10-10-2019, 05:19 PM | #1 |
Rep 26
Relocating M2 from NY to CA
Currently living in NY and received a job offer for a role in San Jose. Would like to relocate with my M2 if I like it out there. Has anyone had any experiences importing cars into the state and what it would require/cost to make the car pass smog? I’m assuming it’s more cats on the exhaust?
Thanks! |
10-10-2019, 05:51 PM | #2 | |
Rep 7,428
This allows for cost savings as they only have to build a single spec and have it be one size fits all.
10-10-2019, 07:14 PM | #3 | |
Rep 289
10-10-2019, 07:18 PM | #4 | |
Rep 7,428
If it's stock then you shouldn't have any issues, if you have carb certified parts then you probably will have to show certificates so slightly more hassle but possible.
10-10-2019, 09:27 PM | #6 |
Rep 7,428
I heard the jb4 was going to a carb certified route, talk to Terry about it since I haven't been really looking into the jb4 since flash tuning was out. If this is the case he could probably send you a carb certified certificate.
10-11-2019, 04:44 PM | #8 |
Rep 20
Smog testing in CA also isn't required until a car is over 4 years old... so depending on what year your M2 is, you'll have some time to sort it out.
That said, nothing except a modified downpipe/cat should should trigger a smog test problem.
Current: 2017 Dinan S1 M2 - LBB 6MT
Previous: 2005 M3 Mystic Blue 6MT |
10-11-2019, 05:01 PM | #9 | |
Rep 4,341
10-11-2019, 05:39 PM | #10 |
on restriction from buying more cars
239
Rep 186
I did this with a 6 year old car several years back. The process may have changed, but it was straight forward. Get a smog certificate, make appt with DMV for inspection. They check smog stickers on car. M2 should have a 50 state emissions sticker under the hood. They look at your smog cert and give you plates on the spot.
10-11-2019, 06:40 PM | #11 | |
Rep 1,124
10-11-2019, 07:52 PM | #13 |
Rep 3,256
10-11-2019, 08:44 PM | #14 | ||
Rep 20
10-11-2019, 09:44 PM | #15 | |
Rep 4,341
10-11-2019, 09:45 PM | #16 | |||
Rep 4,341
10-11-2019, 10:34 PM | #17 |
Rep 289
10-12-2019, 01:53 AM | #18 |
Rep 4,341
No you can't. That's why I posted. Out of state inspection ONLY at DMV. Cannot be done by AAA. I'm on my third out of state into California import. Only DMV for inspection.
10-12-2019, 10:37 AM | #19 | |
Rep 289
Either way OP, you'll be fine with smog once you flash back to stock. |
10-12-2019, 01:28 PM | #20 | ||
Rep 6,635
nachob2314.00 |
10-12-2019, 01:29 PM | #21 | |
Rep 6,635
nachob2314.00 |
10-12-2019, 03:29 PM | #22 | ||
Rep 4,341
