M2 Technical Topics > Track / Autocross / Dragstrip > Installing a racing seat
      11-26-2023, 12:35 AM   #1
GeraldM2
Drives: BMW M2 (F87) LBB 6MT
Installing a recaro pole position in the coming weeks and have no idea where to start. So i figured i'd come to the fourms for some solutions.
Which is better? Coding out the seat or getting a physical resistor? (I do not plan on switch seats)
I want a sliding mount that can accomodate me and my friends, but i don't want to compromise on seat angle nor do i want to take too many parts off the stock seat (i am okay with taking the original seat belt buckle)
Any and all help is appreciated!
      11-26-2023, 12:44 PM   #2
FaRKle!
Coding is easier since there aren't really any guides/writeups on the parts to use for emulators.
      11-27-2023, 06:02 PM   #3
jwr9152
Drives: M2 Competition
coding is the easy button for sure. For Recaro's with sliders I used the Macht Schnell mount. Worked great. Tried the VAC mount, but it didn't play well. Looked at the Brey Krause, but didn't want to take on the wiring, but looks like a cool set up.
      11-27-2023, 07:37 PM   #4
ZM2
Drives: 2017 LBB M2
I mentioned the mount I used for my Sport C here, and we coded it: https://f87.bimmerpost.com/forums/sh....php?t=2047388
      11-28-2023, 07:46 PM   #5
GeraldM2
Sounds good, who would you reccomend to code it out and where should i be putting the harness for the seat?
      11-28-2023, 10:05 PM   #6
FaRKle!
I can code it remotely 😁.
You can just leave the harness under the seat or try to tuck it into the carpet a bit more.
sly1types431.50
      11-29-2023, 04:46 PM   #7
GeraldM2
I just need an ENET cable right?
      11-29-2023, 07:11 PM   #8
FaRKle!
Yup, ethernet to obd2 cable and windows laptop (or Mac with windows emulator) with ethernet port.
      11-30-2023, 10:58 PM   #9
GeraldM2
Will this one work?
https://www.amazon.com/dp/B07DKCBGJZ...t_details&th=1
If not ill have to cancel this and reorder (NBD)
      12-01-2023, 11:26 AM   #10
ThreeStripes
Drives: X3M
Not sure if OBD > USB will work or not.
This cable will though for sure: New 2M Ethernet to OBD Interface Cable E-SYS ICOM Coding F-series for BMW ENET https://a.co/d/1vCDxqu
I’d grab that one just to be safe unless someone else can confirm the USB 2.0 route works as well.
      12-02-2023, 04:20 PM   #11
FaRKle!
Will this one work?
I recommend getting the ethernet version. Even the cheaper $12-15 models on Amazon work fine.
