12-17-2018, 08:17 PM | #24 | |
Rep 538
This is assuming it's the pcv and not another seal further up which failed causing the same symptoms. I'm not S55 expert but maybe it's worse after break in and not quite as bad later (I'll find out). Also - the valvetronic V3 is crazy compact! My buddy and I (not S55 familiar) weren't even sure it had it at first. We also stared at the boomerang carbon fiber "strut brace" and just can't seem to figure out how it does anything. Can someone explain the physics? There is an aluminum piece under the shrouding that does connect and actually even connects up at the firewall as well (weak?). But not sure how the carbon piece is really adding rigidity the way it's mounted/shaped etc. Some other observations; The extra triangulated gusseting supports are pretty neat. The bane of my existence electric power steering (manual rack swap would be great) Looks like the gap in bodywork and headlight feed to intakes? I had to adjust the felt on a power junction to keep it from chaffing. One of the larger gauged wires does chaff (sp?) but luckily bmw put a plastic guard there do you don't burn your car down.. Nice electrical tape.. The almond paste looking corrosion coating is sweet. There is also a lack of sound deadening in many places BMW formerly installed which is interesting considering how quiet the car is with windows up in comfort and ASD disabled. Last edited by Proctor750; 12-17-2018 at 08:48 PM.. |
Poochie9104.50 |
12-17-2018, 08:43 PM | #25 |
Rep 573
Ditto. This has only been a problem for me in a straight line. I have yet to have hop when making donuts or U-turns.
12-17-2018, 08:48 PM | #26 | |
Luxury at the redline :)
9105
Rep 7,563
Of course, saying anything that might be remotely interpreted as negative about the sanctimonious M2C here is considered blasphemy and will be followed by subliminal verbal attacks and being labeled as a "troll" so I kept it to myself, even if it's blatantly obvious.. |
///M Houbi1655.00 |
12-17-2018, 09:31 PM | #27 | |
Rep 1,015
I recall the same thing on my 2016 M2. Last edited by 3tekcorps; 12-18-2018 at 01:54 AM.. |
12-17-2018, 10:27 PM | #28 |
9105
Rep 7,563
WoW, the S55 turbos are smaller than I expected but it's ok; a beautiful woman once told me that size doesn't matter, while crossing her fingers...
I'm pretty sure she was telling the truth.. |
12-18-2018, 01:35 AM | #29 |
S0THPAW
8716
Rep 7,846
About wheelhop. I got that sometimes with my ex 1M and Michelin PS2. Annoying I remember.
Some say it's because of that type of tyre. Grippy summertyres on dry surface because in the wet no problem off course, wheelspin galore. But half wet wheelhop occurred also. Why should it be an LSD thing in the first place and not the PSS (In my case) Just asking. Cheers Robin |
12-18-2018, 02:32 AM | #30 | ||
Rep 3,659
Drives: 981 Cayman GTS
Found a solid explanation by CanAutM3 (as always ) that is inline with what I used to experience in my M4:
12-18-2018, 04:17 AM | #31 | |
844
Rep 1,962
12-18-2018, 05:04 AM | #32 | |
844
Rep 1,962
12-18-2018, 05:51 AM | #33 | ||
9105
Rep 7,563
It's probably light as styrofoam and it can't and doesn't take any brunt of the twisting forces. The alloy brace would have to bend first before the carbon fiber piece kicks in as 'reinforcement.' And that's never going to happen unless the vehicle is in a major side-impact collision, which moots any supposed purpose.. I know you guys just love it to death and is going to defend its purpose to the bitter end but it's pretty obvious that the alloy brace is doing all the work but the carbon fiber piece is there to take all the credit.. Reminds me of my manager... |
4
12-18-2018, 06:21 AM | #34 |
9105
Rep 7,563
Skimming through the old Bimmerpost archives, it appears the pre-LCI F82 M4 was tuned, stock, to be tail-happy and suffered from many cases of wheel hop.
On later iterations of the M4, BMW turned down the spiky front-heavy tune, making it more progressive throughout the RPM band to help with this and to make the power more manageable i.e. less 'low end torque' Keeping with this trend, it explains why in the newer BMW M2C they "weight optimized" the the boost to help alleviate this and similar launching issues.. It seems that it's a known problem but proper right foot pedal modulation and proper season-appropriate tires will help to minimize it. |
Robin_NL8716.00 |
12-18-2018, 06:35 AM | #35 |
Rep 3,333
Wheel hop is a massively complicated non-linear vibrations problem in a car with IRS. *ALL* IRS cars are susceptible to wheel hop vibration, and since tires are a significant portion of the equation, varying them along with tread depth, rubber thermo-oxidative aging (heat cycles), along with the road surface, etc,etc all will change the dynamic response of the chassis (like how on a certain dry road you might be able to lay down 50' of rubber cleanly but come back when the road is wet and get wheel hop like crazy).
If you go about changing bushing stiffness, you'll simply change the frequency where the oscillation occurs. It's actually a really cool vibrations problem to analyze since so many aspects of car's suspension and the chassis (body-in-white) and subframe properties are all part of it. That wind-up/release forcing function CanAutM3 refers to is one of amazing parts of the equation, and is very difficult to model. The best solution so far was found by Cadillac during the 2nd gen CTSV development a number of years ago and involves having halfshafts of different torsional rigidity. When you properly size the differing polar moments of inertia of the two halfshafts, it allows different levels of dynamic torsional deflection...which nicely eliminates (or greatly reduces) the wheel hop wind-up condition in the system.
Current Stable:
akkando5863.00 |
12-18-2018, 06:44 AM | #36 | |
9105
Rep 7,563
12-18-2018, 06:51 AM | #37 |
Rep 3,333
No, the LSD has nothing to do with varying levels of torsional deflection on each side. Power distribution is unchanged in the Cadillac solution. It allows a transient variation in in rotational stiffness on each side of the IRS. There is now way to simulate such with any design of the differential/LSD. Completely different animals.
Current Stable:
Poochie9104.50 |
12-18-2018, 08:59 AM | #39 | |
844
Rep 1,962
The original item in the M235i Racing must have been there for a reason - whether that applies in the M3/4 and M2C is up for grabs. Last edited by M Fifty; 12-18-2018 at 10:46 AM.. |
12-18-2018, 09:49 AM | #40 | ||
Rep 538
Are you saying the M235i (R) has the carbon strut brace? I don't remember seeing that when I last saw one and isn't it specific for S55? |
12-18-2018, 10:46 AM | #41 | |
844
Rep 1,962
https://www.realoem.com/bmw/enUS/sho...diagId=51_9764 |
12-18-2018, 11:30 AM | #42 | |
Rep 538
The last thing I want is piston boots like this guy (cts V) after only 2 months needing a rebuild (thanks to the bus stop and turn 1 at wg): |
12-18-2018, 11:33 AM | #43 |
Rep 3,333
Use Ti shims between the piston and backing plate and also don't run race pad thickness below about 1/3 of new...
Current Stable:
Proctor750426.00 |
12-21-2018, 05:40 PM | #44 |
Rep 1,015
Feels like there's a lot of flex in the drivetrain to me. My 1st -> 2nd shifts are not very smooth when getting back into power like there's some excessive flex somewhere.
Anyone else have slopping 1st/2nd shifts? I've rowed a lot of gears in my life and don't recall this before. |
