05-15-2022, 02:14 PM | #1 |
Rep 488
Anyone go from AST 5100 to Bilstein PSS10?
Hi,
Has anyone got experience of both AST 5100 and Bilstein PSS10? Be great to hear some thoughts on how they compare if you have. The ride of the AST's is amazing for fast road, and they were good around Silverstone as well, but they will probably need a rebuild at some point over the next year or so - it really isn't much extra to swap to the Billy PSS10's (considering the resale value if the AST's). Cheers. |
05-15-2022, 04:24 PM | #2 |
844
Rep 1,962
Well, the following doesn't have AST, but it does have Billies (and others):
https://f87.bimmerpost.com/forums/sh...highlight=dyno HTH |
widetyres279.00 |
05-16-2022, 02:18 AM | #3 |
Rep 130
The AST is way better overall than PSS10 especially if you're planning on tracking them.
widetyres279.00 starlord722.00 |
05-16-2022, 02:53 AM | #4 | |
Rep 488
OK, pss10 not the route to go down. Coincidentally I have just been offered a set of lightly used ohlins r&t. In standard form, I know they'd not be as good on the road as AST, but revalved with a slightly softer front spring (like 3dm offer with their roadsport kit), they might be a good alternative. Hmmmm..... any thoughts on that? Thanks. |
05-16-2022, 03:36 AM | #5 | |
Rep 130
widetyres279.00 |
05-16-2022, 05:30 AM | #6 |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
widetyres Ran Ohlins R/T on my 18' M2. Cannot recommend for both track and road compared to the AST 5100s.
The AST 5100s feel more stable on the track in my opinion and also smoother on the road. Also my Ohlins R/T had to be wiped down and lubed every oil change to stop it from creaking / clicking at low speeds and turns. Im sitting at 6 tracks days so far this year and 27,000 Km on my AST 5100s. Will see how long they can go before a rebuild! Aiming for 50,000km and maybe 35 more track days! ;D
-2021 M2C, HS, 6MT
-AST 5100, AP Racing 9660, BMW-788M, RF-GT4, BW-TA5R, APR GT 250 Wing & Front Splitter -TMS Diffuser, TMS F80 Skid Plate, HEX Armor PPF, CAN-Checked Data Logger, RaceBox -Recaro Pole Position , 2kBody Half Cage, Pinnacle Motorsports Half Cage (On order), CAE Shifter -Remus Race + BR EL Mid |
05-17-2022, 01:29 AM | #7 | |
Rep 488
The AST kit is very good - just the other day I gave a friend a lift and he was blown away by how composed the suspension was, given how taut the car is. Surprised that the AST is better than Ohlins on track, but as I mentioned, on my track day I certainly didn't leave feeling that the AST suspension could of been better - it was really good. i will stick with what I have then! |
02-17-2023, 02:20 AM | #9 |
Rep 303
I have used the Litchfield AST kit for 2 years and it's great so far. It has a great combination of compliance with excellent body control. I of run my damping rates higher than most and they have worked perfectly so far.
Ive always been a Bilstein fan and although never compared. I bet Litchfield could comment on the two. I was there recently having the ride heights adjusted and they moved form AST to Bilstein I think due to supply as a lot of stock is kept in Denmark |
03-01-2023, 05:08 PM | #10 |
Rep 566
03-06-2023, 01:20 AM | #12 | ||
Rep 488
One of my fronts did need a bushing replaced though after approx 12-15k miles. Ast rebuilds are half the price of ohlins though,so only cost me £130. |
Carrera2RS203.00 |
03-06-2023, 07:15 PM | #13 |
Rep 566
Not sure exactly what the problem might be. My winters are below freezing for about 4 months, lots of moisture, some dirt and sand on the roads during the cold season. I had a theory that monotube coilover kits might be more susceptible to really cold weather. Could be the oil changing viscosity too much with really cold temperatures. Just a theory. Over 10 years or so, I had 1 AST5100 kit, 2 Bilstein P16 kits, and 2 Bilstein B8 shock absorbers leaking within 10k range and all in winter. Although in case of AST5100 it was a rear, all the others were fronts. Never had the same issue with twin-tube kits (like KW2, KW3, M Perforamance, H&R). That seemed a bit strange to me.
03-07-2023, 01:27 AM | #14 | |
Rep 303
03-07-2023, 10:32 AM | #15 |
Rep 30
Guys, I pulled the trigger an a new AST 5100 kit. Plan on putting it on in the spring. Any recommendations for maintenance would be appreciated. I also don't plan on driving the car below 40F so hopefully cold won't be an issue. But is sitting in the garage on ASTs during winter is ok I assume?
08-18-2023, 06:52 PM | #16 | |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
-2021 M2C, HS, 6MT
08-21-2023, 01:28 PM | #17 |
Rep 30
08-22-2023, 10:04 PM | #18 |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
Yea every few months ill clean off the suspension with air. Get all the dust and small rocks off the exposed shock. Clean it with parts cleaner and then spray it with Super Lube multi purpose sythentic lubricant.
-2021 M2C, HS, 6MT
08-31-2023, 10:27 AM | #19 | |
Rep 30
This is the email I sent them: “I recently purchased AST 5100 coilovers for my 2017 BMW M2. I need an installation manual, can you please send me one? Also, I would like to know the ideal rebound settings for street driving. I live in the USA, in case you need to know. And, if you could could tell me ideal settings for track driving as well, I would appreciate it. I know this can change based on track and personal preferences but I want a setting to use as a baseline. Also, are you able to provide the ideal ride height and where the spring perch needs to be set as an initial starting point during installation? How do I set the preload? Is this explained in the instructions? Also, are the torque specs included in the instructions as well?” Thanks |
08-31-2023, 02:03 PM | #20 | |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
Did a install guide etc not come in the box?
-2021 M2C, HS, 6MT
09-01-2023, 10:33 AM | #21 | |
Rep 30
I sent an email to: support@motonsuspensionusa.com info@ast-suspension.com But haven’t heard back still. Installation guide was not included in the box. There was a paper that said to contact support@motonsuspensionusa.com about any questions regarding installation. Thanks. |
09-11-2023, 08:40 PM | #22 | |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
-2021 M2C, HS, 6MT
