10-07-2019, 12:14 PM | #1 |
Rep 95
HP numbers by Tune?
First I did do an extensive search but what I found were a couple of posts / threads where someone posts a link that leads to nothing more than a product page with no HP information... Some products did provided the usual HP number like Turner, Vivid and the likes but I dont see anywhere the numbers for BM3's tune. Does anyone know where that information is published?
I'm surprised that a product so popular has no HP info on their web site (disclaimer- I could not find the info so if it is there link me please) that you can use to compare. So does anyone have that information? what is the advertised gain from them for Stage 1 with 93 / 91? how about stage 2? and the likes... I want to get a tune but I also want to make an informed purchase... Thanks in advance for the info |
10-07-2019, 12:19 PM | #2 |
Rep 324
I could be wrong but I think one of the reasons might be that there is no single hp/torque gain that applies to everyone. I know they keep sending updates, which might change them too.
10-08-2019, 02:10 AM | #3 | |
Rep 1,466
2018 ///M2 LCI, LBB, 6MT...
Infamus75.00 |
10-08-2019, 02:14 AM | #4 |
Rep 1,466
My own story is that CA fuel is very low octane compared to most of the world, and also already contains quite a bit of Ethanol. I logged the stock map and have bad timing pull with CA 91 gas, so I tried adding more E85 to improve octane to run the BM3 OTS 91 map and hit the limit of my HPFP...
Just as a point of reference, I get ~16 mpg commuting to work, and about ~25 mpg on a long freeway run... If I'm lucky. CA fuel has so little capability that it takes a load more of it to burn effectively. Meth injection isn't used unless the load is high, so it doesn't affect cruising MPG at all, but I can say that if I'm on it, the fuel consumption does seem better now. I'm now running WMI 50:50 mix, and can happily run the BM3 OTS 93 map even on the hottest summer day. I'm pretty sure I'm consistently putting down quite a bit more power than anyone else in CA running the same map (if they even could), but that's to be expected. Would my numbers therefore be unfair for BM3 to publish... possibly, technically I am running the standard BM3 OTS map.
10-08-2019, 10:17 AM | #5 | |
24195
Rep 190,805
If you are looking for the most aggressive out of the box tune, get Active Autowerke flash. If you want the best flash in terms of power, features, etc.. get the BM3. It offers very strong off the shelf maps and we offer custom maps for customers wanting maximum power safely.
Infamus75.00 |
10-08-2019, 12:17 PM | #6 |
Rep 1,485
all you can get is a ball park from other peoples dynos. every dynos reads different..fuel, temp, evelation, health of the engine can all change those numbers.
all you can do is figure out what your powers goals are and do as much research as you can in how to get there. |
10-08-2019, 08:24 PM | #7 |
Rep 95
thanks for the feedback gents...
