10-02-2019, 06:25 PM | #1 |
Rep 328
Terrible smell from air vent, need help
My car has developed a terrible smell like cow poop from the air vents. When I turn on automatic climate control, the smell comes out no matter if the AC is on or off. When I just have the climate control on (not automatic), the smell comes out for a brief moment and it won't smell anymore.
I have tried to put my nose up against the vents and it seems like only the middle vent have that smell, or it might be I can't extend my nose far enough into the vent to the left of the steering wheel because there isn't enough space. The smell wasn't there in the summer. Right now I can have the windows open, but when winter comes I will have to use my climate control. It would be a horrible experience if I have to smell cow poop everyday. If anyone have suggestions or possible causes of this smell, I would really appreciate it. |
10-02-2019, 09:56 PM | #5 | |
Rep 328
10-02-2019, 10:22 PM | #6 |
Rep 4,541
Drives: 2015 328d xDrive
Check air filters and refrigerant
NYC Bimmer259.50 |
10-03-2019, 11:12 AM | #7 |
Rep 430
Luckily I've never had this problem so far.
Various bimmerfest forum postings point to the evaporator as a possible source. Here's something you might want to try: https://1z-usa.com/klima-cleaner-air...ioner-cleaner/ |
10-03-2019, 01:34 PM | #9 | |
Rep 328
10-03-2019, 03:23 PM | #10 |
Rep 52
Check your cabin air filter? Something similar happened to me not long after I got mine and when I took the air filter out it reeked of the same smell. I swapped it out to a new one and the smell has gone away since.
10-03-2019, 11:09 PM | #11 | |
Rep 328
Btw, did your dealer replaced your cabin air filter or did you pay for it yourself? |
10-04-2019, 03:50 AM | #12 |
Rep 6
Try turning the recirculation on and turning the temperature up as high as it will go. Leave it like that for 10 minutes. If you've got bacteria in the system, this will dry it out and kill it.
10-04-2019, 03:30 PM | #13 | |
Rep 52
10-04-2019, 03:40 PM | #14 |
Rep 278
I had this issue in my former two Mercedes cars and now I'm starting to smell this from my M2.
In my A45 I had to go and replace the AC air filter. In my E350e I used an air refreshener bomb such as this one. I think (but not sure) that it depends where you live. For example, if you live in a hot and humid place like I do, it'll happen more often. I haven't dealt with it in my M2 yet. Will update after I will. |
10-11-2019, 11:23 PM | #17 |
Rep 328
I have been doing that for the past week, I thought it got better at first but the smell is back again. Ahhh this is annoying
10-12-2019, 01:39 AM | #18 |
Rep 7,421
I had this happen to me before on an older car and this is what I did to solve it (not saying that my situation is the same but I thought I could give some insight).
Ok so what happened was in the summer I would use the AC for long periods of time and not switch off the AC 10ish mins before I shut off the car or climate control. What happened was the air inside of the vents was so cold moisture condensed and when I shut off the car the moisture would just sit inside the vents without drying off (which is why turning the ac off and running ambient temp air through the vents to dry it is important). This moisture would cause mold build up causing a really foul wet dog/mold smell in the car whenever the climate control was activated. The only way I could fix it was by changing the cabin air filter, and spraying an entire can of lysol into the air ducts and blasting the fan to try and circulate it. That was the only way I could get rid of the smell. But before you do this I suggest you check the engine bay, cabin filter, and if you have a borescope check that middle air vent for anything like a bug, or small rodent that could've died in there.
10-12-2019, 03:48 AM | #19 |
Luxury at the redline :)
9103
Rep 7,563
Mention this to your dealer and they'll change the cabin air filter.
I'm not 100% sure but I believe it's still covered under the inclusive 3/36k maintenance agreement. If not, they go for like $30 for the OEM replacement. I make up phantom odors or embellish about my "allergies" and get my dealer to change mines at every other oil change, as they rightfully should be doing in the first place. Side note, I remember I had changed the cabin air filter for a friend on her Honda Accord and found remanence of a dead bird wedge in-between it. Yuck.. |
