06-22-2020, 12:52 PM | #23 |
Rep 4,658
This^^^^. I'd get it just to see how long it takes my tires to warm up in various conditions, and optimize tire pressure for various scenerios. I've spent more money on lesser things.
06-22-2020, 12:56 PM | #24 | |
Luxury at the redline :)
9103
Rep 7,563
I mean, I would of just coded out the TPMS, then add it back, after my track session, to avoid error, when I'm on the track. |
06-22-2020, 02:23 PM | #26 |
Rep 4,658
06-22-2020, 02:30 PM | #27 | |
756
Rep 2,149
What would be useful is knowing the temp rage across the tire, because then you can adjust camber to even out tire wear and grip. I guess your point is a practical use though. If you disable OEM TPMS and use Track Connect instead, you can circumvent the BMW only allowing you to use comfort mode when the tires are below a certain pressure. So it would allow running lower tire pressure, while still getting sport mode, temp, and psi features. Would need two phones though for track use. One to read tire readings, the other to read ODB2 data. So that you can monitor all the important stuff. |
Poochie9103.00 |
06-22-2020, 03:19 PM | #28 | |
9103
Rep 7,563
But regardless, I don't see the value of it, tracking or not but that's just my humble opinion. |
06-22-2020, 03:59 PM | #29 |
Rep 2,856
06-22-2020, 07:01 PM | #30 |
Rep 3,842
In the video they specifically said that the box had to be located at the center of the car which for the CS would be the console that doesn't exist.
06-22-2020, 11:48 PM | #32 | |
756
Rep 2,149
Only things that can safely interact with alcantara are carbon fiber, titanium, and e85 or greater. |
robertm449.50 |
06-23-2020, 06:21 PM | #35 |
Rep 660
Makes me wonder why BMW's TPMS couldn't accomplish the same thing? It already displays the temp and pressure data in iDrive, so I imagine they would just need to create a BMW app to do that. The temp/pressure doesn't need to be that accurate as I imagine it's all relative (increase/decrease pressure to decrease lap times).
06-24-2020, 05:52 AM | #36 |
Rep 3,329
Measuring temperature near the treadface, in the actual tire carcass, is much more accurate reflection of the "tire temperature" than the TPMS sensor measuring internal air temperature. Besides the obvious substantial phase lag between tread temperature change and internal air temperature, there are other losses that result in the TPMS air temperature measurement being a very poorly correlated value versus tread temperature.
For example, the tire carcass/tread loses heat due to conduction into the road surface, convection into the outside air and radiation into the surroundings. Having an embedded sensor in the actual carcass allows a much more accurate and direct measurement of temperature the tire is experiencing. It will give much more accurate data of the temperature profile the tire experiences - it's transient temperature profile (tire temperature versus time) with the substantial peaks recorded, etc. You get essentially none of that with just an internal air temperature measurement.
Current Stable:
cptobvious2531.50 |
06-24-2020, 08:00 AM | #37 | |
756
Rep 2,149
06-24-2020, 08:23 AM | #38 |
Rep 3,329
That depends on how you employ the data. Michelin has extremely detailed data on how the tire responds versus air pressure versus temperature at the sensor location. That three dimensional array is highly useful when properly applied and interpreted which the app implements. While it obviously isn't as useful as real-time infrared tread analysis from a full view sensor setup in every wheel well, I can't simply say it's worthless either. Unless someone has spent time with the system using engineering level analysis, speculating on it's usefulness is simply inaccurate at this point.
Current Stable:
cptobvious2531.50 |
06-24-2020, 11:47 AM | #39 | |
756
Rep 2,149
Even the marketing material and instructional documentation say the track connect technology improved the lap time by 7.29 by analyzing track data over the course of 10 laps to give recommendations on the best tire pressure to run. All it's using itself for is a platform to recommend the best tire pressures to people, not as a way to make other setup changes. |
06-24-2020, 03:33 PM | #40 | |
Rep 3,329
I had no run-around and non-answers. Reread my technical description of why and how the track connect data differs from a TPMS temp data. If I've made any technical error, please reply and we can figure out what I'm missing, but I don't see anything in error at the moment.
Current Stable:
cptobvious2531.50 Davil6469.00 |
06-25-2020, 11:27 PM | #41 | |
756
Rep 2,149
The sensor being mounted inside of the tire or in the wheel makes no difference in reading PSI. Nor does Michelin claim more accurate PSI readings. The entire track connect system isn't based on that. The entire system is created to give calculated tire pressure recommendations based on your driving style. You ask the app to start logging data, and after enough data is collected it recommends a tire pressure to you. That is how Michelin achieved the 7.29 second better lap time. It set the car's tire pressure to some arbitrary PSI, then ran the track for 10 laps. At the end of the 10 laps, they app told them what is the best tire pressure to run for their current driving conditions. They then set their tires to the PSI and a achieved 7.29sec faster lap time. It's actually a useless test without knowing what their tires were run at for the start lap. If they started off at 5psi, well then it's not hard to achieve a 7.29sec lap time by adjusting tire pressures. So the test doesn't show how great their system is. Yes, I agree you get quicker tire temp readings from a sensor in the tire, as opposed to in the wheel. But that is of absolutely no use to a driver setting their own pressures. You're not gonna stop in the middle of the track to adjust your pressures. And it is absolutely not more useful for making suspension changes for the same reason. No one adjusts their tire pressure to handle 1/8 corners at a track. You run a tire pressure, the same tire pressure, for the entire lap. You keep arguing this from a "the sensors are more accurate" perspective (which they aren't. they read temp quicker, but aren't more accurate), without grasping that I am speaking about usefulness, not accuracy or speed of readings. That's why you are missing my point. You also completely miss the point of what Track Connect is designed for. It is a system to calculate and recommend the best tire pressure for ones driving scenario, so the user doesn't have to think about it themselves. That's it. Last edited by Anthony1s; 06-25-2020 at 11:35 PM.. |
06-26-2020, 12:20 AM | #42 |
Rep 141
The tire temperature function of the BMW TPMS sensors are inaccurate and slow to respond. It’s a useless function. The functions of the track connect are very useful as having tire temps is the actual data needed to get the most performance out of the tire. For example, I did a burnout before a drag race and the air temp in the rear tires did not change. If I had the tire temps I could find the optimal temp range and warm the tires up to that point without under or overdoing it.
Davil6469.00 cptobvious2531.50 |
06-26-2020, 06:06 AM | #43 |
Rep 3,329
If one doesn't understand how much more accurate and different the tire temperature measurement is in the carcass of the tire versus a TPMS air measurement, there's not much anyone can do. TPMS air measurements are a distant cousin to the tire carcass air measurement for all the physical reasons I outlined, precise mechanical engineering reasons, in a post above. Hence the point of "if you want to measure tire temperature", a TPMS is a near worthless measurement.
Accurate in these terms mean you're measuring a direct carcass/compound temperature with all the nuances and precision that provides. Having done extensive thermal analysis testing, instrumentation, analysis, design, etc, there is no question this is the case. A simple analysis will show it in fact. One can deny long proven thermal design analysis as invalid, but that doesn't make it not true.
Current Stable:
cptobvious2531.50 |
06-26-2020, 11:45 AM | #44 |
Rep 3,842
Since these new Connect tires + box haven't been evaluated by anyone here there is no proof how well they perform.
I can only say that I've found the TPMS useful. It tells me in the morning what the cold pressure is accurately with the usual .7 psi lower reading that both of my BMWs have had. I just add .7 to the reading. When the tires warm up I can see how much the pressure goes up and how hot the tires get in a given situation. A 4 pound gain with normal street driving is about normal. On a hot day in the twisties is where it's really obvious how hot the tires get. If they get too hot add more air. If they don't get hot enough let some air out. This whole tire pressure/temperature thing is not exact rocket science. It may be more predictable at one track on a given day but ambient temperature can change the optimum pressure, cool mornings will be different than hot afternoons. Chasing optimum pressure in mountain twisties is hopeless. You have varying roads, temperature and altitude. I think this new tech might be more accurate than TPMS, how good it will be compared to the evaluation of an experienced driver remains to be seen. |
