09-09-2019, 11:45 AM | #23 |
Rep 1,237
Drives: M2 Competition
Spacers below 10mm do not have a centering. So basically they are no option then imho.... not with such a car.
But to each its own as they say 🙂
09-09-2019, 07:28 PM | #24 | |
756
Rep 2,149
https://www.turnermotorsport.com/BMW...-wheel-spacers Also, hubcentric rings never bear any load. They are simply used to make it easier to align the wheel during mounting. Even OEM isn't thick enough to bear load of the vehicle. The weight of the vehicle is supported by the hub and wheel faces by friction created by the lug nuts. Last edited by Anthony1s; 09-09-2019 at 07:39 PM.. |
09-10-2019, 09:07 AM | #25 |
never could compete with Lloyd Braun
5272
Rep 5,378
I did Turner 7.5mm all around lowered on Eibach springs. The fronts could probably go 10mm to be more flush but I heard of people rubbing in the front on 10mm so I stayed with the 7.5mm... don't feel like dealing with rubbing issues as this is my daily.
2022 G80 M3 6MT | Skyscraper Gray | Kyalami Orange
2018 F87 M2 6MT | Alpine White (sold) 2016 981 Cayman 6MT | Jet Black (sold) 2015 F80 M3 DCT | Tanzanite Blue | Gold Brown (sold) 2013 E92 M3 6MT | Mineral White | Fox Red/Black (sold) |
FreeDarko217.00 jessetaylor1171.00 |
09-13-2019, 06:58 AM | #27 |
5272
Rep 5,378
ask and you shall receive
If you want any others from specific angles let me know!
MASHCT616.50 |
09-14-2019, 12:26 PM | #29 |
Rep 4,154
Drives: 1/18 Monte Carlo Blue E92 M3
I ended up going with 10mm/12mm spacers on the M2C. Been running them for a month at least and no issues now.
09-14-2019, 02:00 PM | #30 | |
Rep 103
Suspensión specs? Rear rubs? Thanks |
09-14-2019, 02:02 PM | #31 |
Rep 4,541
Drives: 2015 328d xDrive
KW HAS + 4x 15mm spacers. No rear rub. Some front rub on large dips but no tire wear or fender damage.
NYC Bimmer259.50 |
09-14-2019, 02:49 PM | #32 |
2528
Rep 1,908
If one went with 12F/10R or 15F/12R spacer combo (stock wheels/tires), seems stock bolts would need to replaced with longer bolts?
If so, do the longer bolts come with the spacers, or need to be purchased separately? |
09-14-2019, 08:14 PM | #34 | |
2528
Rep 1,908
I did look at the Turner offerings on their website, and according to my specific vehicle (M2C). Perhaps the detail I am after escaped me when reviewing the product description, but I found no mention of spacers being equipped with bolts. Am I to assume the spacers do not require longer bolts, or that the bolts need to be purchased separately? Thank you ///AVM |
09-14-2019, 08:39 PM | #35 | |
756
Rep 2,149
09-15-2019, 01:18 PM | #37 |
6629
Rep 4,145
Drives: '18 M2 6MT
$116 each? Wow. It says "Spacers", but I can't find where it says if there are 1 or 2 for that $116. And 10 wheel bolts for $4.95? What am I missing there?? Terrible website.
MASHCT616.50 |
09-15-2019, 02:58 PM | #38 | |
756
Rep 2,149
The spacer quantity is for a set of 2 spacers, as pictured (1). The bolt quantity is telling you how many will be added to the cart when you press select (10)... also consistent with the picture. Both numbers and pictures mean, do, and show the exact same thing. I do not see any inconsistency at all. |
JTO245271.50 |
09-15-2019, 07:11 PM | #39 | |
6629
Rep 4,145
Drives: '18 M2 6MT
MASHCT616.50 MarlboroM2C237.00 |
09-15-2019, 07:56 PM | #41 |
6629
Rep 4,145
Drives: '18 M2 6MT
For me? A picture of one spacer and a quantity drop-down, or something that obviously said spacers were sold in pairs. Once the spacer quantity was selected and the buy-button pressed a pop-up notification about requiring longer lug bolts, a picture of 1 lug bolt populated and a quantity drop-down.
09-16-2019, 03:54 PM | #42 |
Rep 23
I am running 10mm all around. Got the spacers from IND/ Future classic
https://ind-distribution.com/collect...r-kit-14mm-lug I personally like how the spacers secures to the hub directly with a hub bolt. It is also hub centric and it comes with longer bolts |
///M Houbi1653.00 FreeDarko217.00 |
09-17-2019, 05:00 PM | #43 | |
Rep 632
