11-23-2023, 03:30 AM | #67 |
Rep 71
the car is new to me, just over 1 month old.
the only indication i believe i have of how it was uses is: it still has the original pilot super sports tyres, the tyre manufacturer date was 2019 same as the car reg date. the fronts have 6mm of tread on the and rear 4mm, i dont think it has been on many track days... MPG is 19mpg the car was purchased from a London dealership my guess it has been mostly used as a city commuting car Last edited by timchump; 11-23-2023 at 03:37 AM.. |
11-23-2023, 03:52 AM | #68 | |
Rep 8,970
I'd say if the brakes are working fine, the OBC says many 1000's of miles to go yet, then they're good to go. Presume it's had an MOT? They check disc and pad condition and would put an advisory on it if they had any concerns (of fail if they were very poor). |
11-23-2023, 04:26 AM | #70 |
Rep 8,970
I see you're South West, there seem to be some good indies there.
https://the-bmw-specialist-register....mw-specialist/ Really you'll get such a better job from a good Indy, checks reviews etc. |
11-23-2023, 04:55 AM | #71 | |
Rep 71
They also went into detail on the bonus scheme mechanics at bmw get for getting new work in on tyres and brakes etc |
11-24-2023, 08:29 AM | #72 |
Rep 337
11-24-2023, 09:18 AM | #73 |
Rep 71
i like the way he says somebody who can take care of her
i genuinely think this man will gladly spend $5k every 25k on a brake service to take care of his princess if that's what the BMW sales man says then sure why not Last edited by timchump; 11-24-2023 at 09:24 AM.. |
11-24-2023, 11:34 AM | #74 |
Rep 337
11-30-2023, 01:03 PM | #75 |
Rep 39
Just picked up a 20' M2 Comp with 55K miles. Pads are okay but rotors failed my state inspection coming in at 34.36mm and not making the 34.4mm required minimum. After a bit of hand wringing I figured time to just suck it up at get new rotors...
Wanted to go OEM so picked up 4 new rotors (figured I would just do all at the same time) 2 new wear sensors, 8 rotor screws (front and back are different) and then 8 new caliper bolts. Paid about $1560 for the 4 rotors. I could have picked up maybe for a few bucks less but I bought from FCP Euro which will replace for free when they wear out. I have done that in the past and it pays for itself. Paid about $135 for the sensors, bolts and screws in total. For the pads I was planning on going with EBC Redstuff (really just wanted to try them out as I have never used them before) but the rear pads were no where to be found and backordered until January at the earliest. With no EBC's, went ahead and ordered Carbotech 1521's. Will give them a shot, they seem to get decent reviews. Rotors and pads on M cars are very straightforward, replaced them on previous M3 and M5 with no issues. Looks like the M2 is exactly the same. For those that might be a little hesitant, there are a lot of guides out there on the step by step process. |
11-30-2023, 01:19 PM | #76 |
Rep 8,970
Interesting it failed on rotor thickness when even bmw say being under thickness just means can't reuse come pad change time.
Seems your state inspectors are overdoing it a bit. 0.04mm under if it was a warmer day they'd probably have passed... Anyhow, good effort on changing your own, i did mine but the rotor screws were all seized solid. I had to drill them out and clear it up with a tap. |
11-30-2023, 05:39 PM | #77 | |
Rep 1,610
I am getting some new rotors, they are at 33.8 lol, no way I will let it go till the pads finish. Ferrodo 1.11 definitely eat these up but just gonna do FCP euro and get free rotors for life. I dunno how they get away with this |
12-01-2023, 12:21 AM | #78 | |
Rep 8,970
Is an open invitation for them to sell you parts you don't need. Seems these 2nh discs don't last too well. |
12-01-2023, 07:36 AM | #79 | |
Rep 39
I think the only reason they are so tight is that they don't want to lose the state inspection certification. Seems that having that certification is an easy way to make a few buck for very little work. Also, did the front rotors last night and sure enough the 4 hex bolts holding the rotor on where seized up. Never seen anything like that. Since I had seen the posts about it prior to starting the work, I used PB Blaster from both the front side and backside of the rotor (gave plenty of time to penetrate). Even applied a slight bit of heat. All with no luck, none would budge. Drilled them out, and even tried an extractor when I was able to get a ton of bite, but no luck. Was able to get the new rotors on just so I can pass inspection, and this weekend will tap( I though I had an M8x1.25 tap, but I was wrong ). Thanks Dougboy for the previous posts on drilling it out, probably saved me a good amount of time messing around. Although if I had the stud conversion I might not even worry about drilling them out, but then again my OCD would probably get the best of me.... |
12-01-2023, 09:46 AM | #80 | |
The Seeker
13864
Rep 3,326
12-01-2023, 11:54 AM | #81 |
Rep 39
///MPhatic13864.00 |
12-01-2023, 08:26 PM | #82 | ||
Rep 1,610
12-02-2023, 03:53 AM | #83 | |
Rep 8,970
Hopefully the next owner will thank me... Last edited by doughboy; 12-02-2023 at 06:07 AM.. |
12-02-2023, 06:45 AM | #84 |
Rep 1,610
yeah i can't believe people are installing these dry (and I guess same with the caliper pins) with this being a known issue. And specially with those bolts that don't even need to be in there, any grease will do a better job than dry
12-02-2023, 11:26 AM | #85 |
Flavor of the month
889
Rep 716
Drives: BMW F87 M2C
They’re the best. I looked at the 2NH rotors and I said, ‘look, these are the best’.
Samuel of the Internet
2023 F98 X4M Comp 2023 F95 X5M Comp 2020 F87 M2 Comp |
12-11-2023, 12:54 AM | #86 | |
Rep 7,299
12-11-2023, 07:48 AM | #87 | |
The Seeker
13864
Rep 3,326
12-11-2023, 09:20 AM | #88 | |
Rep 8,970
