M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Disadvantage of Adding Spacers to Setup?
      10-11-2019, 01:22 AM   #1
mscdman
Drives: 335xi
I am adding a winter wheel square set 18x8 ET29 for my winter wheel setup. According to the fitment calculator, the front will be set in from the fender about 12.7mm and the rears 14.4 less. I’m thinking about adding 12.5mm spacers to the front and rear for visual appearance. Aside from being even further from the inside strut, what are the disadvantages of this?
Wondering if I should put 12.5 spacers in front and 14 in rear also...
      10-11-2019, 02:03 AM   #2
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Changes scrub radius hence puts more load onto suspension and steering components; effects your insurance premiums; too wide esp at the rear in your case and you will rub tyre outer shoulder and fender
Current '22 X3M LCI..
      10-11-2019, 05:09 AM   #3
mscdman
Drives: 335xi
Wow - too wide at rear even though I’m only trying to bring out to stock level with these 12.5 spacers and my setup?
Would any size spacer bring it out to look more stock and not cause the rubbing?
      10-11-2019, 06:15 AM   #4
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
I've seen 10mmF & 7.5mmR and they look flush
      10-11-2019, 06:38 AM   #5
CTSean
Drives: LCI BSM MT M2
If it helps, this is what 18x8 et29 looks like. If they are set wider with spacers, I assume the car will throw even more rocks at the rear fenders.
      10-11-2019, 03:15 PM   #6
mscdman
Drives: 335xi
thanks! That doesn’t look as bad as I thought. I thought 18x8 ET29 would look way sunken in
      10-13-2019, 03:03 PM   #7
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
Rims might be set in a little, but what about the tyre shoulder?
The picture above shows a tyre that is wider for the rim than the summers. That helps fills the gap to arch even with rim set back.
Best get them fitted first then decide if you want spacers.
I put square winters on my old E91 335i. Ended up going for 10mm on the rear only, but again depends on tyre brand as shoulder widths are different even at same stated size.
