M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > THE ULTIMATE Intercooler Thread - What to Look For Before Buying an FMIC
      03-04-2020, 10:44 AM   #463
cecaa850
Originally Posted by AmuroRay View Post
I’ve narrowed my search down to 2 intercoolers - 3 maybe.
ER - the prior best intercooler. You don’t hear about it much anymore, but I’ve never seen anything bad about it, or anything compared to it really.
VRSF 6.5 and/or Race - Not sure this is the same, but these just get things done. They are old school. No rounded end ranks, or fancy design. It’s straight up big and that’s how the job gets done. It’s also cheaper.
ATM/CSF - I’ve read a ton. The most track worthy, holds records for fastest N55 (until recently I believe - I’m tired, I was up all night reading) the ATM should flow better and have less lag than the CSF, both are better than the Evo 2 from every test I’ve seen. Also cheaper.
Why not:
AA - too small. (Goes for all 5”cores)
eBay - Garbage
Wagner - Evo 3 has no test, the Evo 2 is outright inferior to the others mention in absolute cooling. Even the claimed faster recovery doesn’t measure up on the track where it heats up quicker and higher than the rest, and it’s smaller meaning it’s absolute ability to hold heat is lower.
Do88 - same as the Wagner. It’s better in terms of absolutes keeping temps, but it was 5* vs 10* or so for the ATM/CSF. No reason to buy this over the other more capable options.
Now you need to decide if you want to pull the front bumper cover and/or modify or remove the front brace prior to making your decision. Some require it, some don't.
243Racing1447.50
TemjinX2520.50
      03-04-2020, 10:46 AM   #464
243Racing
1448
Originally Posted by Tiago@VRSF View Post
<snip>
I PM'd you.
      03-04-2020, 11:08 AM   #465
AmuroRay
AmuroRay's Avatar
2268
Drives: M235i
Originally Posted by ZM2 View Post
Just a note that I haven’t seen the M2 listed as an application for the ATM.
I’ll also make the same comment here that I did on the F30 board. Point is, the best IC for someone is the one that has the best blend of characteristics for their use, not just cooling capacity.
For me, a 10F IAT improvement isn’t going to make much of an impact for guys running Emixes on track. I wouldn’t trade to a 5-10lb heavier IC with worse throttle response to gain what would only be a few hp on an Emix tune on track.
If you run 93 octane on track, then the 10F difference will be noticeable on hot days.
To get a 20F+ difference over the Evo 2 Comp we’re talking about needing a massive IC, all of which are going to be 30lbs+. I haven’t seen that any of the massive bar/plate IC’s have that kind of performance gain without making lag even worse.
Apparently the Evo 3 achieves all these things from Wagner’s data, but no one knows why it will fit the M235i and not the M2.
You’re not going to notice 10lbs, but you will notice your car overheating and pulling power. I saw you changed from the Dinan? Or Do88 to the Wagner to run into the same overheating issues on the track that you had before, despite running a lower cell count on downpipe. The Wagner is just smaller than the others, and every post I saw of people actually running them at the track shows they just don’t perform as well as the others.
On the street, I think it might be a great choice due to the claimed superior throttle response, and the less demanding needs.
      03-04-2020, 11:10 AM   #466
AmuroRay
AmuroRay's Avatar
2268
Drives: M235i
Please stop spreading mis-information. The VRSF 6.5" Competition HD along with the 6.5" Race FMIC were both designed using CFD analysis and both incorporate incredibly efficient cast end tanks. The fin packs were specifically engineered to provide the best balance between external cooling and internal flow. There's nothing old school about our intercoolers
The VRSF 6.5" Race will outcool EVERY intercooler you've listed and it's currently featured on both the fastest N55 powered car along with the highest horsepower. It's less expensive because we don't slap on a BMW tax like the other brands mentioned.
Here's a 2nd through 4th gear pull with our 6.5" Race FMIC. The starting temp is 89 degrees and ends at 86 degrees. 3 degrees lower than the initial starting temp.
Here's another set of logs from a customer who upgraded to the VRSF 6.5" Race FMIC from the Wagner Evo 2. He was seeing a 75 degree increase (37F - 112F) with the Wagner Evo 2 on a 2-5 gear pull where the VRSF only saw a 39 degree increase (50F to 89F).
Impressive stuff. I’ll admit that I got confused looking at the VRSF stuff and wasn’t sure if the 6” and the race were the same.
Any data on pressure drop/throttle response? How modifications needed to install it? Running any sales?
243Racing1447.50
      03-04-2020, 01:03 PM   #467
ZM2
Drives: 2017 LBB M2
I'll forgive you for not knowing the exact details of my upgrade and track testing path, as there are numerous posts to sift thru.
The general consensus on my overheating issue is it is oil temp related, and will require some custom oil cooler work, similar to what the Tyspeed guys did.
As for IATs, the Evo 2 Comp did perform better than the Dinan, even while I increased power significantly from Dinantronics to BM3 Stg 2H E30. If you run an Emix on track, the impact from any increase in IATs, including timing pull, is reduced. You can see this in the many 93 octane, 100 octane, and various Emix logs I've posted.
So, I'm not willing to give up my better throttle response during the 75% of time I drive my car on the street, vs reducing IATs by 10F during the 25% of time I'm on track bc the impact of 10F when running an Emix really isn't noticeable.
My interest in all this reemerged when the Evo 3 came out b/c it seemed to give the best of everything, but it apparently doesn't fit the M2 and I haven't seen any independent testing.
If someone who's had an Evo 2 Comp could chime in independently regarding their experiences jumping to the CSF or VRSF IC's, and can show that they reduced IATs by an additional 20F over the Wagner during a 30-45-min 95F+ summer track day, and they can say subjectively that they don't notice worse throttle response when on/off the gas in stop & go traffic, then I'm all ears.
Unfortunately, it sounds like I may need to be that guinea pig, unless a forum member can pipe up.
243Racing1447.50
      03-04-2020, 01:52 PM   #468
cecaa850
Everything I listed is plug and play. The VRSF 6” may not cool as well as the others, but it is cheap.
How do you define plug and play? To me plug and play is no modifications.
243Racing1447.50
Wattens59.00
      03-04-2020, 02:00 PM   #469
cecaa850
https://f87.bimmerpost.com/forums/sh....php?t=1654219
ZM22810.50
      03-04-2020, 02:15 PM   #470
AmuroRay
AmuroRay's Avatar
2268
Drives: M235i
I read you posts in detail multiple times, including last night. Yes, your temp increases were more gradual - but that was because you are running a flash tune vs piggyback and a lower cell count on the catalyst (Which drops egts) I’m saying this as definitive fact - it’s not as good of a track intercooler as the others. It’s physically smaller, and every review against similar coolers (the VRSF one featured above) proves there is PLENTY left to improve.
I agree, for the street it’s great. I’ve been looking for a new cooler and I don’t want excess lag myself, because I daily drive the car. But I personally can’t justify paying more for a less capable (in absolute sense) intercooler because of what may amount to an imperceivable amount of lag. Again, that’s just me. If it were major lag spikes (like I heard the CFS caused on the single scroll turbo that FaRKle! runs) yeah, I might be more inclined to lean in that direction.
I’m just curious about this VRSF one now, because it’s on sale - and it’s god plenty of headroom for my needs. I hope to be tracking the car more frequently and don’t want to run into IAT issues.
      03-04-2020, 02:18 PM   #471
AmuroRay
AmuroRay's Avatar
2268
Drives: M235i
Originally Posted by cecaa850 View Post
Thank you for this! Is it a 6.5” or 6” did you sell it already?
      03-04-2020, 02:44 PM   #472
cecaa850
6.5 and sold it. Put in a CSF and couldn't be happier. I made sure the buyer had all the info about fitment prior to selling it.
243Racing1447.50
      03-04-2020, 03:06 PM   #473
ZM2
Drives: 2017 LBB M2
And all this is why I want the Evo 3 to work. I’ll keep dreaming, or order it and try it, or have them do a custom one.
      03-04-2020, 03:11 PM   #474
243Racing
1448
Did the CSF fit without any modifications?
      03-04-2020, 03:22 PM   #475
AmuroRay
AmuroRay's Avatar
2268
Drives: M235i
CSF and ATM are the same - the difference is that ATM is the original and uses a single core and CFS is a ‘clone’ that is basically 2 cores put together. The CFS is said to have a bit more lag. FaRKle! tested them both, ask him for feedback.
243Racing1447.50
      03-04-2020, 03:24 PM   #476
AmuroRay
AmuroRay's Avatar
2268
Drives: M235i
Please do! I kinda want to live vicariously though you guys lol. If it doesn’t work, I guess you can return it, right?
ZM22810.50
      03-04-2020, 03:32 PM   #477
cecaa850
Yes. No perceptible lag that I can feel however I've tuned my car.
TemjinX2520.50
      03-04-2020, 03:36 PM   #478
243Racing
1448
The contradiction in this thread is brutal for us overthinkers.
So the CSF is out, the VRSF 6.5 is out. VRSF hasn't PMed me back anyway. Might just stick with stock.
      03-04-2020, 03:57 PM   #479
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
I'm noticing a trend for the necessity of a plug and play solution. I'll see if we can't get a M2 in here next week so we can properly scan the cavity and design a M2 specific intercooler for the folks interested in a mod-free solution.
      03-04-2020, 03:58 PM   #480
cecaa850
That's the problem I ran into with VRSF. You're at their mercy when it comes to communication. There's no phone number to call and if you have a question or God forbid an issue when installing you have to just sit on your hands and wait.
Whatever you ultimately decide to do, do yourself a favor and deal with a company that offers phone support.
243Racing1447.50
      03-04-2020, 04:02 PM   #481
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
We've been in business for 15 years without a dedicated phone line. Our support team works from 8 AM to 7 PM, Monday through Saturday and e-mail communication offers our customers flexibility that a phone line simply can not.
I completely understand if your preference is phone support rather than e-mail but we're able to provide our customers with better service via e-mail. If phone support is your go to, we have over 250+ resellers in the US who do offer phone support
      03-04-2020, 04:06 PM   #482
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: F90 M5
We've responded to your PM.
243Racing1447.50
      03-04-2020, 04:16 PM   #483
243Racing
1448
To be fair, I'd rather sandpaper the asshole of an alligator in a toll booth than have to talk to someone on the phone
koastal375.50
      03-04-2020, 04:24 PM   #484
cecaa850
It would be days (week days) between correspondence and my vehicle was down during that time. You need to get a phone if you're serious about customer support. There's nothing worse than having your car down and waiting on an e-mail answer that may or may not come that day. It's extremely frustrating. None of your resellers can make warranty decisions so talking to them is a moot point.
243Racing1447.50
