10-06-2019, 10:38 PM | #1 |
Rep 492
Pads, Stainless steel lines, brake flush DIY (video)
My buddy and I did a little brake upgrade to the m2 this weekend. I hadn't done pads or lines before so he showed me how it's done. Hope this video helps some of you out, I can't believe the difference the carbon ceramic pads and stainless lines made.
10-07-2019, 05:23 PM | #4 | |
Rep 492
The sensor is super simple! Needle nose pliers and kind of rock it gently back and forth. You don't want to hit the actual sensor (you can see a bump where the sensor is). There's also one on the driver front which you remove and replace the same way. |
10-07-2019, 05:24 PM | #5 | |
Rep 492
The stainless lines adds the complexity mostly from the bleeding but they help a lot. |
chief1richard381.00 |
10-15-2019, 08:50 AM | #6 |
381
Rep 731
Nice video. One thing I found that helps doing the front calipers is turn wheels to left when working on right front, and right when working on left front, to give more room to access calipers. Also some Track Pads like Pagids don't have sensor slots. I zip tie the sensor and wire to suspension for when I switch back to street pads. Using side of punch to hammer back pins is something I never thought of. Thanks for posting.
10-15-2019, 10:23 AM | #7 |
Rep 4,516
Really ? M cars come with Kevlar oem flexi hoses that supposed to be equivalent of SS in terms of preventing any bulging & associated ropey pedal feel
Current '22 X3M LCI.. |
10-15-2019, 10:13 PM | #8 |
Rep 427
I noticed a much firmer pedal and higher engagement point after changing to braided lines. I was skeptical as I had read similar things about the OE lines, but figured it wasn’t much added effort since I was bulling the calipers to rebuild anyhow, so went for it.
10-17-2019, 01:33 AM | #9 | ||
Rep 492
10-17-2019, 05:44 AM | #10 | |
Rep 4,516
When I switched to Castrol SRF, pedal was & still is firmer and pedal linearity/modulation felt/ & still feels better. TBH, it maybe placebo but then again pedal/brake responses stay way more consistent on track, as one would expect with upgraded BF, even with std flexi hoses.
10-17-2019, 09:07 AM | #11 | |
Rep 427
So I had plenty of seat time before, and a consistent pedal feel through multiple pad and fluid changes before, and now have had several months of consistent feel after. They’re just different. I’ll add that I’m not even sure I like the current pedal feel and have considered switching back. It’s a bit harder to modulate and smoothly transition on/off the brakes because of the high, firm pedal. I’m mostly used to it, but have definitely had to adjust. You don’t have to believe me, but I won’t accept the placebo or fresh bleed explanations. |
10-17-2019, 03:26 PM | #13 | ||
Rep 4,516
Based on yr comments, I won't be swapping hoses any time soon as brake pedal feel and braking response is spot on for me. Thanks again for saving me a few pennies !!!
bentom2335.50 |
10-17-2019, 03:58 PM | #14 |
Rep 1,519
Thanks for posting--very helpful. The caliper design reminds me of the StopTech BBK I had on my E90 M3. Just a removable bridge for swapping out pads, making the process pretty easy.
Past: E46 330Ci, E60 545i, E60 M5, E90 M3
Present: 2020 M2 Competition, 2022 GT3 |
Poffman493.00 |
10-23-2019, 09:53 AM | #15 | |
381
Rep 731
