BIMMERPOST Universal Forums > General Automotive (non-BMW) Talk + Photos/Videos > PSA: Modified exhausts are no longer fix-it tickets in CA
      01-08-2019, 01:28 PM   #89
UltraMagneticAL
Meh
UltraMagneticAL's Avatar
926
Drives: M3CS & Cayman S
2019 BMW M3 CS  [0.00]
2018 X3 M40i  [0.00]
2017 BMW M2  [10.00]
Originally Posted by nioh_lbbm2 View Post
I wonder which exhausts for the M2 meet this restriction. Assuming stock cats of course
i think most exhausts w/ a muffler and stock cats should meet this. 95dB is LOUD
      01-08-2019, 01:40 PM   #90
MONSTAR
#gotboost
MONSTAR's Avatar
Originally Posted by JDTX View Post
What's going on with that 911? :0
Lol he literally said above the picture "crazy bolt on mufflers" for purposes of coming in under the track's decibel limit
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11
2013 F30 328i (12/2015 - 09/2020) SOLD!
      01-08-2019, 01:49 PM   #91
pz619
Drives: F87 M2C 6MT, Tesla 3
The base law hasn't changed, it's just not a correctable violation anymore. The panic is completely overblown in this thread. State referee tests for 95 DB @ 4500 RPM. I know this because I did it not too long ago. Why did I get the ticket? Because I was an asshole to the cop, so he made it tough on me. Also, if you pass the referee test the ticket for loud exhaust gets thrown out.
Also when you get tested they also test for emissions. Based on the amount of catless downpipes I would be far more worried about that.
      01-08-2019, 01:59 PM   #92
werdn
werdn's Avatar
656
Drives: 997.1 GT3 Shark, ex E92 M3 ZCP
California Exhaust Law
It is illegal to have any modified exhaust and stock exhaust louder than 95dB in California now!
http://www.thedrive.com/news/25799/c...ine-you-for-it
Please sign petition for all us Californians!!!
https://www.change.org/p/nullify-fin...4105273-1%3Av2
      01-08-2019, 02:02 PM   #93
werdn
werdn's Avatar
656
AB 1824 -- Fine for loud vehicle exhausts
Drivers in a vehicle or motorcycle with an excessively loud exhaust will be fined. Previously, they would have been cited with a “fix-it” ticket.
      01-08-2019, 02:18 PM   #94
avex8
avex8's Avatar
324
Drives: 11 E92 m3, 15 F80 M3, GLC 63
The goal was 50k votes, why the goal is 150k now?
      01-08-2019, 02:21 PM   #95
VDMTom
Drives: M3CX
Who knows, but I'm pretty damn sure it will still not work lol
essjon1136.50
      01-08-2019, 02:23 PM   #96
RickFLM4
RickFLM4's Avatar
Drives: M4
What's the point of the change.org petition? How will getting out of state people to sign it help?
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
      01-08-2019, 02:23 PM   #97
damageprone
Drives: Tesla
Wow...even stock? Time to delete that cold start.
      01-08-2019, 03:26 PM   #98
COKen
COKen's Avatar
981
Drives: M Rster / Z4 M40i / X5 M50i
Originally Posted by Billfitz View Post
At what distance? SPL goes down by 6dB with each doubling of distance from the source, up by 6dB with each halving of distance. At what RPM? Idle, midrange or full throttle? Is that an A-weighted or C-weighted result? In the low frequencies there can be as much as a 50dB difference between the two. Your eardrums can be pounded into mush by low bass while an A-weighted meter won't even register it. These are just a few of the variables that make a simple statute unenforceable.
The chart I was quoting was (I think) using the standard of 50 feet and the motor running at normal cutting speed (high rpms). No real detail was given. Not sure if the CA law set some other standard or not, but 50 feet from the source is what should be used. Wind is another variable which can't be controlled in the open environments where cars operate.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg
2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
      01-08-2019, 03:46 PM   #99
pz619
Your stock exhaust is no where near the 95 db limit. In fact, unless you go muffler delete and test pipe, you likely won't be at 95 db.
Also testing is done at 4500 RPM, not WOT or high RPMs.
      01-08-2019, 03:48 PM   #100
pz619
It's always been illegal. The only difference now is that it's no longer a "fix it" violation. If you didn't get a ticket prior, it's not going to be a problem now.
      01-08-2019, 03:53 PM   #101
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
94dB at 50 feet is 120dB at the operator position. 120dBA would cause permanent hearing loss after about one lawn.
      01-08-2019, 03:55 PM   #102
goj
goj's Avatar
Drives: 2016 EBII 340i 6-MT
Hopefully this reduces the urge of people to decat and straight pipe their car at the same time. It's not a good sound. Some people think louder is better when that's just plain dumb
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04
Instagram: @brandons340i
      01-08-2019, 04:35 PM   #103
BayE30
Drives: 2011.75 E90 M3 ZCP
LMAO @ all the guys running burble tunes...
I am never able to post pictures on forums, all my pics are on IG @baye30 https://www.instagram.com/baye30/
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V]
      01-08-2019, 04:43 PM   #104
damageprone
Drives: Tesla
I only say that because I have a port installed MPE, and it sounds like it's louder than 95 db at cold start, but then again, I don't have a decimeter. Not that any of this matters to me anymore...haha
pz6193278.50
      01-08-2019, 05:01 PM   #105
pz619
I'm sure you are fine. Also, you can always run the test in efficient mode which should keep 2 of those valves closed. The car that I tested had an aftermarket exhaust and ran a 82 DB, which honestly I felt was way too quiet. But I took my certificate and ran.
s021199.00
      01-08-2019, 05:04 PM   #106
afadeev
afadeev's Avatar
1163
Drives: F80 M3
Originally Posted by positiveions View Post
So CHP will target exhaust modification but won’t target speeders at 90mph+, pipe smokers and bottle drinkers that actually kill people. Is there something wrong with this picture?
Nope - local municipalities need the money, the rest are just creative pretexts.
Californians are just like their taxes more than the rest of us:
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS)
ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's
      01-08-2019, 05:11 PM   #107
Drunkm0nk3y
Drives: 2022 X5 40i Msport
My understanding of the law -- the old way was a fix-it ticket for a loud exhaust, and the new way is just a regular non-correctable ticket IE Police cannot write it off. it becomes a state ref fix, along with 1k fine. not sure if it gets state ref fix you dont pay the 1k fine.
So i would assume if your exhaust is Carb / Cali compliant and under 95dbs you are good. Reminds me of when the Dodge SRT4s came out back in the 00's folks were getting pulled over for the stock exhaust.
still sucks though.
      01-08-2019, 06:30 PM   #108
greasypeanut
Drives: F87
Do people even know how loud 95db is? DB scale is logarithmic but for comparison, 90 dB according to something I quickly found on Google from Purdue University is a jackhammer, for 100 dB they're using aircraft and helicopters to describe the sound. 80db is where damage starts to happen with prolonged exposure
The majority of everyone's modified exhausts on here are not close to that 95db limit
      01-08-2019, 06:32 PM   #109
pz619
100% this. If your exhaust is comparable to a plane taking off, you deserve the ticket.
      01-08-2019, 06:44 PM   #110
Snoball M3
Snoball M3's Avatar
Drives: 2008 328i MB Sedan/11.5 ZCP M3
BM  [0.00]
Looks like they've started a petition for it.
https://www.change.org/p/nullify-fin...-in-california
2008 328I MB M-Sport E90
2011.5 E90 AW ZCP M3
1965 C-10 SWB (bagged)
chief208.00
