10-08-2019, 09:20 PM | #1 |
6632
Rep 4,145
Drives: '18 M2 6MT
Does the M2 require rake?
Hey guys, I have a spare set of tires from my previous car that I'd like to use on the M, but they are a bit short in the back. I wouldn't bother but they only have 4,000 miles on them, and they are all-seasons, so I can use them this Winter.
Stock specs are: F: 8.8 TW & 25.8 OD R: 9.6 TW & 26.3 OD This gives a .5" rake. My tires are 235/35 & 275/30, which have the following specs: F: 8.1 TW & 25.5 OD R: 9.7 TW & 25.5 OD I know they'll fit, just a tiny stretch in the front, but the rear 30 series is the same OD as the front. I know some cars get their ABS modules freaked out by changing the OD's from front to rear too much. Is the M2 that way? |
10-09-2019, 09:50 AM | #2 |
Rep 427
The DSC/ABS will adjust after some miles. I run square winters and track wheels/tires. Takes a TPMS reset and 50-70 miles when I switch.
VisualEcho6632.00 |
10-09-2019, 09:55 AM | #3 | |
6632
Rep 4,145
Drives: '18 M2 6MT
About the TPMS reset, is this something the car does automatically, or do I need to take it to a shop like my old Lexus IS350? |
10-09-2019, 11:38 PM | #4 |
Rep 427
You reset in iDrive. Menu-> Vehicle Status. Should be the first option. Same place you can check tire pressure.
VisualEcho6632.00 |
10-10-2019, 03:54 AM | #5 |
Rep 396
Or just press the voice command button and say “tyre pressure” to bring up the display. Perform reset will be highlighted, ready to go with a button click.
VisualEcho6632.00 bentom2335.50 |
10-10-2019, 08:56 AM | #6 |
Rep 427
Hadn’t thought about this. The Nuance voice controls in the M2 are pretty great. I use them a lot for navigation and calls, but not for car controls. I’ll have to play with this feature more to keep me entertained in traffic.
10-13-2019, 03:28 PM | #7 |
Rep 8,970
Don't worry about it just reset TPMS, good to go!
Even matching tyres will be 1/2" difference diameter new to worn, before you figure pressure or load into it. |
VisualEcho6632.00 |
