01-09-2019, 04:37 PM | #1 |
Rep 35
Smaller spare tire on rear as temporary solution: risk of LSD damage ?
I got a flat on my rear right stock wheel and without thinking I used a 245/40/18 with 35 psi on the rear right side as a spare and left the stock 265/35/19 with 31psi on the left side. Drove about 18miles at various speeds to get the wheel fixed! All in all have I caused any damage to the lsd!? Thanks! Picture shows difference in diameter!!
Bm
01-09-2019, 07:28 PM | #2 | |
Rep 684
01-10-2019, 12:44 PM | #3 | ||
Rep 35
Bm
01-10-2019, 04:50 PM | #4 |
Rep 6,912
Drives: 2018 M2 AW DCT
I would assume the LSD could take care of the difference in tire size for a limited amount of time without damage.
01-12-2019, 05:01 PM | #5 |
Rep 1,755
You can always put a front on the rear and the spare on the front. Rolling diameter should be the same.
2016 428ix, r, 2018 430iC, 2018 330it
01-24-2019, 06:06 AM | #6 |
Rep 753
01-24-2019, 11:24 PM | #7 |
Rep 3,402
18 miles shouldn't be a problem at all. If you went out and did track days like that where that diff really gets a workout you might have an issue.
01-29-2019, 10:16 AM | #8 |
Rep 538
I'm not sure how the E-Diff works and how it compensates or adjusts but I do know that with the car OFF it is not an LSD...
Not sure how it would then damage the LSD in your scenario as I do not know how the electronics would react or when the lockup is changed. Edit: Interesting.. |
