01-19-2019, 06:39 PM | #1 |
Rep 684
Front left tire always warmer?
I have this nagging issue with the temp sensor. For some reason the temperature of the front left tire is always about 5-7 degrees than the other tires. Cold temperature read seems consistent with the other tires, meaning all tires read same temp out of the garage.
Has anyone else observed this? Is there a reason why there should be more heat transfer from the left side of the engine to the tire? This is not related to sun exposure either. This happened on a cloudy, wet day (today). Appreciate your thoughts and observations. Thanks. |
01-19-2019, 06:56 PM | #2 |
Rep 4,551
Drives: 2015 328d xDrive
NYC Bimmer259.50 |
01-19-2019, 08:23 PM | #5 |
Rep 684
01-20-2019, 06:10 AM | #6 |
Rep 171
At 57 degrees Celsius (134 Fahrenheit) in the evening cool down lap, mines are just a bit warmer , but similar layout (even though I always suspected the Nordschleife track configuration to be the more obvious reason here)
Attachment 1975429 |
01-20-2019, 07:59 AM | #7 | |
Rep 684
01-20-2019, 08:50 AM | #8 | |
Rep 177
01-21-2019, 08:57 AM | #10 | |
Rep 13,097
Spirited drive on the 'Col de Turini' in the French Alps on a warm Summer day (75°C = 167°F | 3.2bar = 46psi) (my usual tire pressure at sea level for cold tires: 2.5bar = 36psi):
///M is art ↔ Artemis
01-21-2019, 08:59 AM | #11 |
Rep 40
It’s not the oil cooler but the auxiliary radiator.
That wheel is hotter for me too, both by touch and by the sensor. It’s more obvious here in Singapore in the stop and go traffic and the heat. |
01-22-2019, 12:52 PM | #12 | |
Rep 171
p.s. there is a huge difference between track tyres and UHP tyres for a very good reason. Last edited by flyaway; 01-22-2019 at 02:33 PM.. |
01-22-2019, 01:41 PM | #13 |
Rep 1,237
Drives: M2 Competition
My front left is hotter too. I always wondered why that is. Now when its colder it is a bit less extensive than when its hotter outside.
