06-26-2020, 12:23 PM | #46 |
Rep 929
06-26-2020, 12:59 PM | #47 | |
756
Rep 2,149
Not once did I say it's not more accurate. I said it's not more useful. I think you need to start having a conversation with the actual person you're talking to, instead of making up things you think I am saying "TPMS air measurements are a distant cousin to the tire carcass air measurement for all the physical reasons I outlined, precise mechanical engineering reasons, in a post above. Hence the point of "if you want to measure tire temperature", a TPMS is a near worthless measurement." Umm, no. Air pressure at the tire surface and air pressure and the wheel barrel are not different. Nor did you outline a precise mechanical reason how they are. "One can deny long proven thermal design analysis as invalid, but that doesn't make it not true." Where the hell did I ever deny thermal analysis is invalid? Like I said, you continually build strawman arguments against me and have a conversation with someone that doesn't exist. End of the day, you are wrong. Track Connect IS NOT more useful than TPMS. And you've continually not justified how you think it is. That's on you, not me. Last edited by Anthony1s; 06-26-2020 at 01:08 PM.. |
06-26-2020, 01:00 PM | #48 |
756
Rep 2,149
06-26-2020, 02:14 PM | #49 |
Rep 3,337
I have only *ever* been referring to TPMS temperature measurements. Only. Every single statement I have made in reference to that accuracy of tire sensor embedded measurement has all related to temperature measurement of which TPMS temperature measurement is a distant cousin. Reread my post on exactly why this is the case if you do not understand the heat transfer situation of a sensor embedded in the tread/carcass versus the air measurement at the TPMS sensor.
No place above, including in my specific post on the different heat paths and transfer methods, was it ever discussed that pressure was any different (obviously, just reread my posts). It's a fairly involved analysis, so if you're not a thermal design engineer, you probably won't easily understand the huge difference between those two locations. It's even more involved since there are two major sources of energy input, one of which primarily affects the bulk TPMS measurement (heat conduction from the hub interface, which on track and up front, is a large component; heat radiation input from the wheel barrel from the brake assembly). Both of those sources of input significantly effect the overall gross measurement a TPMS sensor measures. In the meantime, the embedded tire sensor is primarily reading the overall and transient effect of the actual tire carcass from two primary sources of energy input: (1) the tread/pavement interface and (2) the hysteresis of the flexing of the carcass as it flexes through a complete cycle due to the contact patch contact. This is PRECISELY why the temperature measured by the embedded sensor is massively more precise/accurate/pick-your-best-adjective measurement of the tread compound temperature, especially in the transient condition with its sharp peaks. The TPMS temperature measurement is a far distant cousin to this embedded sensor value. There are many analogies, but one fairly good one is that of a circuit board with a surface mount high power chip. The TPMS sensor here is measuring the overall average board, MIB, temperature; while the embedded sensor here is the semiconductor junction temperature. That junction temperature varies dramatically with time, transient heat transfer, and reaches extremes in rate of change and max peaks that the overall board temperature measurement never shows. Similarly, the overall board temperature is also affected by other heat sources similar to the TPMS located air temp sensor. Also while some may want to discard the actual embedded sensor accurate tread compound temperature transient and bulk data as not useful, since I have no experience with the entire system as designed, I'm retaining an open mind for now. Michelin tire engineers are some of the best in the business, and while it's possible they've created a worthless toy, I'm open to finding out what can be learned and what features the program provides.
Current Stable:
cptobvious2531.50 devo755.00 |
06-26-2020, 05:50 PM | #50 | |
756
Rep 2,149
This has been an entire conversation of me asking you to provide a single example of them being more useful in setup changes other than tire pressure, and you not giving any. Literally, that's all I've been asking for from you. You just go on and on about how they give more accurate temperature readings. Which, for one, is not true. And two, has zero relevance to what I claimed and you are calling me out on being wrong for. Last edited by Anthony1s; 06-26-2020 at 06:12 PM.. |
06-26-2020, 06:38 PM | #51 |
4985
Rep 11,891
Through a Michelin marketing event I attended last year, I ordered a set of Cup 2s for my M6. Michelin actually sent me a set of Track Connect Cup 2s instead.
Here are some up close pictures of the tires in case you were curious what it looked like. The sensors fit inside the tire. As I was not prepared to get connected versions, I'm now debating whether I should dive in all the way and buy the sensors.
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) Last edited by Flying Ace; 06-26-2020 at 08:03 PM.. |
CSBM52721.00 |
06-26-2020, 07:21 PM | #52 | |
Rep 3,654
06-26-2020, 07:31 PM | #53 | |
Rep 4,672
06-26-2020, 08:01 PM | #54 |
4985
Rep 11,891
Sensor.kit is $500! Not sure if geeking out is worth the cost of 1 corner!
https://m.tirerack.com/tpms/detail.jsp?ID=2843
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
06-26-2020, 09:24 PM | #55 | |
756
Rep 2,149
06-27-2020, 05:04 AM | #56 | |
Rep 13,104
///M is art ↔ Artemis
06-27-2020, 11:22 AM | #57 | |
Rep 3,842
