09-27-2019, 04:31 AM | #1 |
Rep 16
Pre-Throttle TMAP Sensor and Manifold TMAP sensor 3.5 bar
Hello guys!
I need some advice to get the upgraded 3.5 bar sensors for my 2017 M2. I would like to buy the Pre-Throttle Tmap sensor and Manifold TMAP sensor Do you have any recommendations? Thank you so much! |
09-29-2019, 07:08 PM | #2 | |
Rep 7,429
Hello, First off lets start with a few questions and statements: 1) Why do you need a tmap replacment, is your factory ones broken? If not how much boost are you hitting because the oem sensors can read up to 21 PSI. 2) If you're tuning the car and are surpassing 21PSI you only need to replace the prethrottle TMAP sensor on the chargepipe, the manifold sensor does not need to be replaced or upgraded to 3.5 bar. This is because the manifold sensor measures vacuum and is only capable of a positive reading of ~2.7psi, while the prethrottle charge pipe sensor measures boost and is the one that needs to be upgraded if you surpass 21psi. 3) The sensor you will need to buy is an oem 3.5 bar N20/S55 tmap sensor found in the N20 or S55 powered bmws. Here is a link: https://www.ecstuning.com/b-genuine-...r/13627843531/ There are many other sources for this part as well, including but not limited to the dealer ship. Just make sure you buy an oem part because aftermarket or ebay knock off sensors are garbage imo, and will cause issues with accurate boost readings. - Also note you require a tune to calibrate the ecu to support the new sensor as the resolution is different and it can also read higher levels of boost. - Make sure you do more research before buying this part and installing as this part can cause damage to your car if installed improperly. - I believe on the F series that this sensor is plug and play (it was for my m235i), but just to be safe make sure you don't require an adapter harness. Good luck.
10-03-2019, 08:11 AM | #3 | |
Rep 16
Yes, I'm currently running a Bootmod3 Stage 2 and I want to upgrade the sensors to increase the boost. In the App you can toogle two options related the sensors: The Pre-Throttle Tmap sensor. You can put this to 3.5 bar The Manifold TMAP Sensor. You can put this to 3.5 bar too. So, the Pre-Throttle TMAP Sensor is what are we talking about, and in the flash I will select the 3.5 bar, but, I have doubts about the other setting, the Pre-Throttle Tmap sensor... So I don't know if I can toogle the 3.5 bar in the Manifold Tmap sensor as I can read for your response is only reading the vacuum... I found this genuine TMAP, do you think that is what I need? https://www.bimmerworld.com/BMW-Pres...627843531.html Thank you so much, I really appreciate it. |
10-03-2019, 08:40 AM | #4 |
756
Rep 2,149
Compare part numbers. You both linked the same part. You also don't need it unless you are running a bigger turbo. OEM turbo is never gonna run right at those boost levels.
10-03-2019, 12:48 PM | #5 | |
Rep 7,429
Also at 21 psi that's way out of the turbos efficiency range and you'll be making a lot of heat, so make sure you have an intercooler.
10-03-2019, 02:22 PM | #6 |
Rep 16
Thank you for the responses!
I'm not planing to upgrade the turbo yet, so I will stay with the stock TMAP sensor. I currently have intercooler, charge and boost pipes, bootmod3 stage 2, MPerformance exhaust, Catless downpipe and one step colder spark plugs |
10-03-2019, 03:58 PM | #7 |
Rep 7,429
Make sure you have the octane to hit those boost levels. I assumed that would already be a given, but I thought I'd just remind you. At 21 psi you'll probably need 98 octane +, octane as in aki not Ron or mon.
10-04-2019, 01:01 PM | #9 |
756
Rep 2,149
Just to make sure you're clear too. The 3.5bar TMAP sensor doesn't do anything to make more power. It just lets the car read higher PSI.
Think of it like this. A 500lbs person isn't going to be able to use a generic scale you can get at Walmart that only reads up to 400lbs. Same way our cars can't read higher than 20psi, because the scale (TMAP sensor) can't measure any higher. |
10-04-2019, 02:11 PM | #10 | |
Rep 7,429
10-08-2019, 02:20 AM | #11 |
Rep 1,466
There is also more potential for erroneous readings with the 3.5bar sensor. The output is an analog voltage from about 0.5v to 4.5v, if you squeeze more bar of dynamic range into that voltage range, the accuracy will drop.
I'm not sure if it's a real issue in practice, but I would say that if you've got no reason to use the higher bar sensor, there is no benefit in doing so, and potentially a negative.
2018 ///M2 LCI, LBB, 6MT...
10-08-2019, 02:25 AM | #12 | |
Rep 1,466
I've tried to bias the pre-throttle sensor to lower boost (as a fail safe), and under part throttle, the manifold sensor reads the correct boost pressure and keeps trying to adjust the throttle plate because the values don't match what's expected. I guess it's probably true that you only need to replace the pre-throttle, because you'll only see more than 20psi at WOT. This was just my findings after fiddling with these sensors a bit BTW, I'm not an expert.
F87source7251.50 |
10-08-2019, 02:35 AM | #13 | |
Rep 7,429
All I do know is the MAP sensor doesn't need to be replaced only the TMAP does. I also think theyre both different part numbers as well since the MAP sensor doesn't read temps.
10-08-2019, 03:31 AM | #14 |
Rep 1,466
I hope I didn't offend F87source, I always enjoy reading your posts and your contributions to the community.
The manifold sensor is the exact same part as the pre-throttle sensor, and you're correct that temperature isn't measured there. BMW probably did this for money saving (reducing component count), but they simply don't connect the wire to the temperature sensor output for the manifold sensor. This is worth knowing because if you end up with a failed temperature sensor in the pre-throttle unit, you can swap it out safely with the manifold one!
F87source7251.50 |
10-08-2019, 03:59 AM | #15 | |
Rep 7,429
Yeah I didn't know that for sure (was going to check real oem but it is past 3am here while I sit and process some data), ok I stand corrected then. Edit - So according to real oem the MAP sensor is: 13627599042 which is the same on the S55 (m2C, m3, m4) and N20 which again I did not know, but that is weird since that would mean it is a 3 Bar sensor. The tmap sensor is: 13627599042 which is also the same part number and is also on the S55 and N20 which again is really weird. So I don't know what is going on.
10-08-2019, 04:20 AM | #16 | ||
Rep 1,466
On our cars, and other N55 engines, the 13627599042 is both pre-throttle and post throttle.
10-08-2019, 12:59 PM | #17 | |
Rep 7,429
I see, yeah it's hard to think at 3, so it's not a mistake. But then that's a bit weird because if the S55 uses a 2 bar sensor on the manifold how does it read boost there? Leading to the thought that it just there for vaccum.
10-09-2019, 08:39 PM | #18 | |
Rep 1,466
At part throttle, and you can see this if you log both sensor readings, the throttle being partly closed restricts airflow and therefore lowers pressure in the manifold. In this case, it's the pressure in the manifold that's important for engine management, and not the pressure in the charge pipe. If you log the pressure in the charge pipe when cruising, it will be higher than in the manifold because the turbo is still providing some, though minimal, boost. The throttle plate then does the job of controlling this air-flow and boost pressure to get the load needed... using the manifold pressure sensor for this.
10-09-2019, 09:32 PM | #19 | |
Rep 7,429
Well thanks for the clarification!
06-29-2020, 10:44 AM | #20 |
Rep 3,695
Hey guys.
Digging this back up, we’re starting to hit above 21psi on my custom tune. I’m still waiting to hear from Halim that he wants to change this out based on our tune strategy, but if so, I just want to clarify that I need to change my TMAP with 13627843531, correct? If so, looks like FCP Euro has a good deal on the VDO: https://www.fcpeuro.com/products/bmw...or-13627843531 Thanks. |
10-01-2020, 11:10 AM | #22 | |
Rep 127
Drives: 2017 M2 Mineral Gray
I just ordered one of these myself to get ready for the inevitable need to read over 21psi with the Pure stage 2 turbo coming in a few weeks. Just had a Dorch stage 2 HPFP & Fuel It stage 2 LPFP & Bluetooth ethanol analyzer installed, so I'm ready for more boost |
Tags |
tmap sensor |
