Twt
Twt's Avatar
634
Drives: 2017 M2
It looks like you had a rear toe issue as well from the factory.
