01-23-2024, 10:02 AM | #1 |
Rep 48
Driver's Side Front Wheel Running 10° Hotter
Gents,
After my TPMS required a reset I noticed my driver's side front wheel runs on average 8-10° hotter than the rest of them. A quick google search has revealed a few reasons for this, but has anyone else experienced this? My '21 M2C only has 7.5k miles on it. |
01-23-2024, 11:09 AM | #3 |
Rep 962
How much do you weigh?
2020 M2C
2018 M2 LCI Gone 1M, 991.1, 991.2, 718S, 991.2 TT, R8 Spyder RWD |
01-23-2024, 06:44 PM | #5 |
Rep 7,431
on the s55 there are heat exchangers on both side. On the n55 the aux radiator is on the driver side and the oil cooler is on the passenger side. Technically you should see higher temps behind the oil cooler when it is fully open and flowing oil, because oil is always running hotter than coolant, and because the aux radiator has no pump to flow fluid through it so flow is generally quite slow.
01-23-2024, 07:06 PM | #6 | |
Rep 557
01-23-2024, 07:19 PM | #7 | |
Rep 7,431
Not sure why this phenomenon exists, but it does. Corner weighting doesn't really explain much either especially just for street use: https://f87.bimmerpost.com/forums/sh....php?t=1700383 Passenger side front is heavier as expected since there are 2 heavy turbos and down pipes on that side. OG is a bit different with the weight bias being on the driver side front: https://f87.bimmerpost.com/forums/sh....php?t=1819724
m0g2446.00 |
01-24-2024, 03:23 PM | #9 |
Rep 523
Is there a temperature delta that you would be concerned with? My assumption would be if a wheel is out of alignment that tire would have more friction/more temperature. Would a mild out of alignment wheel cause enough heat to really show up.
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers) 2014 M235i MT, BSM, MPE, Dinan Springs (Sold) |
01-25-2024, 12:26 PM | #10 |
Rep 3,953
No. If your alignment was that far off to increase heat in the tire, he wouldn’t be able to drive the car.
stlb5220.00 |
01-25-2024, 12:28 PM | #11 |
Rep 3,953
This is one of those cases where, too much information is too much information. Just pretend the temperature of the tires doesn’t exist and you won’t worry about it.
Fred Conoway365.00 |
01-25-2024, 12:46 PM | #12 |
n00b
83
Rep 12
If it were me, I’d bring a laser thermometer with you on a drive and see what the brake temps are at after warm-up and maybe spirited driving. Might be a pad not retracting?
///MPhatic13862.50 philth198.50 |
01-28-2024, 02:37 PM | #13 |
Rep 621
Same as OP on my car - around 10 degrees higher on the front drivers side wheel - more pronounced on my winter tires than the summers.
It bothers me too, since I dont understand why, but wear in that corner hasn’t been any better/worse than the other 3, so idk.
2021 M2C, HS / 6MT
2019 Mini Cooper S Hardtop 4 Door / 6MT 2022 Mini Countryman All4 JCW No longer with me: 2018 Golf R, 2017 F80 M3, 2016 F30 340i xDrive |
