08-31-2019, 10:27 AM | #1 |
Food Critic
1084
Rep 1,015
Maps - where are they loaded?
Quick question, are maps loaded at the factory, VPC, or dealership?
09-05-2019, 07:37 PM | #2 |
Rep 62
Drives: 19 M2C HS, 20 X3MC PB
I load the maps onto the car myself using a USB stick.
There are certain requirements you must have. - BMW Connected account - USB Map Update subscription. - Assign your car to your BMW Connected account. Go to your BMW Connected Drive account. Select your vehicle. In the Booked Services, look for Map update. Go into it and then you'll be able to find Manual Map Update. Download the BMW Download Manager. Once downloaded you'll need to log into the downloader. Then you should be able to find your car and its respective map it should have. Note: USB sticks needs to be formatted as fat32 in order for it to work. So any USB Sticks < 32GB is okay. If you have larger ones, you just need to create a partition that's less than 32GB and Windows will allow you to format that partition as FAT32. |
