12-29-2021, 07:09 AM | #1 |
Rep 1,126
I thought I would share some details since I struggled getting answers to some of my questions when I was searching.
My car is a 2018 OG M2 DCT with the stock brakes. The car has 22k miles, so the OE rotors are in good shape. I was tired of the dust and didn't care about losing that initial bite that the OEM pads provide. I ended up going with Akebono for a couple of unscientific reasons: cost effective (purchased from FCP Euro for $280), prior good experience with Akebono on previous cars, and low dust. I do not track the car, so these seemed like a good fit for a street car. The installation was extremely easy and took 15 mins per wheel. I did replace the brake pad wear sensors since I was already there - I would recommend doing this. Drivability: I noticed an immediate difference without the immediate bite from the OEM pads. However, there is overall more brake power but it is linear - the harder you press the pedal, the faster you stop. No initial bite/jerk when you tap the brake. So far I have not had any issues with squeaking or the occasional bang/click/tap you hear when driving in reverse when the pads shift within the caliper. Dust is significantly less, and I'm sure will continue to decrease with usage. Here is a link to the front set: https://www.fcpeuro.com/products/bmw...kebono-eur1880 Rear: https://www.fcpeuro.com/products/bmw...kebono-eur1656 Anything from FCP Euro comes with a lifetime warranty, even replaceable items like brake pads. Let me know if there are any questions! (Dirty pic is obviously the old pad) |
12-30-2021, 08:56 AM | #2 |
24201
Rep 190,807
Thank you for the review
WOT Bimmer1226.50 |
12-30-2021, 02:45 PM | #3 |
Rep 309
TY for review
Unrelated: what diffuser is that? it looks great |
WOT Bimmer1226.50 |
12-30-2021, 02:46 PM | #4 |
Rep 1,126
WedgeSalad280.50 |
01-19-2022, 08:50 AM | #6 | |
Rep 1,968
Good review. |
01-19-2022, 10:08 AM | #7 |
The Seeker
13864
Rep 3,326
One of the very best street-car mods you can do in my opinion. Not only do they dust significantly less, but your rotors should last at least twice as long.
WOT Bimmer1226.50 |
01-19-2022, 10:12 AM | #8 | ||
Rep 1,126
///MPhatic13864.00 |
01-19-2022, 10:54 AM | #9 |
The Seeker
13864
Rep 3,326
This is exactly my experience. I didn't like the stock progressive pad, creating more and more braking force without me adding more pedal. If I want more braking, I'll brake harder, which is what you get with a linear pad. So for me the linear Akebono pads were a welcome change, even without less dust, and less rotor destruction. I also get no noise at all.
WOT Bimmer1226.50 SilverM2_CS103.00 |
01-21-2022, 01:56 AM | #10 | |
13
Rep 15
Interbc11.00 WOT Bimmer1226.50 |
01-21-2022, 04:44 PM | #11 |
Rep 602
Well done review as above mentioned. Made this switch one year ago this month and have not looked back. Was simply, irrevocably and irritatingly finished with excessive brake dust and maintenance...and I maintain things. The braking is also spot on.
WOT Bimmer1226.50 |
06-02-2023, 05:36 AM | #12 |
Rep 1,968
Bumping this thread for the kudos, I finally got around to installing my Akebono pads that had been sitting on a shelf and I'm not sure why I waited so long.
Any difference with cold bite is so very minor, it's almost imperceptible and it's remarkable how clean the wheels still look after 4+ hours driving with both hard braking and stop and go traffic during 2 days of my Boston-area commute. |
4
10-01-2023, 06:48 PM | #13 |
Rep 484
Drives: 2018 M2 6MT
Swapping out the OEM brake pads for the Akebono's is definitely something I'd like to try on my M2. Good riddance brake dust!
I've just recently watched one of the recent Engineering Explained videos about how the brake pad friction material is attached to the backing plate — either mechanical attachment or adhesive: Anyone know how the Akebono friction material is attached? Anyone willing to sacrifice a nearly-worn-out Akebono pad to find out? |
10-03-2023, 06:51 AM | #16 |
The Seeker
13864
Rep 3,326
Low dust, no noise, and they preserve your rotors. For a street car that means that you won't need rotors until 80K+ miles. Personally, I prefer the dust color as well, it's not black, it's light grey, and if you're a freak about your wheels like I am, just a quick blow from the leaf blower after every drive makes them *appear* to be clean for quite a while. I also hate progressive pads with a passion, and found the Akebono's to be fantastically linear.
gphung193.50 |
10-03-2023, 08:40 AM | #17 |
Rep 309
Drives: 2018 M2 LBB - 6MT
FCP description says no break-in (I assume similar to bedding) required. Have you guys found that to be true as well? Really getting tired of both the bite and dust of the OEM pads.
