04-04-2023, 07:51 PM | #23 | |
Rep 7,435
From what I have seen it's the gap that causes these misfires, and when they go to a larger gap (generally closer to stock) the misfires go away. These cars don't seem to sensitive to colder plugs, so the NGK's play no part in the issue. Now here's the caviot, I have heard issues come from the poor QC of the NGK plugs, that's the only time when I see the plug being at fault, and according to AmuroRay QC problems on NGK plugs are way more common than on Bosch plugs.
chris7197335.50 |
04-04-2023, 08:45 PM | #24 | |
Rep 7,299
04-04-2023, 08:58 PM | #25 |
Rep 7,435
It very well could be, that's why no one should ever buy plugs off of eBay, or non authorized resellers.
04-05-2023, 12:21 AM | #26 | |
Rep 1,339
Even easier, the 500 hp is not obtained by increasing turbo pressure, but by cooling the combustion chamber, therefore the oem spark plugs suffer even less. I always leave them at 0.022. Last edited by Track/S; 04-05-2023 at 12:33 AM.. |
04-05-2023, 01:33 AM | #27 | |
Rep 7,435
https://f80.bimmerpost.com/forums/sh....php?t=1262417 1) Injection start is load and RPM based not strictly iat like you said... "If the engine is operated in a load range (full load) and engine speed range (>5000 rpm) that justifies water injection, the DME requests this." Bmw also stipulates volume iinjected is dependent on the ecu and various other running parameters. 2) The technical documents also mentions BMW operates the engine with higher charge pressures and earlier ignition. So again you're wrong. Several press sources say its a ~4psi bump: https://www.bmwblog.com/2016/09/14/t...ok-bmw-m4-gts/ The M2CS, M3Cs, and M4CS are all making Stage 1/2 power level and no water injection, and running on the Bosch spark plugs without issue. This further refutes your narrative that the stock plugs can't handle these running conditions. 3) You do realize that air density doesn't increase enough for there to be a 50 HP gain right? The car is also load based tuning, so when the iat's get that cold it will alter engine parameters to keep the same load. So without running the engine harder you will not make more power. Btw gapping down without cause is how you trigger misfires and incomplete combustion. Maybe that's why you are seeing alot of broken plugs.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 04-05-2023 at 01:53 AM.. |
04-05-2023, 05:23 PM | #29 |
Rep 420
F87source not to digress the convo too much from OP’s thread but you mentioned gapping down to 0.022 being problematic and I’ve done that on my last F30 n55 when I had it stage tuned and now just recently did so on my F87 stage e30 yesterday. Haven’t been able to push the car yet but folks at the shop swear by that gap standard and I had followed the same per BM3 suggestion a while back.
If you’re currently tuned, what gap have you been running? I’m on stock plugs btw, tried the NKG on the F30, wasn’t feeling the colder step as the car did run rougher and you’ve been following these threads for a while to be a wealth of knowledge on the subject matter. |
04-05-2023, 06:58 PM | #30 | |
Rep 7,435
Ideally you should run the stock gap size - which has been tested by BMW and Bosch vigorously under all these running conditions all over the world, and then gap down only when you need it (i.e. when experiencing spark blow out). This is how it should be done, run as large as possible and move down as data logs show you that it is required. Not guessing some random number because one feels smaller is better - because it isn't. So why would you want to run a gap size as large as possible? Because you want to promote complete combustion, the larger the spark the large the "ignition area" and the larger the ignition pocket can be to burn all the fuel in the combustion chamber. If you go smaller gap, that ignition pocket gets smaller and you start to experience incomplete combustion. The only reason one would gap down is to prevent spark blow out, because the smaller the gap the harder it is to blow out the spark. However gapping down to stop spark blow out is only a band aid solution, in reality you should get stronger coils to retain the gap size. I have helped alot of people on here who got rough idles and misfires due to the gap size being too small. So that's why I'm suggesting staying stock, and gap down only when needed, take feedback from your car, not some arbitrary one size fits all suggestion, because there is no such thing as one size fits all without massive rnd.
chris7197335.50 imperfectluck426.50 |
04-05-2023, 08:54 PM | #31 |
Rep 420
F87source I hear you and it begs me to ask why would PTF suggest this specific gap range here? I understand the logic of starting at stock gap and going smaller if needed though I find it odd coming from a platform that develops tunes to hear otherwise which is why most folks just gap down and go to town.
Reference |
04-05-2023, 09:03 PM | #32 | |
Rep 7,435
Either way like I've said before I've diagnosed a lot of spark plug gap induced issues on this forum alone. So there's that.
imperfectluck426.50 chris7197335.50 |
04-06-2023, 01:39 PM | #33 | |
Rep 7,299
F87source7263.00 |
04-09-2023, 12:15 PM | #34 |
Rep 4,156
I’m running NGKS at out of the box gap. I don’t know what the obsession is with gapping down, or even changing from OEM. I did it because everyone else was and it provided nothing.
04-09-2023, 06:19 PM | #36 | |
Rep 7,435
There's always a train of thought process out there that after market is always better than stock, so there is a huge rush to replace all stock parts with aftermarket. While for somethings that may hold true (engine oil - replacing the FE garbage for non Fe oils) there are somethings that are better stock (diff oil).
