01-17-2020, 08:47 PM | #45 | |
Rep 4,976
Current Car: 2018 F80 M3CS, SMB, DCT, ZEC, MPE Recently Departed: 2020 F87 M2C, LBB, ZEC, 6MT (Euro Delivery Aug. 29, 2019, totaled by an idiot in a Camry who then ran from the scene) Wife's Prior Car: 2018 F80 M3, Yas Marina Blue, DCT, Black 19s, Carbon Structure Anthracite Cloth/Leather Combination, Driving Assistance Package (Euro Delivery Oct. 9, 2017) |
KevinM2935.50 |
01-17-2020, 09:23 PM | #46 | |
Rep 433
Clutch pedal has firmed up considerably It now feels just a tiny bit softer than stock, but with greater sensitivity and consistency Will need more seat time to evaluate further Fortunately, I have a track day on Sunday |
Poochie9103.00 |
01-17-2020, 09:40 PM | #47 | |
Rep 433
I definitely think the UCP could help and will more than likely try to order one |
Thescout134944.00 |
01-18-2020, 01:42 AM | #48 | ||
Luxury at the redline :)
9103
Rep 7,563
I figure that would help since the clutch and brakes shares the same brake fluid reservoir, so when you replace the slave cylinder, it can introduce air bubbles into the entire system, not just the clutch line. Your shop did the right thing by bleeding the brakes and slave together, into order to eliminate any possible air from the complete system. Beware DIYers, it's a total bitch if you vehicle is not up on a lift and you have no one to assist with the bleeding process.. |
01-24-2020, 02:18 PM | #49 | ||
Rep 4,541
Drives: 2015 328d xDrive
Anyway, even though the clutch pedal seems a tad lighter, the way the car shifts compared to the way it used to is night and day and I've noticed the benefits of the mod even more today. The car doesn't jerk around and buck sometimes like it used to. Up and downshifting is smooth as hell. It's a BIG difference that I didn't notice as much the day I got it installed when I drove it from the shop back to the house. For me, this is one of those mods I wish I'd done sooner. It's made the car so much more enjoyable to drive. |
NYC Bimmer259.50 gphung193.50 |
01-24-2020, 04:30 PM | #50 | |
9103
Rep 7,563
Vacuum bleeding consist of connecting a hose to the nipple of the slave/caliper's bleed valve and other end submerged in brake fluid. Then pump but keep the reservoir filled with fluid, allowing it to circulate. This pushes fluid through the lines and eliminates any air pockets. If afterwards it still feel light-ish, then I guess maybe it's just the MO of an unrestricted slave.. It's hard to say without testing it myself and making my own hypothesis but what you're concluding sounds logical, that the lack of resistance would make the pedal feel lighter. I'm also only making this assumption because you're the third person to mention a pale feedback, so there might be something to that. |
AndrewC198910910.50 |
01-24-2020, 04:47 PM | #51 |
Rep 4,541
Yeah, that's a good plan. I'll update when that happens.
NYC Bimmer259.50 |
01-27-2020, 11:23 AM | #52 |
Rep 2,104
Just did this over the weekend. Big thanks to Thescout13
My initial thoughts: If the AutoSolutions SSK is an 8.5, and the UCP is a 6, for me, this is a 6. During the first bit of driving, the pedal was definitely softer, especially when you start the shift. At this point, I'd say it's back to OEM feel. To me, this mod is kind of like removing a tumor or a thorn in your side vs buying a new watch or suit. The OEM CDV was 'hurting' me at every single shift. The engagement point always seemed unpredictable (except for first). I really couldn't understand why the car wasn't smooth, despite my best efforts. Now, the car is getting more smooth, because I am having to re-learn the muscle memory a bit. But my body and brain are learning very quickly, as the clutch engagement is relatively linear. In contrast, the SSK is like buying a new suit. The OEM shifter wasn't hurting me, and the new SSK really changed the shifting experience much more dramatically. The CDV delete is more subtle, but perhaps more necessary. I know this is so cliche, but the car really should have come from the factory this way. There is NO need for a CDV. There is need of clutch skill. My guess is that I'll enjoy this more and more as time progresses. BTW, I already had the Ultimate Clutch Pedal installed, and there were no issues bleeding the slave. |
01-27-2020, 11:55 AM | #53 | |
Rep 4,541
While I do love the predictable engagement and find it pretty life-changing, I'm not super happy with the added lightness. It's not terrible or anything but It's definitely a small step backward. I'm currently having the clutch rebled to make sure there are no air pockets, but a part of me thinks the lighter pedal feel is unavoidable and is simply a byproduct of deleting the restrictor valve. Hopefully it stiffens up a little after a rebleed but even if it doesn't this is a great mod that I am definitely keeping. |
NYC Bimmer259.50 Poochie9103.00 |
01-27-2020, 11:59 AM | #54 |
Rep 392
Out of curiosity is replacing the whole slave really easier than pulling the hard line and removing the restrictor like this guy did? https://f30.bimmerpost.com/forums/sh...&postcount=102 It's too cold for me to take a stab at this at the moment so I don't know what it really looks like for clearance under there.
01-27-2020, 12:12 PM | #55 | ||
Rep 2,104
Also, if you have an UCP, you could adjust the spring to the more stiff setting. Come to think of it, I may do that... Quote:
Poochie9103.00 AndrewC198910910.50 |
01-27-2020, 02:18 PM | #56 | |
Rep 4,976
01-27-2020, 03:55 PM | #57 |
Rep 1,646
This strikes me as one of those placebo mods, and reading between the lines doesn't actually improve anything. The stock clutch feels very consistent to me, if a little long at the very top.
01-27-2020, 04:07 PM | #58 |
Rep 4,541
Speaking as someone who has owned and driven their car for 3 years on the stock slave/cdv and recently changed it, I feel like I know what I'm talking about here. I'm telling you right now this isn't a placebo and that a very large noticeable positive change has taken place. If it hadn't done anything I'd have stuck the old part back on and returned/resold the new part. But don't take my word for it, go ahead and try for yourself.
NYC Bimmer259.50 Thescout134944.00 |
01-27-2020, 09:17 PM | #59 | |
Rep 1,646
01-27-2020, 11:42 PM | #60 |
Rep 4,541
The difference is in the way the clutch engages. It has nothing to do with drivers' skill or error. The way the clutch functions with the delay valve in place will make shifts more rough and unpredictable by nature. I've been driving MT my whole life and this is my 3rd 6MT bmw. This car, in particular, is rough shifting sometimes and the cdv is clearly the cause behind it. If you don't see or have a problem shifting then don't do the mod. I very clearly saw issues with the shifting and clutch engagement in this car regardless of how careful I was and this mod solved that immediately. It's not an expensive mod so if you're curious go do it and see for yourself.
NYC Bimmer259.50 Montaver2137.00 |
01-28-2020, 07:49 AM | #61 |
Rep 500
The best way that I can explain it is that, with the unrestricted slave cylinder, the clutch engagement follows the action of your foot at a linear rate. With the CDV, the clutch action lags behind your foot, and not in a consistent or predictable way.
01-28-2020, 09:30 AM | #62 | |
Rep 2,104
The CDV also makes it nearly impossible to stall out of 1st gear. Perhaps BMW was catering to fledgling 6MT drivers, and wanted them to have a good experience; or if this is your first MT car, and you're learning how to drive MT. As mentioned a few times already, it's a very inexpensive mod, so there's little risk in trying it out and making your own conclusions. |
01-28-2020, 10:17 AM | #63 |
Rep 4,541
Just got the car back from the rebleed and the clutch feels stiffer for sure. Still has that initial inch of slight play right at the beginning but it's only apparent if you're looking for it. Not sure if that existed before the mod or not but either way when you go for a normal clutch press at full speed it's not noticeable. Overall it feels as close to the OEM weight as much as I can remember. Definitely glad I rebled, thanks for the suggestion.
01-28-2020, 04:20 PM | #64 | |
Rep 2,104
01-28-2020, 04:37 PM | #65 |
Rep 4,541
NYC Bimmer259.50 RocketBoots1860.00 |
01-28-2020, 08:35 PM | #66 |
Rep 1,646
Alright I'm interested. What's the labor cost and where is the CDV located? One thing I was already considering is the UCP as I think the clutch pedal sits an inch or so too high. Whilst I can shift smoothly there's definitely a 'lag' to the clutch, I definitely have to slow release on the 1-2 but just gotten used to it.
