07-21-2023, 11:46 AM | #1 |
Rep 6
KW H.A.S. springs noise
I installed KW H.A.S. COILOVER KIT on my M2 comp.
Now I hear clicking noise from rear left spring when going over bumps. If I move it a bit with a hand, noise is gone for a while, but it comes back. It only comes from the left wheel. Anyone experienced the same issue? Mine are installed like on this photo, helper spring is on top. Can this be an issue? |
08-24-2023, 11:59 AM | #2 |
Rep 858
Drives: F87 M2CS
I believe the helper is on the bottom. Your setup is backwards. Someone correct me if I'm wrong
MY18 F82 M4
Austin Yellow / Black / DCT / MPE |
08-28-2023, 04:56 PM | #3 |
3847
Rep 54,376
Drives: F80 M3
Helpers can go on the top of bottom and still serve the same purpose. That said you follow KW's instructions.
if the source of the noise is from the helper spring coupler, add a set of thrust bearings/sheets can help. You really should have thrust bearings/sheets on all the springs to reduce noise/spring bind/rate spikes. |
