10-16-2020, 08:50 AM | #111 | ||
There Is No Substitute
1909
Rep 1,070
10-16-2020, 09:42 AM | #112 | |||
Rep 13,104
It appears that some M2 CS cars are not affected: (source: here - poll thread: here) For your info: Ferrari Enzo CFRP hood for Michael Schumacher back in 2003.
///M is art ↔ Artemis
10-16-2020, 01:53 PM | #113 |
In the Details
1810
Rep 866
Drives: Yes
Garage List 2020 AMG GTR [0.00]
2022 R8 Quattro Spyder [0.00] 2023 X5M50 [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Civic Type R [0.00] |
10-16-2020, 04:17 PM | #114 | ||
Rep 1,672
Drives: M2 CS | M135i
2020 M2 CS DCT
2021 M135i xDrive ex: 18 M3 DCT ZCP | 15 M3 DCT | 11 M3 Coupe 6MT ZCP | 07 M Coupe |
Artemis29404.00 |
10-16-2020, 04:51 PM | #116 |
Rep 4,672
My further 2cents about the construction. Watching the CFRP roof creation video you will notice similar defects in the standard carbon roof. These defects are present until the material is placed under a large press. The M2CS roof with it's "honeycomb" center structure would/could not go through the same pressing process. It this process that stretches the material and removes the defects from loose regions in the material. The M2CS roof is likely handmade for a large part of the process and would need a special tool to strectch the material and sandwich the center structure without destroying it at the same time.
Try stretching out a net so that all cross sections are equal. Similar concept with a course woven material. If it gets stretched too much in any direction it can sometimes be very difficult to undo. Align the best you can and spray it with a ton the clear, or tinted clear like mentioned previously. I think we are seeing ripples in the fabric from not lying perfectly flat or not being cut to take into account the final curvature of the panel. Try nicely wrapping a ball with a piece of notebook papar |
2taCoS279.00 |
10-16-2020, 05:15 PM | #117 |
Rep 5,728
Drives: 2019 M2 Competition
M2 CS Carbon Fubar roof.
10-16-2020, 05:33 PM | #118 | |
Rep 405
Even this limited-run vehicle will realize gross receipts in the ballpark of $200M USD - not a big account for a mass-producer of cars, to be sure, but not chump change either. |
10-16-2020, 06:17 PM | #119 | |||
Rep 13,104
On the M2 CS on display in Los Angeles (Autumn 2019), there were also some 'raclette' sections closer to the windscreen:
10-16-2020, 07:24 PM | #120 |
Rep 4,672
Does the roof bow inward with respect to where the corners start at the front and rear window? If yes, then the material would have to pinch in a bit near the apex of the curve. One major defect at the apex or a few minor defects if you try to spread it out. This could be a roof pattern error that wasn't remedied.
10-16-2020, 08:29 PM | #122 | |
Rep 405
JustChris17487.50 |
10-16-2020, 08:33 PM | #123 |
Rep 4,672
10-17-2020, 10:15 PM | #125 |
Rep 1,297
Ran into this on a youtube video I was watching, stuck out once you know where it is. Looks like same area as some of the other cars.
2022 M3 xDrive Comp
2020 M2 CS (retired) 2018 M3 Comp (retired) 2015 335i (retired) |
Hedoniste3834.00 |
10-17-2020, 10:42 PM | #126 |
Rep 405
We most assuredly are seeing a trend. In hindsight it's not surprising the production issue would be more or less consistent from unit to unit. Occurring at the assembly level and not at the CF sheet formation level.
10-18-2020, 12:37 PM | #127 |
Rep 367
10-18-2020, 01:00 PM | #128 |
Mmmm... Bavarian
2129
Rep 1,690
One of my thoughts is this is part of the normal curvature of the roof shifting the material as evidenced in the videos and is somehow more difficult or more visible either because of the larger weave pattern or the structural sandwich layers unique to this roof construction.
10-18-2020, 08:24 PM | #130 | |
Rep 1,297
Now if there were REALLY perfect ones out there, I'd have an issue with it.. I have a feeling those who say are perfect either don't have a good eye or aren't looking at it in the right lighting condition
2022 M3 xDrive Comp
10-19-2020, 03:46 PM | #131 | |
Rep 309
10-19-2020, 04:07 PM | #132 |
Rep 375
