04-19-2018, 10:10 PM | #2 |
Rep 4,551
Drives: 2015 328d xDrive
I think our current 4 piston fronts can be moved to the rear without any modifications needed, so it's just a question of if the new 6 piston calipers and rotors from the M2C will be plug and play on our cars, which I believe they should be. The M2/M3/M4 all share the same brakes and It would seem illogical from a financial standpoint for bmw to have completely redesigned them from the ground up just for the M2C. My guess is they just took the M5 rotors and calipers and modified them to fit our cars. But you never know, I guess we'll have to wait and see.
NYC Bimmer259.50 |
04-19-2018, 10:14 PM | #3 |
Rep 52
Yeah that's what I figured, I know the M3/M4 CCB's can be swapped to ours so it seems logical to assume the new M2C brakes can be but who knows
04-19-2018, 10:33 PM | #5 |
Rep 4,551
Probably also yes but I personally have little interest in them. They will most likely cost something outrageous like $3000. I'm getting that number based on what the e92 m3 mirrors cost when I tried to buy them for my e92 335i many years ago. If they really are that much, then it's a big no for me. I'd much rather put that money into the front brakes or some new seats.
NYC Bimmer259.50 |
04-20-2018, 03:54 AM | #7 |
Rep 3,402
Different diameter rotors so I suspect it would take some work to get them to fit. You would be better off getting an AP Racing setup if your looking for track performance. Essex has some good videos on how the Brembos hold up to track conditions.
04-20-2018, 05:54 AM | #8 |
Rep 47
With decent pads the std brakes should be fine I think.
Given our cars hubs/ brakes etc are carried over form the M4, I can't see why the carbon ceramic option would fit our cars and that comes with 6 piston calipers (funds allowing!). I'm still learning all things M2, so don't shoot me down if I'm wrong! Given BMWs previous history with brakes though, APs are the way to go for proper performance. Having said that, our cars are Brembo calipers I think so if other companies can get them to work well, why can't BMW? I personally think it's mostly down to pad choice and the std pads are a compromise for road use, where they're mainly fine. |
04-20-2018, 08:30 AM | #9 |
Rep 52
Oh yeah, with track pads the stock brakes are great on the track in my experience.
I was just wondering if it'd be a simple swap if I could get my hands on a take-off set and save some $$ over aftermarket! Plus I think they look pretty slick |
04-20-2018, 09:12 AM | #10 | ||
Rep 4,551
Also buying just the M2C front brakes and swapping the stock fronts to the rear will be a hell of a lot cheaper than buying an aftermarket set from AP racing, brembo etc. I'm not concerned with track performance since my car is only used on the street. |
4
04-20-2018, 09:32 AM | #11 |
Luxury at the redline :)
9105
Rep 7,563
You'll are lucky, those 6 piston brakes will fit flush on current M2; the most you might need is new backing plates and coding.. I would jump on those, whenever it's available.
Speaking on that; roughly when would OEM replacement parts be available for the Comp.? |
04-20-2018, 09:49 AM | #13 |
9105
Rep 7,563
Cool, you think you might need to re-code it? I mean it is 2 extra pistons, the booster might need to know it needs extra pressure..
04-20-2018, 09:58 AM | #14 | |
Rep 4,551
"this retrofit is using the same standard OEM brake booster for iron rotors with no coding changes as the standard 4/2-piston iron setup. No need to code/replace the booster for CCB calipers as in the OEM CCB retrofit kit as the coding is to adjust the CCB booster to the friction of the CCB rotors, which is different from the friction of the iron rotors. So no no need to code/replace the standard brake booster for iron rotors for these calipers." http://www.bimmerfest.com/forums/sho...d.php?t=884981 |
Poochie9104.50 |
04-20-2018, 11:42 AM | #15 |
Rep 444
Drives: 2017 M2 6MT, 2022 X7 M50i
Are you guys upgrading for the looks?
04-20-2018, 11:58 AM | #16 |
Rep 4,551
Both for the looks and the decent increase in stopping power. Again, not tracking the car so form over function for me personally. I'm aware others take performance more seriously.
04-20-2018, 01:07 PM | #17 |
Rep 660
Just curious, but performance-wise, isn't braking power usually limited by wheel traction/ABS?
04-20-2018, 01:13 PM | #18 |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
Various factors, those included... but the reason to go to more pistons / bigger rotors is heat capacity or the ability to shed it. This is what helps brakes hold up to track abuse.
04-20-2018, 01:14 PM | #19 |
Rep 351
What about brake bias? Are you sure the piston sizes in the current M2 front rotors are the same size as the rear 4 piston that is available on the M2C?
04-20-2018, 01:30 PM | #20 | ||
Rep 4,551
Again, this is mostly a cosmetic thing for me. I think a 6/4 would look way better than a 4/2. Also gives me a reason to paint the calipers polar blue so I can show them off |
04-20-2018, 01:56 PM | #21 |
Rep 3,949
With the stock tire sizes this upgrade will do nothing for you on the street. This is just for looks. If you increase tire to road traction then you may see some improvement. Plus this brake upgrade increases unsprung weight. Now if tracking, its a different story but you will still probably need a track pad. I am wondering if BMW added much needed brake ducts, that's what I would go for and better pads on the stock set up. Plus I wonder what color the gray calipers will turn once they get really hot on track a few times.
04-20-2018, 02:03 PM | #22 | |
Rep 3,659
Drives: 981 Cayman GTS
