07-06-2023, 11:37 AM | #45 | |
Rep 4,146
I posted a bit about it in ZM2's thread, but I was searching around and I found something that will hopefully settle this matter.
Mods: Yes.
08-10-2023, 04:50 AM | #46 | |
Rep 573
08-10-2023, 07:13 AM | #47 | |
Rep 4,146
The CSF radiator causes higher coolant temps and the oil cooler causes higher oil temps.
Mods: Yes.
08-10-2023, 07:50 AM | #48 | |
Rep 573
Max Cool. Stock radiator - why/how does the CSF radiator cause higher coolant temps (relative to stock I assume)? How does CSF oil cooler cause higher oil temps (relative to stock I assume)? Thanks for your feedback and in advance for your response! |
08-10-2023, 08:08 AM | #49 | |
Rep 4,146
On the CSF radiator, a few people have change to it and immediately experienced higher coolant temps. The CSF oil cooler was only able to decrease oil temps by 2-3F on a M235i which has a smaller oil cooler than the M2 (13 rows vs 15 for the M2) It's not hard to imagine the CSF being worse in this case. Another data point to consider: I've never heard of the CSF oil cooler helping anyone. Edit: Just watched a video on the CSF oil cooler being installed on a F3X by Kies. It's 14 rows in the front (so less frontal area than the M2's oil cooler) and additional 4 rows on the back...which means you're trying to cool the back rows with hotter air. No wonder this thing barely works.
Mods: Yes.
08-10-2023, 08:18 AM | #50 |
Rep 422
Drives: F87 M2 DCT, F15 X5
Curious - what engine oil is everyone using? My S2000 oil temperature was very sensitive to viscosity. Now that was a 9,000RPM motor… Running a 15w-50 would result in >280F within a few laps while a 5w-30 would sit 250F all day at 90+ ambient temps. My point is that using a thicker oil or less efficient oil will result in higher temps all around due to extra windage and pumping losses in the engine.
As a reference, my stock power car runs at 220F coolant and 230F oil in 90-degree ambient using BMW 0w-30 LL-01FE. DCT oil temps around 200F. Coolant and oil temps have never been a problem. And yes, I’m driving fast. Maybe next event try the genuine oil and see if that brings temps down. Last edited by E90convert; 08-10-2023 at 08:53 AM.. |
08-10-2023, 11:35 AM | #51 | |
Rep 557
ZM2 (470whp) the resident track meltdown expert runs Motul V300 iirc. I’ve switched to Motul Xcess Gen2 5w40 myself (~390whp) but don’t run in 90*+ weather since our track season is year round and it’s miserable. |
08-10-2023, 11:38 AM | #52 | |
Rep 422
08-10-2023, 08:19 PM | #53 |
Rep 573
I have been switching it up, but with the oil temp difference between stock thermostat + stock oil cooler and Mossleman thermostat + CSF oil cooler I was running LiquiMoly 5W-40 (same oil for both arrangements). I'll be putting in Redline 5W-30 in for my next oil change...just trying to figure out if I am going to stick with the CSF oil cooler. I might bite the bullet and go with do88. Not sure if that's the best one or not - seems to be.
08-11-2023, 03:32 PM | #54 | |
Rep 4,146
Mods: Yes.
08-12-2023, 04:56 AM | #55 | |
Rep 573
If temps don't improve, then I guess it's not the cooler. I might switch back to the stock thermostat as next step...then vent the hood and maybe fenders. When I switch to the do88 oil cooler, I'll be doing a test on the oil pressure upon priming the oil system with and then without spark plugs. I am looking forward to that, too. |
08-12-2023, 08:47 AM | #56 | |
Rep 3,696
I’m CSFless now (do88 radiator & oil cooler, stock DCT cooler with larger M2CSR DCT pan). Altho, my do88 oil cooler didn’t arrive from Europe in time for the track day I had planned, and now I have a lot of travel coming up so I’m not sure if I’ll get to test everything on a hot track day this year. Will see. |
08-12-2023, 05:11 PM | #57 | |
Rep 573
Since I have the bumper cover off, I am painstakingly using a pick to straighten out fins in the radiator. I am not ready to buy a new radiator yet, so this is a minor (?) help. Car has about 30,000 mile, but about 1/4 if that is likely track miles. It's amazing the dings in the tubes that look close to causing issues and some of the tiny rocks that get stuck/imbedded! |
ZM22810.50 |
08-14-2023, 08:10 AM | #58 |
Rep 4,146
Do you have a log of this event? I watched the video, and it looks like you're at 230F oil within 2 minutes. I see you oil temps just get up to 26XF, but the coolant actually stays low until your oil gets to that range and comes up to 24XF.
Mods: Yes.
08-14-2023, 04:35 PM | #59 | |
Rep 573
08-14-2023, 05:13 PM | #60 | |
Rep 4,146
Well, I'll say this actually doesn't look as bad as I thought. You're running a longer session, higher speeds (144MPH!) higher temps and your car basically reached that peak speed every single time. You never hit limp mode and were able to go flat out. This is actually pretty good, maybe try max cool next time? Otherwise that new oil cooler will help.
Mods: Yes.
08-14-2023, 06:44 PM | #61 | |
Rep 573
Which log are you referring to? Sorry - not understanding.
This can't hurt either: A timelapse: https://youtube.com/shorts/0K31UjM85a4?feature=share Left side done, right side not done: Both sides done: |
08-15-2023, 08:39 AM | #62 | |
Rep 3,696
Anytime ambient is above 75F, oil will go 260F+, coolant will go 242F+, the car will start to pull power, and temps slowly keep increasing to >270F oil and >250F coolant, even tho the car keeps pulling more and more power. I’m hopeful the do88 oil cooler & BMS oil cooler bypass will keep the oil temps lower and reduce the cascade effect to the coolant side, but have to find a hot track day that fits in the next cpl weeks to test. And, my updated tune that tapers boost up top to ~3psi lower without dropping power much should help. Last edited by ZM2; 08-15-2023 at 09:22 AM.. |
08-15-2023, 09:26 AM | #63 | |
Rep 4,146
And I watched the video and reviewed logs, his coolant hit 241 once, but his oil never went above 262. In fact, the coolant was never really an issue until near the end of the course when the oil was getting too hot, even then it came back to respectable levels. He never hit limp mode, as detailed as his consistent 144mph top speed on each lap.
Mods: Yes.
08-15-2023, 11:40 AM | #64 | |
Rep 3,696
I’m just saying he’s already right at the edge. A bit more ambient temp, power, or faster track (150-155mph up here) and then he’ll be getting power pulled bc of oil & coolant temps. What were IATs (I didn’t look)? It could be he’s hitting over 110F a decent bit and the car is already pulling power before oil & coolant temps get high bc of the power being pulled due to high IAT’s, and that is actually helping the oil & coolant temps from getting out of control. That was kind of the point of my original response to to the OP’s thread. If you cure the IAT issue, you very well may more quickly hit the coolant & oil temp issue and will then have to address that. Altho, there’s a lot of factors at play that we’re all trying to figure out. Last edited by ZM2; 08-15-2023 at 12:32 PM.. |
08-15-2023, 01:12 PM | #65 | |
Rep 4,146
Mods: Yes.
08-15-2023, 02:29 PM | #66 | |
Rep 3,696
If he solves the IAT issue to keep them <125F on a laps like those, there will be a good bit more power being produced which will only increase the coolant and oil temp reduction needs for the car. The power decrease from high IATs like that is very noticeable on track, and it’s helping him keep the engine cooler right now. Slap on a better IC, and be prepared to go whole hog on coolant and oil upgrades. |
