10-03-2015, 10:46 AM | #222 |
Rep 2,337
Pretty sure the z4 and 335 -is models got the n54 with slightly different tuning (z4 same hp as 1m). The 135is got the n55 with mppk and dct though.
10-03-2015, 10:57 AM | #223 |
Dinosaur supervisor
3030
Rep 4,214
Yes, as the name TwinPower means it uses a turbo and something else... So whatever turbo setup it has it is only one part of he TwinPower name. The other is for example Valvetronic etc.
10-03-2015, 11:42 AM | #224 | |
Rep 450
Would there be an example of an engine model number with single scroll that is referred to as "TwinPower"? http://www.bmw.com/com/en/insights/t...echnology.html
'74 2002tii, Sienna Braun Metallic, Manual, Sold; '84 e28 533i, Burgundrot Metallic, Manual, Sold; '95 e36 M3, Avus Blau Metallic, Manual, Sold; '06 e60 M5, Silver Grau Metallic, SMG, Sold; '09 e82 135i MSport, LeMans Blue, Manual, Sold
10-03-2015, 12:08 PM | #225 | ||
Rep 1,644
10-03-2015, 12:13 PM | #226 | |
Rep 846
My contention is that the N55 upgrade in the M2 results in a motor that is more modern (Valvetronic) and will be capable of handling more boost reliably over a longer time span than the N54 with its open deck design. What the turbo on the N55B30TO will be able to generate efficiently won't be known until it hits the market and the tinkerers start tinkering but the prospect of a mild turbo upgrade on it just got much brighter |
10-03-2015, 12:38 PM | #227 | |
Rep 1,026
10-03-2015, 02:21 PM | #228 |
Rep 450
You're correct.
10-03-2015, 06:33 PM | #229 | |
Rep 2,402
So again, even if your assumption was somehow supported, how is it relevant? How freaking strong does it need to be before it's all a wash? That's the beauty of all of these engines...you don't have to worry about the bottom ends. Literally none of them. N54, old N55, new N55...they're all very well built, with plenty of strength to handle big power over stock. If an old N55 can hold 500 bhp, literally forever, and the new one can hold 600 bhp, forever...and you're going to run it at 400 bhp, then how the heck is the difference relevant beyond dick swinging on the internet?
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) Last edited by PrematureApex; 10-03-2015 at 06:42 PM.. |
10-03-2015, 06:51 PM | #230 |
Rep 2,402
I mean, the forged crank is a good thing. We'll all take it. It's a sign they gave the car more attention than some of us thinking they may have.
But be realistic here. Some people are getting VERY excited about the strengthening of a part that didn't need any strengthening to be reliable. Take a breath.
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
10-04-2015, 09:32 AM | #231 | |
Rep 846
You might be in a position to be better informed on the potential and longevity of these engines (N54/N55) than I am. I only see what goes through our service shop, what I read on the net and what the guys on our race team opine. While I modified my N54 and never had a single issue with it, I have yet to play with the N55. However, if the strength and reliability of the N55 is good for 500hp as you say, then BMW is going through a considerable amount of time and treasure to strengthen the bottom end and block just for kicks ?! |
10-04-2015, 11:39 PM | #232 |
Rep 1,349
Drives: BMW F80 M3
Just FYI the N55 in M135/M235 models has a forged crank.
10-05-2015, 12:01 AM | #233 |
Rep 2,505
The n54 did a lot of harm than good IMO. Lots of people that I know would not buy another BMW again due to having 4+ high pressure fuel pumps go out. Yeah maybe the engine is solid but your average joe looks at the entire engine and make as a whole.
The n54 seemed of gotten fixed when the 1M got released. That means what ever flaws the N55 had will be fixed for the M2. |
10-05-2015, 12:08 PM | #234 | |
7906
Rep 11,785
"Average Joe " should also realize that BMW doesn't make fuel pumps.. right? Just because a VENDOR supplies BMW with a bad part... doesn't mean " Joe " should throw BMW out with the bathwater either. It doesn't surprise me that if you had one failed fuel pump that you had four... because more than likely they were installing the same pump again.. Until A new vendor (or the current vendor corrects the issue) can be found to create the part... produce it... and get it to BMW... there is nothing that can be done other than install another of the same bad part. Not to mention... hundreds of parts in the supply chain eventually need to be replaced........ Speaking of bad parts... there was an issue with oil pumps on the S54 motors that came in the E46... Same deal.. BMW reacted by extending motor warranties... because the oil pumps could fail and take out the motor... As opposed to a failed fuel pump which just won't allow the car to start in your driveway. Glad you are back... because it would really be silly to " cut off your own nose " to spite BMW's face because of a vendor part issue.. Last edited by M3 Adjuster; 10-05-2015 at 12:25 PM.. |
10-05-2015, 12:23 PM | #235 |
Rep 2,402
We've already been over that. Cite a source.
10-05-2015, 01:50 PM | #236 |
Rep 1,349
Drives: BMW F80 M3
Here is the crank part nr on realoem for 335i and a whole bunch of other models:
http://www.realoem.com/bmw/enUS/part...&q=11212163665 11212163665 AT-CRANKSHAFT WITH BEARING SHELLS From:09/01/2009To:-Weight:20.000 kg Then for M135i/M235i it has a different part nr and is 3kg more heavy: http://www.realoem.com/bmw/enUS/part...&q=11212334334 11212334334 AT-CRANKSHAFT WITH BEARING SHELLS From:07/02/2012To:-Weight:23.000 kg |
10-05-2015, 01:56 PM | #237 | |
Rep 1,644
10-05-2015, 02:00 PM | #238 |
Rep 1,349
Drives: BMW F80 M3
Yes I know that. I got it actually from my source in Germany working close with BMW on their engines. But believe whatever you want to believe
10-05-2015, 02:04 PM | #239 |
Rep 8,165
I've been told by a guy working for a company making engine components in Germany that BMW saves quite a lot of money per one N55 in comparison to the N54. Can't remember the exact amount, though. I was surprised.
10-05-2015, 07:17 PM | #240 |
Rep 2,402
We asked for a source, you gave proof of nothing but a different part number.
10-05-2015, 07:20 PM | #241 | |
Rep 2,402
Not that we need to start this discussion, but it's amazing BMW owners weren't more pissed when they yanked out the N54, gave them a less potent N55 (don't get me wrong, I love my N55 too) with a misleading "twinpower" label on it, and left pricing the same.
10-05-2015, 08:32 PM | #242 | |
Rep 1,026
